Local Time 11:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta Testers Wanted
     Page 25 of 26
Posted: 01:36am 28 Mar 2014
Hi kermess,
Welcome on board - good to see someone from Spain on here!
Hopefully Geoff will see your post and he will send you the necessary info. It is not really correct for anyone else to send you the Hex file or documentation.
Therefore I will drop Geoff a quick line to see if he is ok to send you the Hex file & manual.
We are currently on Beta 16.
Hope to speak soon . . .
Regard,
Phil
Posted: 02:05am 28 Mar 2014
  kermess said   Good morning.
I would like to participate in the beta testers.
I have a programmer PICKIT3 and several pieces of PIC32MX150F128B.
It is possible that I can provide sufficient documentation and software to get started.
And thank you very much.
David PM
Hi David, you need to send me an email with this request and I will send you everything. My address is below.
Posted: 01:23pm 28 Mar 2014
...and THE thread lives on.........
41 pages - I challenge any member to beat this one of Geoff's!!!
Posted: 01:32pm 28 Mar 2014
Hey everyone, Grogster is putting up a $10,000 prize for anyone meeting his challenge!! See previous post
Posted: 01:39pm 28 Mar 2014
Grogs,
WhiteWizards Solder method might pip it..
Damn.... I just added length to this one
Posted: 04:51pm 28 Mar 2014
A challenge ain't a bet.
Lou
Posted: 05:52am 29 Mar 2014
10 grand !! .....I could get a bigger tractor !! Where do I sign up?? Thanks Grogs.
Lou
ztoti
Posted: 12:36pm 29 Mar 2014
Hi All,
I have Micromite ver4.5b15 (44 pin Pic) and I have problem with definition of my own functions, there is simple one:
function square(a)
square = a*a
end function
print square(3)
result:
Error: Array must be dimensioned first
Any help?
Posted: 02:04pm 29 Mar 2014
Hi ztoti,
I have just run this on my 44-pin MicroMite (Beta 16) and no problem - it works 100%
This should also work in Beta 15 as Geoff only made an IR code change between the two versions.
Try typing NEW and enter in the following:
? square(3)
end
function square(a)
square = a*a
end function
Update us with your outcome!
Posted: 02:11pm 29 Mar 2014
ztoti,
I just managed to recreate the error BUT only when I make a typo error.
So please check that the spelling of your function name matches with the function name used in your code. Any difference and the code will give the 'array' error.
Phil
jman
Posted: 03:14pm 29 Mar 2014
  ztoti said   Hi All,
print square(3)
result:
Any help?
So why are you using square(3) ?
Square(3) this would need to be the forth element of an array
Why not just Print Square ?
Jman
Posted: 03:27pm 29 Mar 2014
Hi jman,
If you look a little more at what ztoti is doing, he is trying to write a function; (otherwise you are correct in what you say).
I believe he has made a typo error i.e. not using identical spellings, and hence MMBasic is thinking he wants an array element returned and hence he gets the message he is seeing.
Are you able to try his code that he posted above on your MicroMite? If so please let us know if it worked for you (he is trying to print Square(3) to return '9')
WW
jman
Posted: 04:09pm 29 Mar 2014
Hi WW
Yip I see that now
I tried on my Micromite and I get the same result yet this works
SA(3)
Print Sa
SUB Square(a)
Sa=a*a
Jman
Posted: 04:16pm 29 Mar 2014
The problem seems to be that a function cannot be declared on the first line of a program.
Cut and pasted to a new program this failed:
function square(a)
square = a*a
end function
print square(3)
But this worked:
function square(a)
square = a*a
end function
print square(3)
The only difference is the blank line at the start of the second code snippet.
I used MMEdit to test the code but after the second code worked I used the inbuilt editor to delete the first line. The code then failed again.
I think it can be called a bug.
Tested with beta 15
Posted: 04:25pm 29 Mar 2014
Isn't it "Normal" coding practise, to declare subs, interrupts and functions at the END of the listing, not at the top?
I tend to layout my code these days as:
Constants, strings, arrays, tick timers
MAIN CODE LISTING
Subs, Interrupts, Gosubs, Functions
But that is just me.
jman
Posted: 04:33pm 29 Mar 2014
Hi Jim
Yip you are on the money Function does not like to be the first line
Tested with Beta 16
Jman
Posted: 04:37pm 29 Mar 2014
  Grogster said   Isn't it "Normal" coding practise, to declare subs, interrupts and functions at the END of the listing, not at the top?
Normal, Yes.
But not 'required' for MM Basic.
Some Basics are strict about the order and will require a DECLARE statement before being called if the function is after the calling code.
Others are like MM Basic and don't care.
Posted: 04:39pm 29 Mar 2014
You just beat me to it jman - tried in editor on Beta16.
I agree with Grogster about code layout BUT not everyone will declare subs & functions at the end of their code.
For this reason I say this is definitely a bug!
Over to Geoff to confirm . . . .
Posted: 04:43pm 29 Mar 2014
Okey dokey then.
ztoti
Posted: 04:56pm 29 Mar 2014
Thank you TassyJim,
You are right, the first line must be blank.
     Page 25 of 26
