Local Time 14:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.06RC7
     Page 3 of 4
Sasquatch
Posted: 04:28pm 06 Nov 2020
Something has changed in .JPG decoding along the way.  Now I see horizonal bars of black across some images.
Try running this:
https://www.thebackshed.com/forum/ViewTopic.php?TID=12538&PID=152343#152343#152343
-Carl
Posted: 06:05pm 06 Nov 2020
Carl
Please download and try again - no version change
Sasquatch
Posted: 08:34pm 06 Nov 2020
  matherp said  Carl
Yes!  That's got it. Thanks for the quick response!
-Carl
Posted: 10:34am 07 Nov 2020
Hi Peter,
Close, but no cigar. This worked previously (including RC 12 & 13) but no longer works in RC 14:
Colour Maximite 2
MMBasic Version 5.05.06RC14
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "phon_bug.bas"
PLAY TTS PHONETIC "Weh4lkum tuw thah kahlah mae4ksihmay7t tuw"
> run "phon_bug.bas"
Error in line 1: Invalid phonetic text
Edited 2020-11-07 20:35 by thwill
Posted: 11:01am 07 Nov 2020
Check this
and then try
PLAY TTS PHONETIC ucase$("Weh4lkum tuw thah kahlah mae4ksihmay7t tuw")
Posted: 11:31am 07 Nov 2020
  matherp said  Check this
and then try
OK, so it was just a "bug" that let it work using mixed case previously ? I can handle that.
Thanks,
picman100
Posted: 09:30am 09 Nov 2020
  matherp said  V5.05.06RC7 now available for download
Fixed bugs blitting to and from pages in SDRAM to pages in normal memory in 12 and 16-bit modes when x coordinates were odd numbers
Fixed bug in SELECT where the selection was being made on an element of a string array
Large performance improvements for all but the simplest programs
Hi matherp, is the source for this build available?
Thank you
Nick
Posted: 07:40pm 09 Nov 2020
More performance tweaks in V5.05.06RC15
Improved performance of IMAGE RESIZE_FAST
Improved performance of triangles without borders
Improved performance and reduced memory footprint for simple strings with length <=15 or 2D strings with length <=5
e.g.
dim s$ length 15
dim r$(1) length 5
Improved performance of POLYGON command for both triangles and quadrilaterals
improved performance of LINE command for diagonal lines
Use of oversized arrays for parameters for POLYGON and TRIANGLE
In the case of POLYGON the command will read until it finds a ZERO in the number of vertices array
In the case of TRIANGLE the command will read until it finds x1=y1=x2=y2=x3=y3=-1
Automatic case conversion of phonetic strings for PLAY TTS
I've take the liberty of hacking Pete Cotton's ELITE demo to show off the performance and, in particular, the advantages of using the POLYGON command to allow scaling and positioning of a 3D object
' V5.05.06RC15 or above needed to run this demo
mode 1
scale=1
xpos=400
ypos=300
scaleup=0
dim vertex(11,3)   ' Store 11 vertex points of x, y and z co-ordinates
dim nodeCount%=11
dim plane(16,4)   ' Planes are made up of 3 or 4 vertexes
dim drawNodeX(16)  ' Stores the translated X,Y,Z co-ords of each node/vertex
dim drawNodeY(16)
dim drawNodeZ(16)
dim colours(16)
dim blacks(16)
dim polyX(17*3+5)       ' The array we use to store the points of the polygons
dim polyY(17*3+5)
dim PolyC(16)
' Vertex data is stored in 2 dimensional array where the 2nd dimension defines x, y or z
vertex(0,0)=32:vertex(0,1)=0:vertex(0,2)=76
vertex(1,0)=-32:vertex(1,1)=0:vertex(1,2)=76
vertex(2,0)=0:vertex(2,1)=26:vertex(2,2)=24
vertex(3,0)=-120:vertex(3,1)=-3:vertex(3,2)=-8
vertex(4,0)=120:vertex(4,1)=-3:vertex(4,2)=-8
vertex(5,0)=-88:vertex(5,1)=16:vertex(5,2)=-40
vertex(6,0)=88:vertex(6,1)=16:vertex(6,2)=-40
vertex(7,0)=128:vertex(7,1)=-8:vertex(7,2)=-40
vertex(8,0)=-128:vertex(8,1)=-8:vertex(8,2)=-40
vertex(9,0)=0:vertex(9,1)=26:vertex(9,2)=-40
vertex(10,0)=-32:vertex(10,1)=-24:vertex(10,2)=-40
vertex(11,0)=32:vertex(11,1)=-24:vertex(11,2)=-40
plane(0,0)=2:plane(0,1)=1:plane(0,2)=0
plane(1,0)=0:plane(1,1)=1:plane(1,2)=10:plane(1,3)=11
plane(2,0)=6:plane(2,1)=2:plane(2,2)=0
plane(3,0)=0:plane(3,1)=4:plane(3,2)=6
plane(4,0)=7:plane(4,1)=4:plane(4,2)=0:plane(4,3)=11
plane(5,0)=1:plane(5,1)=2:plane(5,2)=5
plane(6,0)=5:plane(6,1)=3:plane(6,2)=1
plane(7,0)=1:plane(7,1)=3:plane(7,2)=8:plane(7,3)=10
plane(8,0)=9:plane(8,1)=5:plane(8,2)=2
plane(9,0)=2:plane(9,1)=6:plane(9,2)=9
plane(10,0)=3:plane(10,1)=5:plane(10,2)=8
plane(11,0)=7:plane(11,1)=6:plane(11,2)=4
plane(12,0)=10:plane(12,1)=8:plane(12,2)=5
plane(13,0)=11:plane(13,1)=7:plane(13,2)=4
plane(14,0)=9:plane(14,1)=10:plane(14,2)=8:plane(14,3)=5
plane(15,0)=9:plane(15,1)=6:plane(15,2)=7:plane(15,3)=11
plane(16,0)=9:plane(16,1)=11:plane(16,2)=10
sub rotate(ax, ay, az)
 snz=sin(az)
 csz=cos(az)
 sny=sin(ay)
 csy=cos(ay)
 snx=sin(ax)
 csx=cos(ax)
 for n=0 to nodeCount%
   x=vertex(n,0)  'x
   y=vertex(n,1)  'y
   ' Rotate around z
   drawNodeX(n)=x*csz-y*snz
   drawNodeY(n)=y*csz+x*snz
   drawNodeZ(n)=vertex(n,2)  'z
   ' Rotate around y
   x=drawNodeX(n)
   z=drawNodeZ(n)
   drawNodeX(n)=x*csy+z*sny
   drawNodeZ(n)=z*csy-x*sny
   ' Rotate around x
   y=drawNodeY(n)
   z=drawNodeZ(n)
   drawNodeY(n)=y*csx-z*snx
   drawNodeZ(n)=z*csx+y*snx
 next n
end sub
anglex=0:angley=0:anglez=0
page write 1
cls
'Main loop
lc=0
do
tts=timer
cls
anglex=anglex-0.00005
angley=angley+0.01
anglez=anglez+0.025
rotate(anglex,angley,anglez)
tt2=timer
PolyPos=0
PolyCount=0
for v=0 to 16
  p1=plane(v,0)
  p2=plane(v,1)
  p3=plane(v,2)
  p4=plane(v,3)
  x1=drawNodeX(p1)
  y1=drawNodeY(p1)
'    z1=drawNodeZ(p1)
  x2=drawNodeX(p2)
  y2=drawNodeY(p2)
'    z2=drawNodeZ(p2)
  x3=drawNodeX(p3)
  y3=drawNodeY(p3)
'    z3=drawNodeZ(p3)
  dx1=x1-x2
  dy1=y1-y2
  dx2=x1-x3
  dy2=y1-y3
'    crossX=y1*z2-z1*y2
'    crossY=z1*x2-x1*z2
  crossZ=dx1*dy2-dy1*dx2
'   norm=sqr(crossx*crossx+crossy*crossy+crossz*crossz)
'   lightLevel=128+ (127*(crossY/norm))
  'dotproduct=x1*x2+y1*y2+drawNodeZ(p1)*drawNodez(p2)
  if crossZ>0 then
    polyx(PolyPos)=x1
    polyy(PolyPos)=y1
    polyx(PolyPos+1)=x2
    polyy(PolyPos+1)=y2
    polyx(PolyPos+2)=x3
    polyy(PolyPos+2)=y3
    PolyPos=PolyPos+3
    colours(PolyCount)=rgb(128+v*5,255,255)
    if p4=0 then
     PolyC(PolyCount)=3
    else   'It's a 4 point plane
     PolyC(PolyCount)=4
     polyx(PolyPos)=drawNodeX(p4)
     polyy(PolyPos)=drawNodeY(p4)
     PolyPos=PolyPos+1
   endif
   PolyCount=PolyCount+1
  endif
next v
polyc(polycount)=0 'mark the end of valid polygons
math scale polyx(),scale,polyx()
math scale polyy(),scale,polyy()
math add polyx(),xpos,polyx()
math add polyy(),ypos,polyy()
polygon PolyC(),polyx(),polyy(),blacks(),colours()
if scaleup then
   xpos=xpos-1
   ypos=ypos+0.5
   scale =scale +0.002
   if xpos=200 then scaleup=0
else
   xpos=xpos+1
   ypos=ypos-0.5
   scale =scale -0.002
   if xpos=600 then scaleup=1
endif
timerTotal=timer-tts
timerRotate=tt2-tts
timerDraw=timer-tt2
fps=fps*0.9+0.1*(1000/timerTotal)
print @(0,0)"FPS: " +str$(fps)
print "Rotate: " + str$(timerRotate) +" ms"
print "Draw: " + str$(timerDraw) + " ms" ,lc
lc=lc+1
page copy 1,0
loop
Edited 2020-11-10 05:55 by matherp
Posted: 08:02pm 09 Nov 2020
  matherp said  Improved performance and reduced memory footprint for simple strings with length <=15 or 2D strings with length <=5
e.g.
dim s$ length 15
dim r$(1) length 5
Sounds good Peter.
Does it involve a change in how they are stored in memory that is going to affect how we can PEEK and POKE them ?
EDIT: or how we use MEMORY COPY on them.
  Quote  Automatic case conversion of phonetic strings for PLAY TTS
Thanks.
Edited 2020-11-10 06:12 by thwill
qwerty823
Posted: 10:24pm 09 Nov 2020
Peter,
Seems like a FILL of -1 causes the TRIANGLE sub to fail. It works if I leave out the fill color.
David
Posted: 11:06pm 09 Nov 2020
  Quote  Seems like a FILL of -1 causes the TRIANGLE sub to fail. It works if I leave out the fill color.
Always has, always will. If you don't want a fill leave the optional parameter off
qwerty823
Posted: 11:21pm 09 Nov 2020
  matherp said  Always has, always will. If you don't want a fill leave the optional parameter off
Strange... the manual says otherwise.
TRIANGLE X1, Y1, X2, Y2, X3, Y3 [, C [, FILL]]
Draws a triangle on the VGA monitor with the corners at X1, Y1 and X2, Y2 and X3, Y3.  'C' is the colour of the triangle and defaults to the current foreground colour.  'FILL' is the fill colour and defaults to no fill (it can also be set to -1 for no fill).  All parameters can be expressed as arrays and the software will plot the number of triangles as determined by the dimensions of the smallest array. 'x1', 'y1', 'x2', 'y2', 'x3',and 'y3' must all be arrays or all be single variables /constants otherwise an error will be generated 'c'  and 'fill' can be either arrays or single variables/constants.
PeteCotton
Posted: 01:14am 10 Nov 2020
  matherp said  More performance tweaks in V5.05.06RC15
Very cool! Thanks!
I should also note that it gave a significant speed boost to the code I wrote for the Octohedron challenge. I know the rules state RC14, but with RC15 it went from 1525ms to 1304ms (it looks like the Triangle draw speed area of the code that is boosted). Great work as always Peter! Thanks!
LeoNicolas
Posted: 03:22am 10 Nov 2020
@matherp This new version is promising... many performance updates being delivered in one version.
I'm still using the R14 due to the challenge constraints. Will you update the challenge requirements to accept the R15?
Posted: 11:18am 10 Nov 2020
Repost in case it was missed:
e.g.
dim s$ length 15
dim r$(1) length 5
Does this involve a change in how they are stored in memory that is going to affect how we can PEEK, POKE or use MEMORY COPY on them ?
Posted: 12:09pm 10 Nov 2020
  Quote  Does this involve a change in how they are stored in memory that is going to affect how we can PEEK, POKE or use MEMORY COPY on them ?
Shouldn't do - zmim works fine and even a bit faster. The one no-no is trying to change the length byte in the header to more than 15 but that is true of strings now (255 in their case)
  Quote  Will you update the challenge requirements to accept the R15?
Yes, since the objective is to go as fast as possible
  Quote  Strange... the manual says otherwise.
Manual doesn't match the code, will amend one or the other
Edited 2020-11-10 22:10 by matherp
Posted: 12:18pm 10 Nov 2020
Thanks Peter. It wasn't Z-MIM I was concerned about, that doesn't really doing anything too funky because it was written to run on the CMM1 too (I hope to create a CMM2 specific version eventually to take advantage of your recent firmware enhancements, but it isn't near the top of my stack at the moment). My concerns were regarding any impact on the data-structure/lexer/parser tooling I'm working on currently ... currently all my unit-tests are passing with RC15 though, so looking good.
Posted: 04:46pm 10 Nov 2020
Esoteric bug in RC 15 (and probably earlier), I suspect you'll say isn't worth fixing given it involves messing with ON ERROR:
Colour Maximite 2
MMBasic Version 5.05.06RC15
> list "bug.bas"
Option Explicit On
Option Default None
foo()
Sub foo()
 Local x%
 Print "Before" x%
 bar()
 Print "After" x%
Sub bar()
 On Error Ignore
 do_nothing(1)
 On Error Abort
Sub do_nothing(z)
> run "bug.bas"
Before 0
After
Error in line 10: X is not declared
The not immediately obvious solution is to provide a type for 'z'.
Edited 2020-11-11 02:47 by thwill
Posted: 07:43pm 10 Nov 2020
Perspective transforms in V5.05.06RC16
mode 1,16
load jpg "image2"
image warp_h 0,0,400,385, 400,0,385, 600,85,385-170
image warp_v 0,0,400,385,  0,385,400,  100,385*1.5,200
do:loop
The new commands are:
IMAGE WARP_H x, y, w, h, x1, y1, h1, x2, y2, h2 [,readpage] [,dontcopyblack]
IMAGE WARP_V x, y, w, h, x1, y1, w1, x2, y2, w2 [,readpage] [,dontcopyblack]
x, y, w, h defined the top left coordinates and the width and height to read from the current write page or optional read page
In both cases x1 and x1 define the top left corner of the area to write
In both cases x2 and y2 define the top right corner of the area to write
When warping horizontally h1 and h2 define the height of the transformed area at the left edge and right edge
When warping vertically w1 and w2 define the width of the transformed area at the top edge and bottom edge
Enjoy
  Quote  I suspect you'll say isn't worth fixing
Correct
Edited 2020-11-11 05:43 by matherp
LeoNicolas
Posted: 08:26pm 10 Nov 2020
Mauro Xavier will love this new feature
  matherp said  Perspective transforms in V5.05.06RC16
Peter, after installing the RC15 in my CMM2 the rotation octahedron time drop down from 1540 ms to 1085 ms. This is absolutely amazing
Thank you for your hard work.
     Page 3 of 4
