Local Time 19:53 04 Nov 2026 Privacy Policy
Forum Index : Electronics : $10 Inverter Scope
     Page 3 of 3
mackoffgrid
Posted: 06:23am 13 Mar 2019
I haven't yet, I've been waiting to add it to another order too save $$ but I've been bogged down. I'll try and sort it out soon
davef
Posted: 08:24am 13 Mar 2019
No problem.
Cheers,
Dave
mackoffgrid
Posted: 06:52am 19 Mar 2019
Hi Dave, Ordered all my pcb's today. Overall its AUD$86 for 45 pcbs of different flavours So thats comes to $1.90 a piece, if you are interested.
I'll probably have them inside a week.
Gerber Files I sent for manufacture https://github.com/mackelec/Power_Scope
AndrewEdited by mackoffgrid 2019-03-20
davef
Posted: 07:34am 19 Mar 2019
Hi Andrew,
Sent you a PM.
Dave
mackoffgrid
Posted: 08:18am 31 Mar 2019
For anyone thinking of buying a stm32 "BluePill" board I would could consider this product.
robotDyn BluePill
I haven't bought one yet, but the referrals from this sources has impressed me.
stm32duino - robotDyn Bluepill topic
I had to repair my first and only BluePill. I have ordered another from Aliexpress before I found this.
BTW, the two product are the same hardware, the more expensive one has the USB boot loader done for you. And go for the UN soldered pin headers - they're no trouble.
Hope this helps
Andrew
mackoffgrid
Posted: 09:48pm 13 Apr 2019
Guys
Don't use R1 on 2019-Feb version PCB. It has the USB line PA12 pulled up to 5v where it should be pulled up to 3.3volts. My error was to follow the error on the BluePill schematic.
The USB mod to the bluePill (which is fixed on the robotDyn boards I believe)
is to either change R10 (smd) on the Bluepill to 1k5 OR add a 1k8 on top of the BluePill
davef
Posted: 06:23am 14 Apr 2019
Thanks for the heads-up, still waiting for connectors.
Dave
mackoffgrid
Posted: 01:20pm 20 Apr 2019
When I first started using the BluePill, not that long ago, I found that getting all the info together was slow, or out-dated or just confused between the different cores available.
I did a quick how-to. Blue Pill setup Wiki
Andrew
LadyN
Posted: 08:03pm 22 Apr 2019
I received 2x BluePill from the Sincere Company Store on Ali and both boards have the correct 1.5k USB pullup to 3v3, so I don't believe a mod will be needed? Have not flashed it yet
However, I have a question:
If I connect an external 3v3 power source to the 3v3 pin on the board while making sure neither the 5V pin nor the USB port was connected, could I end up damaging the board anyways (or perhaps the LDO)?
I ask because the tiny 3v3 LDO on board looks underspecified and it would be easier for me to power this board over 3v3 than 5v
If desoldering out the tiny 3v3 LDO on board would help, I can do that, but I dont prefer it as it might make programming the STM32 over USB/HID difficult
I can ask this question on a different thread since it's not directly relevant to this project
mackoffgrid
Posted: 09:28pm 22 Apr 2019
The 3v3 reg will be fine. For the purposes of programming the Boot Loader you can power it from either 3v3 or 5v.
FYI, if you are powering it from the USB, just omit the 5v/3.3v when connecting up the USB-Serial adapter.
davef
Posted: 07:44pm 13 May 2019
Could you suggest which project (.ino) would be a good starting point?
Thanks,
DaveEdited by davef 2019-05-15
mackoffgrid
Posted: 09:46pm 13 May 2019
Hi Dave
I need to get back to this project, I was waiting for parts for current sensing etc.
The latest version is on GitHub, InverterScope_ILI9486.
Libraries
I did try one of these but I found it to be very noisy compared to a plugpack transformer. Couldn't sync very well at all.
I want to try just the 2mA transformer without the active parts.
Andrew
LadyN
Posted: 09:48pm 13 May 2019
nvmEdited by LadyN 2019-05-15
mackoffgrid
Posted: 09:24am 14 May 2019
Correction to that link.
The github link is Inverter Scope GitHub
Andrew
davef
Posted: 09:53am 14 May 2019
Hi Andrew,
Which board has the ILI9486 on it? The boards I got say:
spfd5408 controller with built in video RAM buffer
Thanks,
mackoffgrid
Posted: 11:25am 14 May 2019
The 3.5" MCUfriend LCD has that driver. The Library by David Prentice should work with both. His repository is david prentice Github. I modified his library to work with my pin selections.
GenetrySolar
Posted: 10:44pm 18 Jul 2019
Hi Mack,
I would be interested in integrating this into a line of Power Jack inverters. Possibly for mass production. I would like to discuss some more details with you if possible.
Thank you very much
mackoffgrid
Posted: 11:03pm 18 Jul 2019
No worries GS
Its all there on Github - I am behind on finishing off the software. I have no problems with you guys freely using any or all of the work I've done. Just give back to the community
I am happy to help in any way I can.
AndrewEdited by mackoffgrid 2019-07-20
kentfielddude
Posted: 05:56pm 19 Jul 2019
mackoffgrid is the hardware complete? Will you be making any changes?
mackoffgrid
Posted: 08:39pm 19 Jul 2019
The hardware is complete (so far )
Like all things, my bare bones hardware may warrant changes to suit other circumstances.
The analogue input is basic, transformers and current sensors are all off board.
Andrew
     Page 3 of 3
