Forum Index : Microcontroller and PC projects : MMBASIC ver. 4.6 Beta 21....
| G8JCF Guru Joined: 15/05/2014 Location: United KingdomPosts: 676 |
No worries. Just when I saw CPU RESET I thought perhaps MMBasic had been given the 'Big Red Switch' ! The only Konstant is Change |
Give the man a coconut. Jim VK7JH MMedit |
There are some sharp minds on this. With the next beta I will make the 3 second delay apply to both a successful and unsuccessful PIN entry - also make it possible to set a permanent PIN. Geoff Graham - http://geoffg.net |
What would be the point of a delay with the CORRECT PIN? Is this also just to "Trick" any hacking type attack - that will trick it into thinking that the correct PIN is still incorrect?(because of the delay, even when the PIN is correct) Smoke makes things work. When the smoke gets out, it stops! |
| jimbotron Regular Member Joined: 27/11/2013 Location: AustraliaPosts: 50 |
Hi Grogster, That is correct. It forces you to wait the full three seconds to see if you've guessed the PIN. You can't just wait a few milliseconds to see if the PIN is wrong then force a reboot to get the prompt back straight away so that you can retry without waiting 3 seconds. It's a nice solution and won't be a major inconvenience. If you are doing a long debugging session, you'd want to turn off the PIN lock anyway. Jimmy |
Thanks for that info. Smoke makes things work. When the smoke gets out, it stops! |
