Local Time 11:02 12 Nov 2026 Privacy Policy
     Page 20 of 25
Posted: 08:24pm 09 Nov 2024
Simples - you can't surface mount a board with chips on the bottom. :)
Also, it becomes expensive to make the boards if you put components top and bottom. The soldering process is difficult.
javavi
Posted: 08:40pm 09 Nov 2024
  Mixtel90 said  Simples - you can't surface mount a board with chips on the bottom. :)
But Pico2 has pads for USB and other things at the bottom. It's just outrageous that they put such an option to work with an external PRAM into the RP2350 chip and didn't give space (at least at the bottom) so that users could try to use it.
Posted: 09:12pm 09 Nov 2024
Just because the initial modules don't have PSRAM it doesn't mean that later ones won't. :)
Also, it's not PSRAM specific. It's a QMI bus interface. It could potentially be used for other purposes. It's just that PSRAM is a cheap and convenient (if slow) thing to try it with.
The TP pads are not intended for general use. I like to abuse such things. :)
Edited 2024-11-10 07:14 by Mixtel90
Posted: 09:32pm 09 Nov 2024
If you want to play with PSRAM, try the Pimoroni PGA2350
PicoMiteHDMI MMBasic RP2350B Edition V6.00.00RC15
Copyright 2011-2024 Geoff Graham
Copyright 2016-2024 Peter Mather
> OPTION PSRAM PIN GP47
08:23:07 Port: COM4 removed
Disconnected
08:23:08 Port: COM4 inserted
Connected to COM4 at 115200
Total of 8 Mbytes PSRAM available
> OPTION LIST
PicoMiteHDMI MMBasic Version 6.00.00RC15
OPTION FLASH SIZE 16777216
OPTION KEYBOARD US
OPTION PICO OFF
OPTION CPUSPEED (KHz) 315000
Posted: 10:51pm 09 Nov 2024
The problem is that there haven't been any boards with PSRAM on them that can run HDMI. We don't even know if it's possible, as the boards that have PSRAM meet the Pico 2 specification. HDMI output doesn't.
Posted: 07:43am 10 Nov 2024
HDMI runs fine on the PGA2350 at 640x480. It just won't do the higher resolutions
Posted: 07:54am 10 Nov 2024
Ah, thanks Peter.
I see Pimorini still haven't got any anyway, although they are showing stock of the Pico Plus 2 now.
Malibu
Posted: 08:58pm 10 Nov 2024
I just uploaded MMbasic 6.00.00RC15 to try it out, but seem to have found a bug...
This code :
const True = 1
const False = 0
const MaxChannels = 4
dim integer ChNum
dim integer Ch(MaxChannels) = (24, 25, 26, 27)
? "Initialising..."
for ChNum = 1 to MaxChannels
 SetPin Ch(ChNum), DOUT
 pin(Ch(ChNum)) = True  <--- Setting to FALSE will change state to ON for the 1st main loop
next ChNum
? "Initialised..."
pause 1500
do
   pause 500
   ChangeChannelState
 next ChNum
 pause 1000
loop
sub ChangeChannelState
 select case pin(Ch(ChNum)) <--- Always returns FALSE
   case True
     ? ChNum;
     ? " = True"
     pin(Ch(ChNum)) = False
   case False
     ? ChNum;
     ? " = False"
 end select
end sub
... always returns FALSE when reading the state of the output pins, so is never able to change state to OFF when it is currently ON
Common to WebMite and PicoMite - that's all I have to test on
The code works as expected on Ver 6.00.00b5 of both variants
Posted: 10:08pm 10 Nov 2024
Yes, something has changed.
PicoMiteVGA MMBasic Version 5.09.00RC5 'RP2040
> setpin 1,dout
> pin(1)=1
> ? pin(1)
1
> pin(1)=0
> ? pin(1)
0
PicoMite MMBasic Version 6.00.00RC15 'RP2040
> setpin 1,dout
> pin(1)=1
> ? pin(1)
0
> ? pin(1)
0
> pin(1)=0
> ? pin(1)
0
> setpin 1,off
> setpin 1,din,pullup
> ? pin(1)
1
> setpin 1,dout
> ? pin(1)
0
> pin(1)=1
> ? pin(1)
0
Posted: 10:11pm 10 Nov 2024
The pin function no longer reads the state of a pin set as an output. This is needed to circumvent the RP2350 E9 bug. You will need to track the output state of a pin in software
Malibu
Posted: 10:27pm 10 Nov 2024
No worries, thanks Peter...
Posted: 09:35am 11 Nov 2024
UPDATE
When a pin is set for output I can return the state of the output register rather than the input - should fix this. Will include in the release
pwillard
Posted: 01:36pm 11 Nov 2024
Isn't the E9 issue only with input mode?
Posted: 11:50pm 15 Nov 2024
RP2040 standard with LCD
DHT22 worked OK with RC9 but returns 1000 with RC15
Tried various CPU speeds from 133MHz to 300MHz
Posted: 01:11am 16 Nov 2024
DS18B20 DS18B20  DS3231      AHT10                   DHT11      DHT11 reading method
18.3    17.1    16.25   16.5C   37.5%           16.8C   44%    Device HUMID,0 + extra wake pulse for DHT11
18.2    17.2    16.25   16.5C   37.5%           16.9C   44%    PulsIn in  For...Next
> option list
PicoMiteVGA MMBasic Version 6.00.00RC15 RP2350
using the DHT22 command to read a DHT11 to get tenths of °C:-
 Humid GP0, T, H
BitBang and Device no longer required, but still works if used.
Just tested a RP2040
> humid GP0, T,H,1
> ? t, h
17      44
> option list
Posted: 01:32am 16 Nov 2024
My device is DHT22 and I also tried the DHT11 option with no success.
Posted: 02:24am 16 Nov 2024
Tried various CPU speeds, 126MHz and up. Works at all of them.
This is how I use the DHT22 option to read a DHT11
Setpin GP1, Dout
Pin(GP1) = 1
 Pulse GP1, 20  'provide an extended low "wake" pulse via diode for DHT11
 Pause 18.9 'overlap the 1mS DHT22 "wake" pulse
 Humid GP0, T, H, 0 'start DHT22 command
 Print t, h,,,
    H = H*10 >> 8   ' convert data format from DHT22 to DHT11
    T = (T*10 >> 8) + (T*10 And 255) / 10 ' and add tenths of degrees
 Print t, h
 Pause 30000
Posted: 04:47am 16 Nov 2024
More on the DHT22
I compared the timing between RC9 and RC15. I cannot see any difference.
When I attached the CRO leads, I was able to get valid readings some of the time.
Looking at the trace, the ripple at 3.3V is visible on RC15 but not there with RC9
I have tried shorter leads and capacitors on the data line and it worked, some of the time.
Posted: 07:30am 16 Nov 2024
Mine is at the end of about 1m of alarm cable that also has I2C for the AHT10 and DS3231 so there is a fair bit of noise on the DHT line but it doesn't seem to matter.
Check the length of the "Wake" pulse. I measure 1mS which is right on the minimum required for a DHT22. For a DHT11 the minimum is 18mS so I use 20mS for maximum reliability.
You could experiment with the method in the code I last posted to try a 1.5 to 2mS pulse.
Setpin GP1, Dout 'diode anode to GP0, cathode to GP1
Pin(GP1) = 1
 Pulse GP1, 2  'provide an extended low "wake" pulse to DHT via diode
 Pause 0.9 'overlap the 1mS DHT22 "wake" pulse + time to start HUMID
 Print t, h
 pause 10000
loop
The 'Pause 0.9' will probably need adjusting to ensure the end of the extra pulse occurs during the one from HUMID.
Edited 2024-11-16 17:37 by phil99
karlelch
Posted: 04:47pm 16 Nov 2024
Hi,
I have a question regarding the PS2 keyboard in the HDMI/USB 2350 version. I was playing with the Solder Party RP2350 Stamp with carrier board (see also this thread and "PicoMiteHDMIUSBV6.00.00RC15" works out-of-the-box with HDMI monitor and USB keyboard.
The problem is, to activate the SD card, GP9 is required on the carrier board:
OPTION SDCARD GP9,GP10,GP11,GP8
and (as described by Sasquatch) works for the HDMI only version ("PicoMiteHDMIV6.00.00RC15")
However, the "PicoMiteHDMIUSBV6.00.00RC15" firmware complains that "Pin 12/GP9 is reserverd on startup" - used by the PS2 keyboard, which is not needed when using a USB keyboard - or am I wrong here?
OPTION KEYBOARD DISABLE
generates an error ("Error : Syntax") in the HDMI/USB firmware, but not so in the HDMI firmware.
Shouldn't it be possible to disable the PS2 keyboard also in the USB version?
What am I missing?
Thomas
     Page 20 of 25
