Local Time 14:48 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite MkII beta testers needed
     Page 2 of 8
G8JCF
Posted: 07:05am 27 Oct 2014
@KeithW
Re DDS Controller, Try this
OPTION Explicit
'DDS Calculation for AD9850
'(2^32)/CLKIN=Factor
'Tuning Word=Factor*Fout
DIM Factor%,Fout%,TW%,Billion%
Billion%=&h3B9ACA00
'Calculate Factor scaled up by 1E9 so that we can
'do all DDS arithmetic in Integers, 2^32 / 125,000,000 * 1,000,000,000 = 34359738368
Factor% = 34359738368
PRINT "Factor=";Factor%
'For an Fout of 10,000,000 Hz
'TW=34359738368 * 10,000,000 / 1,000,000,000 = 343597383.68 = 343597384 = &H147AE148
'Set Fout=10,000,000
Fout% = 10000000
'Calculate TW% without scaling
TW% = Fout% * Factor%
PRINT "Tuning Word before scaling ";TW%
'Add 500,000,000 because we're going to round by 1,000,000,000
'to ensure correct rounding
TW% = TW% + 500000000
PRINT "Tuning Word after adding 500,000 ";TW%
'Scale back TW% by 1,000,000,000
TW% = TW% \ Billion%
PRINT "Tuning Word is ";TW%;" &H";HEX$(TW%)
'Now do performance testing
DIM I,L
L=TIMER
FOR I=1 TO 100
TW%=((Fout%*Factor%)+500000000)\Billion%
NEXT I
'Calculate elapsed time
L=TIMER-L
'Disp;lay time per DDS Tuning Word calculation.
PRINT "TW Calculate Time=";L/100;" mS"
The Tuning Word is calculated to EXACTLY the same accuracy & precision as a VB Double.
I'll be ditching the BCD library and rewriting my DDS code using INT64 vars.
Peter
The only Konstant is Change
G8JCF
Posted: 07:07am 27 Oct 2014
If anybody is having trouble accessing/installing CFuncGen and/or using the CFunction Tutorial, please PM me
Peter
atmega8
Posted: 07:27am 27 Oct 2014
@Twofingers..
Microchip sends 3 samples for free ;-)
@ Geoff,
tested some I2C, SPI, 1 Wire, Encoder, Interrupts... programms..
So far no Problems.
MMedit Downloads also seem (feels) to be faster.....
Reading bandgap Voltage gives me 1.07xx (+- 0,02 Volts) Volt results.
VCC is stable 3,3 Volts.
Is this as expected?
twofingers
Posted: 07:46am 27 Oct 2014
@atmega
  Quote  Microchip sends 3 samples for free
that would be more than I need. Danke! :)
In fact, I've never tried.
Michael
Posted: 09:41am 27 Oct 2014
Microchip quoted me 63 day delivery for samples:-(
However, RS in the UK now showing plenty of stock, part number 829-0576 at £2.885 each, minimum order 2
Best regards
Peter
Posted: 09:53am 27 Oct 2014
I'm still waiting for the samples I ordered weeks ago, no sign of a date.
If I'd realised they were so slow I wouldn't have bothered.
atmega8
Posted: 09:59am 27 Oct 2014
I had to wait 3 Weeks.
In Germany Farnell and RS have them in Stock.
Delivery within some days...
Posted: 10:54am 27 Oct 2014
Wow, 3 weeks. I've waited nearly 8 weeks already.
twofingers
Posted: 10:55am 27 Oct 2014
@atmega
that (RS) helped a lot. Better than google!
MichaelEdited by twofingers 2014-10-28
atmega8
Posted: 11:18am 27 Oct 2014
  twofingers said   @atmega
Michael
Just use the microchip sample order website.
Here you can choose who supplies the chips.
You can see the estimated Delivery time.
Have not payed one cent for my PIC controllers till now.
OF course i will pay and buy if i switch to mass Production;-)
twofingers
Posted: 01:33pm 27 Oct 2014
@atmega
  Quote  Just use the microchip sample order website.
Thx! I think RS should be faster if I order there (2-3 days?).
Anyway, perhaps we should not continue to abuse Geoffs thread for shopping tips. ;)
Gute Nacht und danke!
Michael
Oldbitcollector
Posted: 04:32pm 27 Oct 2014
  G8JCF said   @Keith W.
I have a version of MMProgRPC which only runs on 4.6 which programs 4.6 in about 13 minutes - needless to say it use CFunctions !!
I'll publish that version as soon as I get a chance
Peter
Peter,
I'm looking forward to this..
Jeff
My Propeller/Micromite mini-computer project.
OA47
Posted: 10:36pm 27 Oct 2014
@Geoff.
Not sure if this is a bug but the memory info is a bit strange:
> RUN
CURRENT UMITE VERSION 4.06
CPU SPEED SET TO 5 MHZ
Flash:
18K (29%) Program (703 lines)
0K ( 0%) 4 Saved Variables
42K (71%) Free
RAM:
773K (1446%) 18 Variables
0K ( 0%) General
4294966576K (-1346%) Free
Will have a look at my DIMs
GM
G8JCF
Posted: 01:17am 28 Oct 2014
Keith, Jeff and others
The new MMProg32RPC which supports 4.6 is available for download from http://www.g8jcf.dyndns.org/mmbasicmkii
This version should also automatically detect and support the older 4.5 MMBasic release. But, if in doubt use the original MMProg32RPC from http://www.g8jcf.dyndns.org/mmbasic/MMProg32RPC.html to program 4.6 into a '170F first, and then use the new MMProg32RPC going forward.
Please give this version a try out and let me know how it goes.
73
Peter
twofingers
Posted: 01:49am 28 Oct 2014
Hallo Peter,
I sincerely find these tutorials instructive, useful, and interesting!
It's more than I expected! Extraordinary good job! Thank you!
Michael
Keith W.
Posted: 02:38am 28 Oct 2014
Thank you Peter,
Chip programmed in 10:29 without fuss.
Now a very practical time.
Now for my bed.
Keith W.
G8JCF
Posted: 05:10am 28 Oct 2014
Thank you Michael.
Always nice to know that one's work is appreciated.
Hopefully you will be releasing a CFunction or two or more in the very near future
Once again, very many thanks for the kind words.
Peter
G8JCF
Posted: 05:11am 28 Oct 2014
Keith
Excellent News !
Thanks for the report.
Sleep well
Peter
atmega8
Posted: 06:50am 28 Oct 2014
Hi Peter,
great Job, really great!
Doesn't solve the Chicken Egg Problem, but fu.. for Chicken ;-)
DS
G8JCF
Posted: 07:14am 28 Oct 2014
Thank you DS ! Really appreciate your kind words
Peter
     Page 2 of 8
