Forum Index : Microcontroller and PC projects : Com Port Problems
Thanks Message me if thats easier Lew |
| Azure Guru Joined: 09/11/2017 Location: AustraliaPosts: 446 |
Here it is changed a little. It had a typo in the open command (closing quote in wrong place). OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "" 'Serial 2 ESP8266 input string Dim EspLine% = 0 'Serial 2 ESP8266 line received flag Dim Count% = 0 'Counter to put stuff on screen Open "COM2:9600, 1024, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do ' *** Check Serial Ports for Data *** If EspLine% = 1 Then 'Complete ESP line received Print 'Start new line after printing waiting **** Count% = 0 'Reset count to start waiting message again Print Esp$ 'Print line to check it 'Add processing for line received here Esp$ = "" 'Clear line ready for next one to come in EspLine% = 0 'Clear line received flag so we can get next line Else 'Just print something to show we are running If Count% = 0 Then Print "Waiting: " ; Count% = 1 Print "z" ; 'Print z to keep it short on same line Pause 500 'Might cause issues with serial port buffering End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 10 If EspLine = 0 Then 'Dont get more if previous line not handled T$ = Input$(1,#2) 'Get data into temp buffer Print "ESP char: " T$ " Received" 'Just to check for other unwanted chars Select Case T$ Case "*" EspLine% = 1 'Set flag to say we have finished this line Else Esp$ = Esp$ + T$ 'Add new char to ESP input string End Select End If End Sub End |
If I comment out the "If EspLine = 0 Then" in the SUB it works However it's printing every character that comes into the com port on a new line with the work "Received" after the character an example of part of what's received [quote]ESP char: , Received ESP char: 9 Received ESP char: 8 Received ESP char: , Received ESP char: 2 Received ESP char: , Received ESP char: 2 Received ESP char: 9 Received ESP char: 2 Received ESP char: , Received ESP char: * Received[/quote] |
Seems to be a problem with the string and select case. Works with If Then and since end char is "*" it will work. Might need to consider what it would do if string gets corrupted somehow during tx. This code works for me. Error you mentioned was variable missing it's %. OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "" 'Serial 2 ESP8266 input string Dim EspLine% = 0 'Serial 2 ESP8266 line received flag Dim Count% = 0 'Counter to put stuff on screen Open "COM2:9600, 1024, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do ' *** Check Serial Ports for Data *** If EspLine% = 1 Then 'Complete ESP line received Print 'Start new line after printing waiting **** Count% = 0 'Reset count to start waiting message again Print Esp$ 'Print line to check it 'Add processing for line received here Esp$ = "" 'Clear line ready for next one to come in EspLine% = 0 'Clear line received flag so we can get next line Else 'Just print something to show we are running If Count% = 0 Then Print "Waiting: " ; Count% = 1 Print "z" ; 'Print z to keep it short on same line Pause 500 'Might cause issues with serial port buffering End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 10 If EspLine% = 0 Then 'Dont get more if previous line not handled T$ = Input$(1,#2) 'Get data into temp buffer If T$ = "*" Then EspLine% = 1 'Set flag to say we have finished this line Else Esp$ = Esp$ + T$ 'Add new char to ESP input string End If End If End Sub End |
It's getting close, I had to modify it slightly to get it to run [code]OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "" 'Serial 2 ESP8266 input string Dim EspLine = 0 'Serial 2 ESP8266 line received flag Dim Count = 0 'Counter to put stuff on screen Open "COM2:9600, 1024, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do ' *** Check Serial Ports for Data *** If EspLine = 1 Then 'Complete ESP line received Print "GOT TO HERE" 'Start new line after printing waiting **** Count = 0 'Reset count to start waiting message again Print Esp$ 'Print line to check it 'Add processing for line received here Esp$ = "" 'Clear line ready for next one to come in EspLine = 0 'Clear line received flag so we can get next line Else 'Just print something to show we are running If Count = 0 Then Print "Waiting: " ; Count = 1 Print "z" ; 'Print z to keep it short on same line Pause 500 'Might cause issues with serial port buffering End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 10 If EspLine = 0 Then 'Dont get more if previous line not handled T$ = Input$(1,#2) 'Get data into temp buffer If T$ = "*" Then EspLine = 1 'Set flag to say we have finished this line Else Esp$ = Esp$ + T$ 'Add new char to ESP input string End If End If PRINT T$; " T$ TEST " End Sub End[/code] The only problem is it never comes out of the ESPIsr SUB, it keeps printing "" T$ TEST " in a never ending loop |
It ran on my unit, so not sure what stopped it working in the changes made. Change: If Count = 0 Then Print "Waiting: " ; To: If Count = 0 Then Print "Waiting: " ; If then is structured incorrectly, print should be on next line as part of the multiline "If Then" Can't see why it is stuck in isr if that doesn't help. *Edit: It seems like it has received a line, expand that isr print to be: PRINT T$; " T$ TEST "; EspLine It should print 0 if it is still building up a line and 1 when it has found *. |
I wonder if it's because the ESP is transmitting every 15 seconds? With the mod's you suggested it's stuck in a loop printing [code] T$ TEST 1 T$ TEST 1[/code] continuously |
Deleted as it had errors |
I'm just going to give up on the whole thing, I can't get com2 working properly no matter what I try Thanks everyone who tried to help with this |
I have not followed this thread in detail but it seems to involve strings and subs. In this case this known bug might be relevant: This will be fixed in the next release. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff Basically what I was trying to do is receive data in COM2 then parse that data and a function to tell when the data was received and then another function to parse the data I can get it working on COM1 perfectly, but when I try and replicate it on COM 2 (different data) it just won't work |
you just posted a good thought. just to eliminate things have you tried using different com ports on the mm for talking to the esp? Sorry busy with other stuff at the moment. I will do some tests next week as that code should work. I need to setup a second machine to simulate the esp data streams you posted while my main development notebook machine (which has only 1 USB port) is the console interface and I don't have time for that for a few days. |
So I am prepared when I get to play with this issue, can you just explain how the esp8266 is sending data. Is it a line (day at a time) up to the end of line "*" character then in 15 seconds it does the next days forecast and so on, or is it all days together one day directly after the other repeated every 15 seconds? |
This is exactly what it's transmitting - one line at a time, getting the data for the tomorrow and transmitting it, getting the data for Day 2 and transmitting it and finally getting the data for Day 2 and transmitting it then repeating this every 15 seconds 15 seconds for test purposes, this will be a lot longer delay "eventually" [quote]STX1,broken clouds,04n,* STX2,scattered clouds,03d,Fri Dec 01 11:00:00 2017 ,-0.76,3.91,1024.77,87,4,4,* STX3,light rain,10d,Sat Dec 02 11:00:00 2017 ,2.08,7.43,1025.56,97,3,307,* STX4,light rain,10d,Sun Dec 03 11:00:00 2017 ,4.83,8.5,1027.69,98,3,317,*[/quote] EDITED: I've changed the ESP output so it has the same info in the first 3 sections STX1 = todays data STX2 = tomorrows and so on This "SHOULD" make it easier to parse, if I ever go back to trying to get COM2 working properly |
When I'm not sure if something is getting to all the right places, I often add a line, [code]Print Crash or just ? cc[/code] As Crash or cc is an undefined variable when OPTION EXPLICIT is used, it works as a simple test to see it the code has got to a line in question. At times I've also done a similar thing with the Trace on, which will allow you to see previous lines that were executed & looped thru. Bit of a primitive debugging technique, but useful at times. Phil. |
I "THINK" I might be getting somewhere This is working at the moment, I just have to incorporate it into the main program and parse the sentences but I'll try that tomorrow after I get up [code]Open "COM2:9600" As #2 Do Do BT$=Input$(1,#2) If By$=Chr$(10) Then BT$="" 'Get rid of a LineFeed (LF)! If BT$=Chr$(42) Then Exit '"*" to signify end of message line MSG$=MSG$+BT$ Loop MSG1$ = MSG$ MSG$="" print MSG1$,"COM2 Message String" Loop[/code] |
I've spent that past 8 hours trying to get the above code incorporated into my existing program It will work BUT it will stop the clock for 4 seconds every time it gets data Is there a way to incorporate this into an existing program without this DO loop? I think this is why it's taking so long to run and move on The original program already has a DO/LOOP and this 2nd one I "think" is making it pause [code]Open "COM2:9600" As #2 DO BT$=Input$(1,#2) If By$=Chr$(10) Then BT$="" 'Get rid of a LineFeed (LF)! If BT$=Chr$(42) Then Exit '"*" to signify end of message line MSG$=MSG$+BT$ Loop MSG1$ = MSG$ MSG$="" print MSG1$[/code] On the plus side, I found out why COM2 is double printing everything, it was a bug in the ESP8266 program, it was sending the data twice, that's corrected now so it's only sending once |
I am away this weekend so cannot play with hardware. My preference would be (still) to get it running in the background using an ISR. I have written a simpler ISR below that the main code can easily check when the line has arrived. If that works it can be built up to do more (and remove and unwanted characters). OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "" 'Serial 2 ESP8266 input string Dim Count% = 0 'Counter just for something in main loop Open "COM2:9600,, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do For Count% = 1 to 100 'Do something in main loop Next If Esp$ <> "" Then 'Check if line of ESP data has arrived Print Esp$ Esp$ = "" End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 10 Local ESPT$ T$ = Input$(1,#2) 'Get data into temp buffer If T$ = "*" Then ESP$ = ESPT$ 'Save string to global now that it is complete Else EspT$ = EspT$ + T$ 'Add new char to ESP Temp input string End If End Sub |
I couldn't get it working If you look at the print statements I added both print statements in the interrupt sub print out the following 111 with nothing printed before it each character received from the com port followed by,222 The "print command" never gets printed [code]OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "" 'Serial 2 ESP8266 input string Dim Count% = 0 'Counter just for something in main loop Open "COM2:9600,, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do For Count% = 1 to 100 'Do something in main loop Next If Esp$ <> "" Then 'Check if line of ESP data has arrived Print Esp$, "Print command" Esp$ = "" End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 200 Local ESPT$ T$ = Input$(1,#2) 'Get data into temp buffer If T$ = "*" Then ESP$ = ESPT$ 'Save string to global now that it is complete print EspT$,"111" Else EspT$ = EspT$ + T$ 'Add new char to ESP Temp input string print EspT$, "222" End If End Sub[/code] |
I managed to run a doctored version (cheating input) The problem was that the EspT$ is being recreated each time it is not static. This caused it only ever to be the last character. I changed it to global, that should fix things, also needed to clear temp string once line completed. Here it is modified: OPTION AUTORUN ON 'Autorun upon power up (after first run) option explicit Dim Esp$ = "", EspT$ = "" 'Serial 2 ESP8266 input string Dim Count% = 0 'Counter just for something in main loop Open "COM2:9600,, EspIsr" As #2 'Open port for ESP8266 ' *** Start of Main Program *** Do For Count% = 1 to 100 'Do something in main loop Next If Esp$ <> "" Then 'Check if line of ESP data has arrived Print Esp$, "Print command" Esp$ = "" End If Loop ' *** COM 2 Input *** Sub EspIsr ' serial port 2 ESP8266 interrupt handler Local T$ length 200 T$ = Input$(1,#2) 'Get data into temp buffer If T$ = "*" Then Esp$ = EspT$ 'Save string to global now that it is complete EspT$ = "" 'Clear ESP Temp string for next line ' print EspT$,"111" Else EspT$ = EspT$ + T$ 'Add new char to ESP Temp input string ' print EspT$, "222" End If End Sub Edit: missed $ sign in first post |
