Local Time 09:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Floppy Drive, Is it possible?
     Page 3 of 3
Vampire05
Posted: 04:20pm 27 Jul 2021
Ok, thank you guys for the information!
Today i finished the case for my external CMM2 Floppy Drive: Here some Pics:
The next Step is to mount an IDE (40 Pin) Connector on the backside for the CMM2 Connection.
Edited 2021-07-28 02:21 by Vampire05
Kingeorg
Posted: 05:13pm 27 Jul 2021
Wow. That looks ROBUST!
Vampire05
Posted: 05:18pm 27 Jul 2021
these wooden panels and aluminuim sheets are the only material i have lying around here.
Posted: 06:23pm 27 Jul 2021
It won't blow off the table anyway. :)
Actually, I think it looks really neat. Your cutting and assembly look very precise.
Posted: 06:36pm 27 Jul 2021
Good work Vampire05,
It won't be long before we hear the buzzing and sizzling of the floppy....
I remember the excitement when my old Acorn Atom was reading disks with a home-brew disk interface (5 1/4 back then). The 160k back ten was sufficient for 20-50 programs. Good that we have 1.44Mb now with the CMM2.
Edited 2021-07-28 04:38 by Volhout
Vampire05
Posted: 06:42pm 27 Jul 2021
Thank you guys, i will keep you up to date
Vampire05
Posted: 10:50am 02 Aug 2021
hi Guys,
i have some problems with the xmodem transfer. here is the full basic file
floppy.bas.zip
the simple commands(dir, type, dump, rmdir, mkdir) works great but the xmodem command did not.
what i do:
i open the serial connection
open "com1:115200, 256, get_floppy_output, 1" as #1
then i send the arduino dos command:
print #1, "receive " + args(2)
and then the xmodem send on cmm2:
xmodem send "floppy.bas", #1
i tried also
xmodem send "floppy.bas",1
after longer waiting i see the empty file specified in args(2) is created on the floppy drive with the size 0. The cmm2 says "Remote did not respond".
Any ideas how i can debug this problem?
     Page 3 of 3
