Forum Index : Microcontroller and PC projects : Micromite and Micromite Plus Beta 37
     Page 2 of 3
Posted: 08:49pm 18 Oct 2015
  WhiteWizzard said   @TassyJim
So are you sorted now?
Yes Phil,
all is well in the world...
viscomjim
Posted: 12:40pm 21 Oct 2015
For this beta on the uMite, Geoff mentioned in the beginning of this thread...
"This fixes the "corrupt library" bug and a few more (see the file Changes.txt for the details). Again, my bug list is empty except for the Win10 USB issue."
Can I assume that this beta is pretty much bug free at this moment? (28 pin and 44 pin only)
Thanks!
Zonker
Posted: 04:00pm 21 Oct 2015
Yep... I think with the next bump, things should be getting settled...
One last thing, Is there a quick way to check if an SDcard is currently inserted without trying to access it..? Maybe a MM.CardIn value.. Not sure... It's not that hard to test it by doing something like tyying to oped a file, then reading the MM.ERRNO var... So, Not a gig deal...
Thanks Geoff for all you work on this fine code..!
CircuitGizmos
Posted: 09:09pm 21 Oct 2015
  Zonker said   Yep... I think with the next bump, things should be getting settled...
I thought I saw that somewhere on a to-do list.
Positron
Posted: 03:40pm 22 Oct 2015
@Geoff, thanks for all the incredible progress, it feels like a solid update and a true Release Candidate 1 !
May I suggest a small feature request: at the command prompt, retyping the last command (without the Enter) when the up-arrow is pressed, "a la Linux".
Regards, Positron.
Posted: 04:20pm 22 Oct 2015
  Zonker said  Is there a quick way to check if an SDcard is currently inserted without trying to access it..? Maybe a MM.CardIn value..
a means of doing this would be to allow greater flexibility in reading from pins that are assigned to 'special functions'. ie, if pin 7 were assigned as the card detect pin, then allow the line:
IF PIN(7) = 1 then PRINT "card in"
this notion could be extended to allow for the likes of:
IF PIN(12) = 0 then PRINT "console input is low"
and to generate a 1000mS break on the console Tx line:
PIN(11) = 0
PAUSE 1000
PIN(11) = 1
geoff: would these be things that are possible and easy to do? not that i have any particular need, but could imagine that it may be useful for someone. and, of course, assuming that when a pin is assigned to a special function, the PIC32 still provides some ability to read and/or manipulate it independent of that function.
rob :-)Edited by robert.rozee 2015-10-24
panky
Posted: 04:23pm 22 Oct 2015
Geoff,
Great job on the continuing development, thanks. I note from the doco that you specify pinouts for the 100 pin 470 - does that mean that a 100 pin 470 is now formally supported?
If the answer is yes, forum members, is anyone out there in the process or have completed a board design for a 100 pin 470 that they are offering for sale fully assembled?
Cheers,
Doug.
Posted: 04:38pm 22 Oct 2015
matherp has a 100-pin MM+ backpack PCB - see his other thread. It is in active topics.
EDIT: Whoops! Sorry, that board is for the 64-pin chip...... Edited by Grogster 2015-10-24
Zonker
Posted: 04:53pm 22 Oct 2015
Humm... I think a 100 pin motor would be a great idea..!
But, maybe this should be on of those "design by forum idea exchange" kinda things... That way what comes off the table will be something that a lot of folks would want to use as a good project starting platform.. Also, thoughts needed on the type of inter-board interface to use and why.. What types of display units to support ect...
Anyway, something to ponder... Maybe get a fresh thread going...
panky
Posted: 05:57pm 22 Oct 2015
Hi Z,
Was hoping for some guidance from Geoff as to the status of the 100 pinner but do agree on a new thread. Will wait on his response.
Cheers,
Doug.
PS. Geoff, not pushing at all , just looking for an idea on direction/timing. Doug.Edited by panky 2015-10-24
palcal
Posted: 08:25pm 22 Oct 2015
@panky
Check out the SnadPic board for about A$30.
Paul
Posted: 08:31pm 22 Oct 2015
  robert.rozee said   . . . assuming that when a pin is assigned to a special function, the PIC32 still provides some ability to read and/or manipulate it independent of that function.
If possible, simply making these pins READ ONLY could be a good compromise to begin with.
So at the command prompt (or during a running program), if trying to write to a 'special start-up pin', or trying to assign one to another option, then you will get a 'warning/error' message as you currently do.
But at any time you interrogate a pin it simply returns the current value.
WW
panky
Posted: 06:22am 23 Oct 2015
@palcal,
Thanks Paul, will check out.
Doug.
Posted: 05:46pm 23 Oct 2015
As far as I know the SnadPic board is currently the only one with the 100-pin chip. It is a nice board and I recommend it for experimental use.
GeoffEdited by Geoffg 2015-10-25
palcal
Posted: 06:09pm 23 Oct 2015
@Panky
If you order the SnadPic make sure you specify it is for a Micromite, it needs to be fitted with a 20 Mhz Xtal and no clock xtal.
Paul.
panky
Posted: 07:10am 24 Oct 2015
@palcal
Thanks Paul - I was thinking of having a go at modifying Peter M's 64 pin board but wanted to know if the pinout for the 100 had stabilised.
Cheers, Doug.
Posted: 12:15pm 24 Oct 2015
  panky said  I was thinking of having a go at modifying Peter M's 64 pin board but wanted to know if the pinout for the 100 had stabilised.
Yes, it definitely has. l have no plans for any changes.
ThierryP
Posted: 08:12am 25 Oct 2015
I'm seeing more posts on this forum with this type of error since beta 37:
CPU exception #7 (bus error on load or store) at address 0x9D0289CF
Processor restarted
I'm having them too: PIC32MX170F256B with V4.7B37 and COM2 receiving TTL serial signal with following program:
Open "COM2:9600" As #1
B$=""
If Loc(#1) Then
B$ = Input$(1, #1)
Print B$;
EndIf
Produces this error after 1 or few seconds.
Flashed back to V4.6B, same circuit, same program, does not produce this error and runs OK.
Thierry
viscomjim
Posted: 08:49am 25 Oct 2015
I have run into this problem also, and tried a few different things to try and figure out what is happening. I too am using com2 exactly like you are. I did a CPU 40 and haven't had a problem since. Give that a try and see if that helps and maybe we can narrow this down.
ThierryP
Posted: 08:55am 25 Oct 2015
I tried CPU 40 and CPU 30, but in my case this "CPU Exception #7" error remains.
     Page 2 of 3
