Local Time 06:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DHCP Ethernet device
atmega8
Posted: 11:23pm 14 Apr 2017
Bigmik,
REALLY PERFECT would be this Device, with an Openwrt Linux Image on it.
With WIFI, Rj45, RS232 and the complete World of Linux ( shell etc.) is open
for you.
No limits to the limits of your Imagination;-)
Linux
atmega8
Posted: 12:06am 15 Apr 2017
Or this very nice device:
Vcore
But with casing about 50$$...
jman
Posted: 04:16pm 16 Apr 2017
Hi
Attached is some code from the PicBasic forum that implement's DHCP on the W5100/
I have not had an in depth look at the code but I ma sure it will give you some pointers.
Jman2017-04-17_021556_w5100-dhcp-demo.zip
Posted: 04:37pm 16 Apr 2017
Hi JMan, All,
@JMan,
Thanks for that, it looks readable (sort of) but boy it is a heap of code to digest.. I am currently exploring the possibility of using a Static IP address, (actually a range of static IP addresses to select from) or at worst case enter one in on power-up.
I have asked the question to see if there is an IP address that is un-allocated that I can permanently use, but as the system hasnt yet been installed that information probably is, at this stage, unobtainable.
I figure we can do a WSPING from the main control room end and find an IP that hasnt been allocated and adopt that at worst case.. So it is still a possible route to go with.
Kind Regards,
Mick Edited by bigmik 2017-04-18
