Local Time 22:22 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Cheap 12v LED’s
M Del
Posted: 04:00pm 12 Apr 2015
Rusty
At that price I should get you to mail me some, $15 a pack every where here.
Mark
Eugeneo
Posted: 07:29pm 13 Apr 2015
  Gizmo said   Tested one at a few different voltages. They work down to 6 volts with no change in intensity, but under 5.5v they dim and drop out. Over 18 volts the intensity drops off, and the current goes up, which cant be good! Some readings
6v, 630mA, 3.78watts
12v, 260mA, 3.12watts
24v, 440mA, 10.6watts
So at 24v I expect they would quickly cook and die.
It almost sounds like the PWM hit it's minimum duty, try increasing the inductor or adding more windings to it. If the IC can handle it - it could be that simple.
dwyer
Posted: 06:46pm 17 Apr 2015
  Gizmo said   Hi Ian
Will see how long they last. I've been using them for a few months now, so far so good, and they dont get hot so should last longer.
2 of LED flood light one of them 1/4 and 3/4 are working
Anyway l have pull apart one of the flood lamp and found one of LED
burn out and that was brought from Bunning has removed from shelves for some reason
All the best Ian
All the best Ian
Georgen
Posted: 03:25pm 22 Apr 2015
Would replacement of failed ones bring it back to life?
Probably some kind of heat removal could help here too.
George
M Del
Posted: 09:57pm 23 Apr 2015
I have a bunch of 12v 20w panels, bought em cheapish, as well as some of these lights.
My plan is to combine 3 of these lights, a 15ahr 12v battery, a timer/switch assy, solar panel and regulator. I believe I should be able to light the inside of my two sheds and not kill this battery size.
Reason for the timer, wife forgets (refuses) to turn shed lights off after use , old system is 12 v fluro, battery (old towmotor battery, N70 so called hybrid semi deep cycle?????) switch and 5 w panel.
The timer would be set for on off cycle 6pm-6am, this gives me a chance to see if any lights are on early evening.
Or is there a 12v push switch that powers on for 30-40 minutes?
The panel will get 7-8 hours of sun, about 4-5 hours full.
Is there anything I am missing. If I get this right she will let me go bigger with a semi grid connect hybrid for the fridge/freezer.
Mark
BobD
Posted: 10:25pm 23 Apr 2015
  M Del said   Or is there a 12v push switch that powers on for 30-40 minutes?
You can get electronic switches or just go to an electrical supplier like Middys or Lawrence & Hanson and ask them for a push button mechanical timer switch. Clipsal has several that could do the job and other manufacturers also.
M Del
Posted: 11:51am 24 Apr 2015
Thanks BobEdited by M Del 2015-04-25
Mark
