Local Time 10:10 12 Nov 2026 Privacy Policy
     Page 22 of 52
ville56
Posted: 10:03pm 07 Apr 2025
@Peter,
is there a limit of 255 integer array elements for the I2C READ statement? I use the following form:
i2c read i2c_addr, 0, num_bytes, eeprom_data()
where num_bytes is 255 or 256 and the eeprom_data array has the corresponding size and is type integer.
num_bytes=255 and less, all ok
num_bytes=256 and up, firmware crashes and reboots
Env: PicoMite MMBasic RP2350A Edition V6.00.02RC10
Gerald
73 de OE1HGA, Gerald
Posted: 10:45pm 07 Apr 2025
Deleted, brain fade.
Edited 2025-04-08 09:42 by phil99
Posted: 09:07am 08 Apr 2025
  Quote  num_bytes=255 and less, all ok
Bug - will fix. Obviously no-one has ever tried to receive more than 255 before.
Posted: 10:11am 08 Apr 2025
Yes, I did (not sure it No_One did as well ... No_One is the name of the guy who wrote the USB-PS2 conversion for mice and keyboard for pico originally). I thought it was a limitation from MMBasic (heritage from the MX170) that did not even have sufficient RAM to put all this data in an integer array.
I wrote copy routines for 24LC32's that read 255 bytes, then 1 byte (the last) for each sector.
Edited 2025-04-08 20:13 by Volhout
58kk90
Posted: 06:04am 09 Apr 2025
So it looks like the bit command and function is not coming back, which is a massive msitake in my opinion, it was so useful, in that case would anyone still have a copy of the beta that DID have it and can possibly upload it for me somewhere, as I am going to stick with that version rather than lose it in favour of stuff that is no use at the moment to me.
Tony
Posted: 06:19am 09 Apr 2025
Hi 58kk90,
This is RC8, and (just tested it) it still has the BIT command.
For me (RP2040 VGA user) this was a stable version. The only issue I found was with font 7. But as I learned later, the above I2C issue with 256 bytes exists in rc8.
6.00.02rc8
But I think (when you ask Peter politely) he may bring the BIT command and function back, in addition to the FLAGS.
Edited 2025-04-09 16:23 by Volhout
Posted: 06:38am 09 Apr 2025
I'm sure it will all depend on the space and tokens available and whether BIT and FLAGS can get in the way of each other. Then it's a case of speed. FLAGS is faster as there is no variable lookup time. These are all things that need consideration - you can't just blindly put BIT back without some proper testing.
Logic tests have been used for ages for testing serial data bytes as they come in (the serial routines on the Nascom did that in Z80 code). You have variable lookup delays there too so the question is, would BIT only be making the code appear simpler and not really give any speed advantage?
Posted: 06:57am 09 Apr 2025
Hi Mick,
a%=FLAGS(x) needs a lookup of 2 variables
a%=BIT(b%,x) needs a lookup of 3 variables.
Flags is best to managing flags.
Flags may faster, but BIT is universal. You can use it at many variables. Also to decode/analyze data that is inside an integer. And if that is what you are doing, the loss of BIT may cause pain. Becaus the alternative { a%=(b% and 2^x)<>0) } is even slower.
Posted: 07:18am 09 Apr 2025
@Peter,
Using RP2040 GEEK. It has an small OLED display, but since typically all communication goes through Teraterm, is there any way to prevent error messages going to the OLED display ?
I tried OPTION LCDPANEL NOCONSOLE but
- this option does not show in OPTION LIST (I have no idea if it is accepted)
- still all error messages go to the LCD.
I think this topic was brought up by Tom earlier (For the Game*Mite), but can't remember the outcome of the discussion.
Edited 2025-04-09 17:28 by Volhout
Posted: 07:23am 09 Apr 2025
But when you are testing serial data you are usually looking for byte codes (commands or addresses) not bit testing so
a%=(data% AND &b00101000)>0 only requires 2 lookups.
I can see BIT being useful for reading flags read from I2C modules, for example, but the read is already completed then (well, it should be!) and timing isn't usually as much of an issue.
I guess it's horses for courses. :)  I normally put bit routines in my Library.
Edited 2025-04-09 17:25 by Mixtel90
Posted: 07:30am 09 Apr 2025
  Mixtel90 said  I normally put bit routines in my Library.
So there is need for it.
P.S. I can't use the library anymore. I have 1 flash slot reserved for the filemanager, many of the games use another flash slots (petscii) so whatever I put in there get's erased anyway. I did not think that when 5.07 was developed, I would be asking or more flash slots... At that time we still had 7 slots, and no A:/ drive and no MODBUF.
Edited 2025-04-09 17:34 by Volhout
Posted: 07:40am 09 Apr 2025
Oh, there's a need for bit testing. :)  But is it speed critical?
When testing for commands and addresses you need to be quick so logic testing an entire byte or word in one operation is the best way. If you test more than a couple of bits it's slow.
There are cases where you might, for example, test a received I2C bit in a loop but the time lost by testing using several variable lookups is nothing compared to the time taken to request and receive the bit into a buffer.
(Didn't I say at the time that we shouldn't be reducing the flash slots? :)
If a *simple* file manager can be sorted out and integrated into MMBasic then
at least you get one back. Or fit the file manager into the Library.)
Edited 2025-04-09 17:44 by Mixtel90
circuit
Posted: 07:45am 09 Apr 2025
  Volhout said  Hi 58kk90,
6.00.02rc8
Would "on my knees and begging" be considered to be polite enough?  As I emphasised in my last post; the BIT() command and function streamlines code for interfacing with power logic shift registers rather superbly, as well as setting PORT() interfaces.
electricat
Posted: 08:20am 09 Apr 2025
I liked idea of Bit commands and functions too. Something I`we used in Mikroe`s "mikroBasic PRO for PIC" much.  But FLAG command  and function seems to me SUPER USEFULL too.
Peter said once something like 'nobody wanted it, so I discarded' or something..  so my both sleepy cats would rise paws for BITs and FLAGs if asked to vote on this case
I see it, like well, problem can always be solved with any tool on hand. It`s only question of how fast/comfortable I could be done.
I still ocassionally write DEC 1 instead of INC ,-1   while INC ,-1 is perfectly OK
I do Bit manipulations shifting, ANDing, ORing and it`s perfectly OK, but Bit set, Bit reset etc. just seems so comfort    and speed is not always that important. And custom bit functions you still need to load/add etc. Takes space
Edited 2025-04-09 18:22 by electricat
My MMBasic 'sand box'
Posted: 08:29am 09 Apr 2025
As a compromise would adding this feature to FLAG() make it usable for you ? Assuming it is possible.
FLAG(all) = x%
or
FLAG(all) = 0
Then you can assemble your bits in FLAG(), send the value of MM.FLAGS out the door and use FLAG(all)=0 to clear it for recycling and start with the next batch.
Posted: 08:50am 09 Apr 2025
Or add the facility to set MM.FLAGS?
MM.FLAGS = &h0FF7 for example. There's no need to change FLAG(n) at all then.
Posted: 08:53am 09 Apr 2025
  phil99 said  As a compromise would adding this feature to FLAG() make it usable for you ? Assuming it is possible.
FLAG(all) = x%
or
FLAG(all) = 0
I guess this suggestion boils down to copying the variable you want to test into the "FLAGS" variable, doing some bit manipulation, then copying it back to the variable. And (in doing this process) loosing FLAGS to do what it is intended for (keeping logic flags) since these are constantly overwritten by above mis-use of the FLAGS variable.
I think that I summarize it well when I say, BIT is more appreciated than FLAGS, despite the good intention of Peter. Maybe time to do a small step back, and re-vive BIT, potentially at cost of loosing FLAGS.
Edited 2025-04-09 18:56 by Volhout
Posted: 10:25am 09 Apr 2025
  circuit said   I am now stuck with having loaded up my picomites with the last code to retain the BIT command/function and it is not clear to me whether or not the latest download will have these available; I don't want to overwrite and find that I have lost these command/functions.
welcome to the abyss... been here since 5.04.08 (but I'm ok with that)
Edited 2025-04-09 21:55 by CaptainBoing
Posted: 11:31am 09 Apr 2025
(xkcd? If not it should be!)
Anyone who is *depending* on a RC release is doing this wrong. RC (Release Candidate) is a beta that is more likely to be released without too many more changes, it's not a stable release yet and things may change.  :)
If you want a release that isn't going to break your program then use the newest full release, even if the future bells and whistles aren't in it...
Posted: 11:42am 09 Apr 2025
V6.00.02RC11 is available on
The Bit(ch) is back
+ > 255 i2c transfers should work - untested
     Page 22 of 52
