Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite MMBasic V5.2 Beta 2
Posted: 12:36am 02 Sep 2016
@Geoff,
Can I make a little suggestion that will save a lot of potential confusion.
I agree with Phil23 regarding version numbering. A.BB.CCC where a is a major release, BB is an incremental release, and CCC are beta releases for A.BB (i.e. testing version).
This is pretty much what you do now; however, my request is can you make MM.VER the SAME number please
@panky
I understand your request about print numbering BUT this is not as easy as it sounds. Keeping up-to-date 'printed' manuals will require either a lot of printing, or a lot of version control documentation. The issue is if you see a page with a different version number on the footer to the one you have printed how do you know quickly if there any changes with the content between the two pages? The only way to be sure is to print the new page which is exactly what you are are trying to avoid (or read the whole page word for word before deciding if it needs printing - not easy with this size manual )
My solution is to simply visit Geoff's website each time I need to reference the manual, download it, and view the relevant section. I do this on a tablet; and I know what you mean about the wife not being too happy reading this in bed (my wife I mean!!)
WW
panky
Posted: 07:51pm 08 Sep 2016
@Geoff,
Would it be possible to add the decimal point to the permisable characters for font #6 in the Micromite + ?
panky
Posted: 02:17am 09 Sep 2016
Yes, that is a glaring omission. I will add it to the list for investigation.
Cremo
Posted: 03:29am 09 Sep 2016
Hi Geoff,
thank you for your wonderful work.
I would like to know why the DISPLAYBOX do not respond to touch.
I think that it is useful for example in this case:
you want to change parameters with an encoder selecting one of the DISPLAYBOX showing the value.
I was forced to check the coordinates during the touch interrupt.
It can be very much simple do the test of the number of the object.
Best regards.
Pietro
nibbler
Posted: 06:41am 09 Sep 2016
@Geoff
Many thanks for all of your efforts with MMBasic and the Maximites & Micromites. I have a simple (I hope) request that might be of benefit to some of us. Would it be a lot of work to provide an errata to the manual after a major or incremental release? Sometimes someone finds a typo or error in the latest manual and posts it here in TBS but subject lines aren't always descriptive and corrections can be missed.
Thanks again. It keeps getting better and better.
Alan
Posted: 11:55pm 09 Sep 2016
This is something that I have thought about but is not easy to implement. Firstly, the Change Log records the changes to the firmware and these are reflected in the manuals. So this just leaves the smaller changes (typos, errors, etc) which are not logged.
I did try generating change bars (I use Word 2003) but they messed up the formatting but there must be some other way of using software to generate a change log.
Posted: 12:27am 10 Sep 2016
I suppose if you also release the DOC then people could ask Word to show the change bars. (I guess almost no-one wuld, though.)
A PDF to text converter applied to old & new PDFs then a text compare wouldn't be too hard, for the few who want to know every change.
Posted: 04:54pm 20 Sep 2016
  lew247 said  Is there an arg$ function? or will there be in future versions?
It would make trying to use specific sections of comma separated items so much simpler if there was.
I was thinking of implementing something like:
n = GetArgs(src$, delim$, array$())
Where:
n = number of delimited values found
src$ = is the source string containing the values
delim$ = is the delimiters (one or more) that separate the values
array$() = is a pre defined string array which will hold each value
So, for example:
n = GetArgs("aa,fff,78,g", ",", a$())
n would contain 4
a$(0) would contain "aa"
a$(1) would contain "fff"
a$(2) would contain "78"
etc
Would this suit everyone's needs?
Any suggestions or extensions that should be included?
Posted: 05:41pm 20 Sep 2016
I would put the delimiter(s) last and have it optional, defaulting to comma
n = GetArgs(src$, array$()[, delim$])
Only because it matches the other languages I use.
Would your function redim the array so we don't have to guess the required size?
The next request will be to handle quoted text.
Edited by TassyJim 2016-09-22
Posted: 06:22pm 20 Sep 2016
Thanks Jim, that syntax is better.
I'm not sure about auto rediming the array, that is not easy to do so I will have to look at it.
What exactly do you mean by "quoted text"?
Posted: 06:35pm 20 Sep 2016
how about:
n = CountArgs(src$, delim$)
where the value returned by CountArgs tells you how many arguments are contained in src$.
and then have a second function:
A$ = GetArg$(src$, delim$, i)
where i is the index of the argument to be extracted, and the value returned is that argument.
the nice thing about this approach is that there would be no need to resize arrays within the interpreter, and none of the functions would be exhibiting unpleasant 'side effect' behaviour that is considered so uncouth.
rob :-)Edited by robert.rozee 2016-09-22
Posted: 06:57pm 20 Sep 2016
This is typically what CSV files will contain.
  Quote  27,"Fred Jones",painter,$120.00,"Perth,WA"
Any field enclosed in quotes stays as one field even if it contains the delimiter within the quotes.
They can be a pain to pass without resorting to character at a time.
I would be happy with Robert's approach also. With the delimiter as the last argument and optional, it is what I am used to.
PureBasic uses:
Result$ = StringField(String$, Index, Delimiter$)
and Liberty Basic uses:
Result$ = WORD$( stringExpression, n [,string delimiter] )
JimEdited by TassyJim 2016-09-22
Posted: 07:29pm 20 Sep 2016
so then:
n = CountArgs(src$, delim$ [, quote$])
A$ = GetArg$(src$, i, delim$ [, quote$])
where quote$ contains the quote mark character(s).
delim$ could also be optional, defaulting to just a comma if not present:
n = CountArgs(src$ [, delim$ [, quote$]])
A$ = GetArg$(src$, i [, delim$ [, quote$]])
Posted: 08:42pm 20 Sep 2016
Or just use a small function written in basic.
[code]
Function GetFieldArray( Record$, Delimiter$, KeepQuotes ) AS INTEGER
  Local Index, Char, InQuote, Count
  InQuote = 0
  Count = 0
  FieldArray$(Count) = ""
  If Delimiter$ = "" Then Delimiter$ = ","
  For Index = 1 To Len(Record$)
    Char = Asc(Mid$(Record$, Index, 1))
    If Char = 34 Then InQuote = Not InQuote
    If Not InQuote And Instr(Delimiter$, Chr$(char)) >= 1  Then
      Count = Count + 1
    Else
      If Char <> 34 Or KeepQuotes Then
        FieldArray$(Count) = FieldArray$(Count) + Chr$(char)
      EndIf
    EndIf
  Next
  GetFieldArray = Count + 1
End Function
[/code]
Only drawback is that the resulting array has to be global, and can not be dimensioned properly. If something would be really useful it would be a REDIM and having LBOUND and UBOUND available. Then it can all be done from basic.
With the current possibility with wifi modules to query info from the internet this becomes more necessary as parsing the result needs to be done.
The next thing that would be great is variable length strings as that in combination with parsing texts is a huge memory saver.
Maybe another approach that is very difficult to implement in basic but offers a lot of functionality when parsing text is to add a REGEX function.
There must be many c implementations available to use as an example.
You would then kill many birds with a single stone. :)
All of the above is probably a huge effort. My wish would be the REDIM/UBOUND/LBOUND as that enables a lot of algorithms to be made efficiently.
I never implemented a REGEX function before so i have no idea how difficult that would be.
Posted: 12:38am 22 Sep 2016
Where:
So, for example:
n would contain 4
etc
Hi geoff - see my post on a SPLIT function. It would achieve the same thing and maintain the "Microsoft" feel to the basic
cheers
Posted: 01:00am 22 Sep 2016
Can you provide a link to this post?
paceman
Posted: 03:12am 22 Sep 2016
I think he means the 8:04 pm post here Geoff.
Posted: 12:57pm 22 Sep 2016
Thanks paceman.
I rather liked Robert's suggestion of:
and
They are plain and simple and in the style of BASIC. I could also add them to the long string series of embedded C routines using the same syntax.
