Local Time 16:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Continuation from cog31s GPS issue.
     Page 3 of 3
goc30
Posted: 05:17pm 13 Oct 2019
I have just found a strange phenomenon. In my task called every 10 ms, I print the time between two calls when it exceeds 11ms.
the code is the following
  if ptime2> 11 then
    print "time between 2 tick of 10ms:"; str $ ((ptime2) / 1000,4,3)
  end if
it give that
Run
time between 2 tick of 10ms:   0.013
error i1=0  nbcar:15
time between 2 tick of 10ms:   0.012
error i1=0  nbcar:25
time between 2 tick of 10ms:   0.014
error i1=0  nbcar:16
error i1=0  nbcar:82
In addition I also print a messgae if the iterruption on the UART is done while there are no characters "if loc (#n) = 0"
in which case I get this
if in my timeout message (in the task called all s10ms), I add some spaces, I no longer get error "loc (#n) = 0"
the code is as follows:
if ptime2> 11 then
    print "   time between 2 tick of 10ms:"; str $ ((ptime2) / 1000,4,3)
  end if
it give that
Run
  time between 2 tick of 10ms: 323.989
Edited 2019-10-14 03:17 by goc30
Posted: 07:20pm 13 Oct 2019
  goc30 said
  JohnS said
I think that error means something is wrong.
Are you perhaps, due to going around your FOR loop, removing an extra character which has flagged an interrupt?  I suspect so, i.e. by having the loop you then cause the error.
uart interrupt is send when one (minimum) char is in buffer. if I receive interrupt and "loc(#n)" say there is no char, this is wrong!!
where is FOR loop ??
You used to have a FOR loop.  Instead, you now remove as many chars as Loc(#2) says, but it comes to the same thing.
Are you getting an interrupt per char and expected to remove one char only?  Perhaps.  If so, when you remove more than one char you will in due course get interrupt(s) with no chars - it certainly fits what you see and I don't see any alternative suggested by anyone.
If it were me I'd read the mmbasic internal C code to see what it does exactly.
     Page 3 of 3
