Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme Firmware V5.03
     Page 2 of 4
disco4now
Posted: 02:39am 03 Mar 2017
Peter,
Thanks for the info and the updated files.
The PEEK for options is OK I think now with the new address.
Gerry
F4 H7FotSF4xGT
Posted: 04:54am 03 Mar 2017
Attached is the latest release 5.3.10 for the 100 and 144-pin parts
2017-03-03_145316_MMX5.3.10.zip
and for the 64-pin part
2017-03-03_151816_MMX645.3.10.zip
This release includes FLAC file playback.
It also includes a minor tweak to the VGA driver that stops a red pixel occasionally appearing one place to the left of its intended position
The manual is updated with the I2S pinouts and PLAY FLAC command
2017-03-03_154533_Micromite_eXtreme_Manual.pdf
Edited by matherp 2017-03-05
Posted: 08:57am 04 Mar 2017
Attached is the latest release 5.3.11 for the 100 and 144-pin parts
2017-03-04_191644_MMX5.3.11.zip
This release includes S.A.M. text to speech.
It fixes a bug that caused WAV file playback to terminate a few seconds early.
It allows mono WAV files to be played
The manual is updated with the TTS command
2017-03-04_191906_Micromite_eXtreme_Manual.pdf
Posted: 09:25am 04 Mar 2017
TTS - ironically I am 'speechless'
Now I can finish my Talking Clock with ease
Not yet tried it but will install v11 on the current MMX144 build in front of me in a short while.
Now don't forget the other two new MMX 'fun features' in my email (v12 & v13 by tomorrow morning if you don't mind!)
WW
Posted: 10:55pm 04 Mar 2017
Fixed a bug in TTS PHONETIC where invalid phonetic text was not trapped and the "Play" status was left incorrect.
No change in version number 5.3.11
2017-03-05_092544_MMX5.3.11.zip
And for the 64-pin part with same additional functionality and bug fixes
2017-03-05_092202_MMX645.3.11.zip
Edited by matherp 2017-03-06
Posted: 03:23am 06 Mar 2017
I've discovered there is a Microchip silicon errata that may relate to the way I use the reference clock to derive the frequencies needed for FLAC file playing over I2S.
This version implements their proposed work-round even though I haven't personally encountered a problem.
FatFs is updated to version R0.12c
176.8KHz FLAC file playback is supported when OPTION CPU 252 is enabled
Attached is the latest release 5.3.12 for the 100 and 144-pin parts
2017-03-06_183253_MMX5.3.12.zip
2017-03-06_183357_MMX645.2.12.zip
User manual updated to reflect the version change
2017-03-06_131724_Micromite_eXtreme_Manual.pdf
Edited by matherp 2017-03-07
Posted: 07:44am 10 Mar 2017
Attached is the latest release 5.3.13 for the 100 and 144-pin parts
2017-03-13_115411_MMX5.3.13.zip
2017-03-13_154846_MMX645.3.13.zip
Changes are:
* Fixed a bug in PLAY WAV and PLAY TONE that could cause distortion when the volume was above 90%
* Fixed a bug in PLAY WAV that caused the volume to be lower than it should be.
* Improved handling of Ctrl-C when playing WAV or FLAC files as part of a program
* Stop playback of FLAC and WAV files when using "RUN" or EDIT"
* Rewrite of FatFs error handling to deal with WW "stress" tests e.g. removing SDcard while playing WAV or FLAC files
* Fixed a bug relating to using the console as COM4
* Re-engineered GPS parsing to fix bug when invalid data sent
* added GPS(GEOID), which returns the Geoidal separation (in meters)
* added PRINT #GPS,"$......*" outputs a NMEA string to a previously opened GPS receiver. The checksum is calculated by the firmware. The string must start with the $ character and end with the * character.
Geoff has kindly agree to host the manual as it is now too big to post
Micromite eXtreme manual
Edited by matherp 2017-03-14
Posted: 07:34am 17 Mar 2017
Attached is the latest release 5.3.14 for the 100 and 144-pin parts
2017-03-19_085644_MMX5.3.14.zip
2017-03-19_085710_MMX645.3.14.zip
Changes are:
* Added support for ILI9481 480x320 displaysEdited by matherp 2017-03-20
Posted: 04:14am 19 Mar 2017
Attached is the latest release 5.3.15 for the 100 and 144-pin parts
2017-03-19_141342_MMX5.3.15.zip
2017-03-19_141440_MMX645.3.15.zip
Changes are:
* Implemented OWSEARCH function
see this thread for details
Posted: 04:13am 31 Mar 2017
Attached is the latest release 5.3.16 for the 100 and 144-pin parts
2017-03-31_140902_MMX5.3.16.zip
2017-03-31_140952_MMX645.3.16.zip
Changes are:
XMODEM function enhanced to transfer files directly to and from the SDcard.
XMODEM RECEIVE filename
XMODEM SEND filename
The filename must be enclosed in quotes if it contains spaces, otherwise it can be typed without quotes.
If the filename is omitted then XMODEM acts as currently documented in the Micomite manual.
This change was at the request of TassyJim and makes it much easier to, for example, transfer data logs to a host PC.
Edited by matherp 2017-04-01
Posted: 10:43am 31 Mar 2017
Thanks Peter.
There will be an update to MMEdit "soon" to allow the File Manager to work with the MMX range in the same way it works with the Maximites.
I have a few redesign issues to cater for the growing 'mite stable.
Zonker
Posted: 12:29pm 31 Mar 2017
Hey, Gents...
@matherp: Thanks for all your work on the new MMX firmware..! I just got working copies of the MMX 144/64 boards from WW.. (w/camera)... So, I finally get some playtime this weekend... Got a fresh 7" fitted up to the 144 and a SPI 2.3" on the 64... Both seem to work great... I will be doing an update to ".16" with a PICkit-3 and bolt on the RTC module.. (sweet)...
@tassyJim: I was typing to Peter couple weeks back about the scanline function... He had mentioned the fact the long VAR names take time to "parse" through the firmware and to keep names as short as possable... Well, that got me to thinking about something I remembered form the old days.. (Z-80/CPM).. I know you have your "crunch" function in the editor. I seem to remember a "post processor" type of CPM program you could submit your basic text file to that would take all your VAR, SUB, CONT ect. "long names" and then compress them to one or two letter versions of them to help make your program run faster... I never used it much and don't remember what it's name was, but when we got a hold of a "star trek" game that was written in basic, I remember processing it through this "crunch" program... It removed all the program comments and crunched the VAR names to the smallest letter combo's and wrote the output file. We took a look at the output file... Wow, very hard to follow as a "human" reader, but the program ran almost twice as fast..! We still went through reams of paper playing the game as it was the only output device..!
So, anyway, not sure if you guy's ever herd of such a thing, but, if your editor could do the same thing... Now, this is probably not an issue on the MMX class of MM's, but could be a good thing for the 170's.. I am not really suggesting this as a thing on your "to-do" list, just my 8-bit brain babbling on...
Thanks again Gent's..! (i love new toys)..!
Posted: 02:01pm 31 Mar 2017
It is a request that has been made before and while I haven't ruled it out altogether, I worry about butchering someones code too much. MMEdit would have to do a lot more than a simple global 'replace'. A wrong assumption by MMEdit could destroy someones pride and joy.
Posted: 12:19am 01 Apr 2017
... which is why we always back up, right? ... we do always back up... right???
Posted: 12:33am 01 Apr 2017
There is a Basic version of crunch which I've tried in the past and works well. You would need to make sure the reserved word list is up-to-date to use it Edited by matherp 2017-04-02
Cherokeecruiser
Posted: 10:02pm 06 Apr 2017
Hi All,
Thanks to matherp for the excellent work on the MMX firmware
Just wondering if it would be possible at some future revision to add the click pin option with mouse support if anyone thinks it is useful.
(yeah I know the actual mouse buttons are supposed to click when you use them - it would be nice to have the gui beep available.
I guess the click for mouse button could be implemented from a gui interrupt with the mouse, but a background beep is more challenging for me!
Jeff
cdeagle
Posted: 11:26am 15 Apr 2017
Is there a way to display all 16 digits of double precision numbers? I need to create DATA statements using MMBASIC eXtreme similar to
DATA -19503.5967962382, -19120.6463095138, -5386.83402043336
DATA 2697.05908554283, -411062.593704381, 18048.4396148379
DATA -302378.152698336, -6944.44935382575, -1025352.02824372
or perhaps
DATA -1.95035967962382e4, -1.91206463095138e4, -5.38683402043336e3
DATA 2.69705908554283e3, -4.11062593704381e5, 1.80484396148379e4
DATA -3.02378152698336e5, -6.94444935382575e3, -1.02535202824372e5
Posted: 11:56am 15 Apr 2017
The data statements work fine in terms of loading the internal variables. I can't find an algorithm to print them out accurately though.
You can prove this as follows:
read a
print str$(a*10000000000,20,0)
cdeagle
Posted: 11:03pm 15 Apr 2017
Thanks Peter.
I was hoping the PRINT STR$ of a floating point number could be extended beyond 8 digits.
Posted: 12:49pm 16 Apr 2017
Would this help
  Quote   DATA -1.95035967962382e4
READ a
PRINT uformat$(a,12)
FUNCTION uFormat$(x,p)
' given a number (x) and the required number of decimal places (p)
' returns formatted string. Negative and zero p is permitted
LOCAL f$
f$=
STR$(CINT(x*10^p))
IF LEN(f$)<=p THEN
f$=
STRING$(p+1-LEN(f$), "0")+f$
ENDIF
IF p>0 THEN
uFormat$=
LEFT$(f$,LEN(f$)-p)+"."+RIGHT$(f$,p)
ELSEIF p = 0 THEN
uFormat$=f$
ELSE
uFormat$=f$+
STRING$(ABS(p),"0")
ENDIF
END FUNCTION
I wrote it a long time ago but it seems to work with double precision.
     Page 2 of 4
