Forum Index : Microcontroller and PC projects : use of spi sd card on mm-28 with 5.2?
Thank you for re-confirming what MikeO did--that the SD code (library and test code) works with the right (3.3V) module. I'm awaiting the arrival of mine. It may be some weeks. Lance PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
