Local Time 02:09 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic V6.03.00 release candidates
     Page 29 of 31
Frank N. Furter
Posted: 11:38am 23 Jun 2026
The battery is fully charged right now, and the behavior remains the same: The PicoCalc only starts up sporadically.
However, the PicoCalc starts up immediately when connected via the micro-USB cable. As soon as I plug it in, the heartbeat starts, and when I press the power button, I see the normal startup screen.
Frank
Posted: 11:49am 23 Jun 2026
Does the PicoCalc run without batteries with just the USB-C cable connected? If so try that. I suspect you are seeing some sort of brown-out during boot presumably caused by some trivial timing change caused by different caching on the RC23/24 builds
Frank N. Furter
Posted: 11:58am 23 Jun 2026
Just tried it: It behaves the same way as with the battery. The PicoCalc only starts up occasionally.
Posted: 12:09pm 23 Jun 2026
  Quote  As soon as I plug it in, the heartbeat starts, and when I press the power button, I see the normal startup screen.
The plugged in USB is isolating the Pico from the main PicoCalc power giving the Pico lots or time to startup properly
Try this and see if makes any difference. I've increased the time before the Pico increases its cpu speed
PicoMite.zip
Frank N. Furter
Posted: 12:14pm 23 Jun 2026
Unfortunately, no change!
Posted: 12:15pm 23 Jun 2026
For completeness can you try a different Pico2 module ?
Frank N. Furter
Posted: 12:16pm 23 Jun 2026
Unfortunately, I don't have any available right now.
Oh yeah, the PicoCalc wasn't recognized as such again:
option list
PicoMite MMBasic RP2350A V6.03.00RC24
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
> [?7h
Only after an OPTION RESET...
Frank
Edited 2026-06-23 22:22 by Frank N. Furter
Posted: 12:26pm 23 Jun 2026
I've spoken to my friend who lent me the PicoCalc when I did the integration. He has installed RC24 on a genuine Pico2 in his PicoCalc and it is running with no issue at all. The one difference that may be relevant is that starting with RC23 I changed the build to enable the single precision H/W floating point in the RP2350 builds. This is then used for a number of internal calcs that speed up some user commands. It may be that  combination of your PicoCalc electrics and that Pico2 module are somehow causing problems. The next step must be to try a different Pico2, in the meantime you will have to stick with RC22. Sorry I can't help further.
Frank N. Furter
Posted: 12:36pm 23 Jun 2026
Thank you for your efforts!
Frank
homa
Posted: 10:45pm 23 Jun 2026
Frank,
What version of the BIOS is on the PicoCalc?
I'm running the latest version, 1.6, and it works fine with rc22.
Matthias
Posted: 07:14am 24 Jun 2026
  Quote  and it works fine with rc22.
Frank's works with RC22, is yours OK with RC24?
toml_12953
Posted: 11:22am 24 Jun 2026
  homa said  Frank,
Matthias
I have 1.6 as well and it works fine with RC24, too.
homa
Posted: 04:39pm 24 Jun 2026
Updated to rc24 with a pico2 in PicoCalc and it’s working! Even with the library!
Every start-up works straight away and outputs the information from mm.startup
Frank N. Furter
Posted: 05:12pm 24 Jun 2026
@homa, @toml_12953:
Did you really install a Pico2 with an RP2350? Not the Wi-Fi version???
Actually, I think I still have BIOS version 1.5 on the board - do you have a link to instructions on how to update it?
Frank
Posted: 05:41pm 24 Jun 2026
Frank, I can absolutely guarantee that RC24 will work reliably on a standard Pico2 with BIOS 1.5. My friend has reinstalled and retested for me. This is why I need you to try a different module. The change from 22 to 23 was enabling the RP2350 singler precision FPU. My suspicion is that the FPU on your module may be giving problems and not starting up properly when the power-up is via the PicoCalc circuitry rather than direct on the Pico itself. I can't see any other explanation and I have extended boot timings to try and overcome it but to no avail.
Frank N. Furter
Posted: 07:07pm 24 Jun 2026
Okay, I'll see if I can find another Pico2 in my stash this weekend...
Frank
toml_12953
Posted: 07:21pm 24 Jun 2026
  Frank N. Furter said  @homa, @toml_12953:
Frank
I have a Pimoroni Pico 2W Plus in my two PicoCalcs. I use the Web version of the interpreter.
homa
Posted: 03:54pm 25 Jun 2026
There seems to be a minor glitch with rc24 that’s new – at least, I hadn’t noticed it before. When switching off, if I don’t hold the button down long enough, an ‘f’ appears in the command line. In other words, a quick press of the on/off button always results in the letter ‘f’ appearing, as if it had been typed on keyboard. If I hold the button down, the PicoCalc switches off properly.
homa
Posted: 04:00pm 25 Jun 2026
Frank
Hi Frank, here are the instructions in German: https://www.boardprojects.com/bios-keyboard-firmware-update-auf-dem-clockwork-picocalc/
And yes, at the moment I’m only using the pico2 without Wi-Fi.
Matthias
Posted: 04:44pm 25 Jun 2026
V6.03.00RC25
PicoMiteRP2040V6.03.00RC25.zip
PicoMiteRP2350V6.03.00RC25a.zip
PicoMiteRP2350V6.03.00RC25b.zip
PicoMite_User_Manual.pdf
Fixes a couple of bugs in WEB processing and increases TLS buffer to cater for sites like microsoft.com that use extra long encryption keys
Support of OV2640 camera on RP2350 builds except VGA and HDMIWEB
Minor enhancement to the LOAD JPG command to allow images to be downscaled to making reviewing easier, new scale parameter
New command WEB TCP CLIENT WRITE data%() [,timeout]
See manual for details of the new commands
Example program for sending an email with a picture attached using the new command. Use the new OV2640 camera commands to take a jpeg picture and then email it.
Sub MailSend
 Const cr = Chr$(13)+Chr$(10)
 Local integer b(512), buf(1100)
 Local integer fnbr, fsize, k
 Local String txt, h$, enc$, chunk$
 Local string EmailFrom="MyEmailAddress"
 Local string EmailTo="YourEmailAddress"
 Local string smtpuser = "MyUsername"
 Local string smtppass = "MyPassword"
 Local string bd = "=_picomite_boundary_="
 Local string fname = "A:/test.jpg"
 txt = "Test email"
 ErrEmail = true : FaultDetected = true
 If Dir$(fname, File) = "" Then Print "Attachment not found: " + fname : Exit Sub
 On Error Skip
 WEB OPEN TLS CLIENT "mail.smtp2go.com", 8465
 If MM.Errno <> 0 Then Print "Connect failed" : Exit Sub
' wait for the 220 greeting BEFORE talking (not an early talker)
' uncomment if using WEB OPEN TCP CLIENT
'  WEB TCP CLIENT READ b(), 30000
'  If Not WaitCode(b(), "220") Then GoTo bail
 WEB TCP CLIENT REQUEST "EHLO picomite" + cr, b()
 If Not WaitCode(b(), "250") Then GoTo bail
 WEB TCP CLIENT REQUEST "AUTH LOGIN" + cr, b()
 If Not WaitCode(b(), "334") Then GoTo bail
 WEB TCP CLIENT REQUEST base64Encode(smtpuser) + cr, b()
 WEB TCP CLIENT REQUEST base64Encode(smtppass) + cr, b()
 If Not WaitCode(b(), "235") Then GoTo bail
 WEB TCP CLIENT REQUEST "MAIL FROM:<" + EmailFrom + ">" + cr, b()
 WEB TCP CLIENT REQUEST "RCPT TO:<" + EmailTo + ">" + cr, b()
 WEB TCP CLIENT REQUEST "DATA" + cr, b()
 If Not WaitCode(b(), "354") Then GoTo bail
 ' ===== build the DATA body in buf() and stream it with WRITE =====
 LongString Clear buf()
 h$ =       "From: " + EmailFrom + cr
 h$ = h$ +  "To: " + EmailTo + cr
 h$ = h$ +  "Subject: My subject" + cr
 h$ = h$ +  "MIME-Version: 1.0" + cr
 h$ = h$ +  "Content-Type: multipart/mixed; boundary=" + Chr$(34) + bd + Chr$(34) + cr + cr
 h$ = h$ +  "--" + bd + cr
 h$ = h$ +  "Content-Type: text/plain; charset=us-ascii" + cr + cr
 LongString Append buf(), h$
 LongString Append buf(), txt + cr
 h$ =       "--" + bd + cr
 h$ = h$ +  "Content-Type: image/jpeg; name=" + Chr$(34) + "test.jpg" + Chr$(34) + cr
 h$ = h$ +  "Content-Transfer-Encoding: base64" + cr
 h$ = h$ +  "Content-Disposition: attachment; filename=" + Chr$(34) + "test.jpg" + Chr$(34) + cr + cr
 fnbr = 1
 Open fname For Input As #fnbr
 fsize = Lof(#fnbr)
 Do While fsize > 0
   k = MIN(189, fsize)
   chunk$ = Input$(k, #fnbr)
   enc$ = base64Encode(chunk$)
   If LLen(buf()) + Len(enc$) + 2 > 8700 Then
     WEB TCP CLIENT WRITE buf()
   EndIf
   LongString Append buf(), enc$ + cr
   fsize = fsize - k
 Close #fnbr
 LongString Append buf(), "--" + bd + "--" + cr
 WEB TCP CLIENT REQUEST "." + cr, b()
 If WaitCode(b(), "250") Then
   ErrEmail = false : FaultDetected = false
   Print "Email sent with attachment"
 Else
   Print "Send not confirmed"
 EndIf
 WEB TCP CLIENT REQUEST "QUIT" + cr, b()
bail:
 WEB CLOSE TCP CLIENT
Function WaitCode(b() As integer, code As string) As integer
 WaitCode = (LInStr(b(), code) > 0)
End Function
Function base64Encode(si As string) As string
 Local integer iiii = Math(base64 encode si, base64Encode)
End Function
Example program using the new camera commands
Option explicit
Option default none
Dim float ch
Dim imag%(320*240\8-1)
Dim s$
If Instr(MM.DEVICE$,"HDMI") Then Mode 4
Drive "b:"
Camera open ov2640 gp20,gp21,gp22,gp26,gp27,gp0
Camera change imag%(),ch' initialise the change image
  Camera change imag%(),ch,1
Loop Until ch>10
s$="Movement"
Inc s$, LEFT$(Date$,2)+Mid$(Date$,4,2)+RIGHT$(Date$,2)
Inc s$," "+LEFT$(Time$,2)+Mid$(Time$,4,2)+RIGHT$(Time$,2)+".jpg"
Camera capture jpeg s$,sxga
Load jpg s$,,,,,4
Pause 2000
Edited 2026-06-26 03:11 by matherp
     Page 29 of 31
