Forum Index : Microcontroller and PC projects : New version of PicoMite/PicoMiteVGA V5.07.03
| geobh Newbie Joined: 29/01/2022 Location: AustraliaPosts: 7 |
Thanks matherp. I downloaded the latest version of PicoMite5.07.03 dated 31/1/2022 and it works fine. I had previously had version 27/1/2022. Problem solved, thanks |
Hi Peter, I was looking at one of these displays, reasonably cheap pounds 13.70 and 480x320 3.5" colour touch screen with case. It appears to use a ILI9486 chip according to this WIKI do you happen to know if your ILI9488 driver will also drive this panel? I was thinking of investing in one, I may just get one to test, if not I can drive it with an old Pi. Thanks Kevin. |
Based on the wiki it uses shift registers to convert SPI to parallel at the display. In which case the driver that might work is the ILI9481. ILI9488 definitely won't because 8-bit commands have to be sent with 16-bits to trigger the shift registers. Edited 2022-01-31 23:15 by matherp |
Hi Peter, Ok thanks, when it arrives I'll probably give them all a try, just in case. I didn't notice anything about converting SPI to parallel, that sounds tricky to drive, where did you spot that? Regards, Kevin. |
The wiki shows 3 shift register chips in the pic |
Hi Geoff, I'm modifying my new program to use GUI controls and pages. On page 95 in the section GUI SETUP it says "See also GUI PAGE command." I cannot find any other reference to GUI PAGE in the manual. Should it just say "See also PAGE command. Thanks George? |
