Forum Index : Microcontroller and PC projects : I Need New Soldering Iron
I agree, and I use the brass wool/goldilox in a small ceramic holder thing, which is glued down to the top of my solder station. I also use Soldering Iron Tip Cleaner available from many outlets. This stuff seems horribly expensive for the small size of the little pot, but one of these little pots lasts me about 8 years, and I am ramming my iron tip into it a few times every day I am using my soldering station, which is most days, so I can reassure you that it lasts well. I also don't really love the wet sponge method. It does work, but as mentioned, it is a bit of a thermal shock for the iron, so I have settled on using the brass wool/goldilox/pot-scrub method, and it works well. Smoke makes things work. When the smoke gets out, it stops! |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Hmmm... I failed to find that one when a searched for "Soldering Iron" on their site, and now I just might need it. Amazon just sent me a notice they have not gotten a "shipment notice" from the seller I was trying to buy the Antex soldering iron from. I may have to cancel the order and try again.
--Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Yeah but its called a "Soder Station". There's no "L". The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Does that "Soder Station" dispense Coke or Pepsi? I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
My guess is SPRITE MIK Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
what is funniest is sitting in the middle of an engineering office (in christchurch, new zealand), and having a newly arrived american electronics engineer say rather loudly to all who can hear: "have you got a pair of side cutters? i'm looking for a pair of side cutters". except, americans have a different name for "side cutters"... |
