Local Time 12:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : *** COMM *** MuP Ver. 2 Available
     Page 2 of 3
Posted: 10:42pm 01 Jun 2014
I am not trying to make an Arduino compatible unit/header - this is a MicroMite unit/header that uses a minimum number of connections to give the maximum flexibility for any BSF members designing new MicroMite boards.
There are a lot of 'standards' out there which by definition means to me there is NO standard!!
We don't need switching capability between 5v and 3v3 logic levels (causes potential confusion (and blown uControllers) for beginners) and there are so many cheap far east modules on ebay that cater for the thousands of potential combinations that people may need.
I still say that the five connections are the most suitable for the MicroMite 'world' - and have proven to work well. And people can still use their own 'modules' they currently use with a MicroMite if they want to!
So on this occasion I don't mind not catering for . . . Arduino 'standard' USB modules.
vasi
Posted: 04:37am 02 Jun 2014
  JohnS said   But that (Arduino) assumes a 5V uC and uses 5V logic levels, doesn't it?
No John, not only. There are 3.3 and 5V variants. You can order them separately.
Elvish name: Mablung Miriel
Beyound Arduino Lang
vasi
Posted: 04:55am 02 Jun 2014
WW, is not wise, many Bluetooth adapters come also with this standard. You are "insulating" the micro/maximite from the world and limit the users options.
Posted: 05:00am 02 Jun 2014
I am open to suggestions - please describe a header connection that is compatible with Arduino's, Bluetooth adaptors and anything else that you suggest so we can have a 'universal' header.
I am about to put more boards into production so I will hold back for an open discussion on this.
My only request is that this is no more than a single row 5-way header on a 0.1" pitch.
Thanks in advance for your help . . . .
vasi
Posted: 05:15am 02 Jun 2014
As I didn't created the standard, you need only the SparkFun's Eagle libraries.
But be careful, there are two connectors:
- the emitter (USB adapter);
- the receptacle (the board who needs the adapter). (the naming is my doing, you can name them as you wish)
You can easily swap them by mistake.
Posted: 05:25am 02 Jun 2014
vasi, to save time can you just name the pins & functions as a list. Don't worry about 'orientation' at this stage.
By the way, I wasn't totally clear as to what you mean about there being two connectors (or what you mean by swapping them). I believe a list will be clear and will also avoid any misunderstanding as to what you are suggesting.
Thanks again for your help with this.
Posted: 05:46am 02 Jun 2014
Oh. I googled for your phrase
Arduino standard USB-to-Serial
which took me to
here
Which says 5V
Seems made for confusion :(
Posted: 05:49am 02 Jun 2014
Depending on what one wants, 5 pins are not enough. Some want:
Gnd
3.3V
5V
Tx
Rx
DTR (used for reset)
Also, some want 5V TTL and some want 3.3V for Tx & Rx.
(However, the common PL2303 etc seem fine to me...)
vasi
Posted: 06:16am 02 Jun 2014
FTDI Friend offer the logic at 3.3v but the VCC pin is indeed at 5V and obvious you need to wire it through a regulator.
A 3.3V USB adapter which use the same 6pin connector. And there are a host of them, but only if you want to see.
Bluetooth modules who use the USB-to-Serial "Arduino standard" connector.
Lou
Posted: 06:18am 02 Jun 2014
Please Guys,
If the USB module standard is to change do it soon before Zonker finishes his current board layout.
I can only see five pins needed for uMite:
1. 5v
2. 3.3v
3. Tx
4. Rx
5. Ground
For my use the DTR signal suggested earlier to reset the uMite is not needed and will add another pin to the USB interface that could confuse it with the PICkit3 programming connector.
The WhiteWizzard 5-pin USB-to-Serial Module is pin compatible with the SparkFun 718 4-pin module (using care when plugging in) and adds the 5v signal to the to the 5th pin, making both useable for me (the 5-pin is preferable).
If a pinout change is necessary to make it compatible with the 'rest of the world' let's figure it out now.
Otherwise my vote is to leave things as they are and use the WW USB-to-Serial Module as the standard, it works well for me.
What say the rest of the group ??
Thanks Guys,
Lou
Posted: 06:43am 02 Jun 2014
  JohnS said   Depending on what one wants, 5 pins are not enough. Some want:
Gnd
3.3V
5V
Tx
Rx
So basically you are saying 5-pins aren't enough because you propose DTR is needed too. However, I debate that DTR isn't required so hence back to 5 pins.
Regarding 5v TTL - I disagree with this as it is NOT required for the MicroMite and hence why confuse beginners to the MicroMite with the potential they 'blow' their MicroController. Remember that this is a MicroMite dedicated header for Coms and Power - not a universal usb module designed to compete with the hundreds of cheap units found on ebay (some of which caused great problems for Beta testers - just read the forums if you are not aware of these issues!!)
So I am still voting for the 5-pins proposed with no viable challenge to this (yet!!)
WW
Posted: 06:53am 02 Jun 2014
Please re-read what I put. I said "Some want". (To be clear, I don't care. I have plenty of cheap USB/"TTL" etc things and they're very cheap anyway. I couldn't care less about Arduino "standard" especially as there clearly isn't one.)
Posted: 06:56am 02 Jun 2014
  vasi said   FTDI Friend offer the logic at 3.3v but the VCC pin is indeed at 5V and obvious you need to wire it through a regulator.
These units only have one voltage out (ok this may be selectable BUT some MicroMite boards require BOTH 3v3 and 5v). Therefore this 'Arduino standard' may be suitable for Arduinos but I suggest here that it is not ideal for the MicroMite modules being created (some with onboard LDOs, others without).
And what would the CTS & RTS be used for in the MicroMite world with regards to console Coms & Power? I am open to valid justifications.
I am not being 'defensive' of what has been proposed - I am just waiting for a valid challenge to the 5-pins offering 3v3, 5v Rx, Tx and gnd.
I have debated with myself about adding a reset signal (as suggested to DTR??). How many people out there actually need the MicroMite reset connected to DTR?
Please 'shout' if you need this as a necessity!
Remember when replying that this is NOT a general purpose I/O header. It is only designed for console Comms and/or Power supply input.
WW
vasi
Posted: 07:05am 02 Jun 2014
The confusion will start when the user will try to use an already bought product... you suppose that the world starts with your gadgets... but if the community desire this, then I don't mind, as micromite is not in my area of interest. Just wanted to warn about "the universality" of your adapter...
The Serial connector is "the flaw" (well, from my angle) who captured my attention on all the boards until now...
Lou
Posted: 07:21am 02 Jun 2014
I agree 100%
I agree 100%, I don't need reset or the extra pin required.
Sorry Vasi, but I can't see a flaw.
I think we already have something awfully good for the uMite needs, why change anything ?? My 2 cents worth.
Lou
Goeytex
Posted: 08:16am 02 Jun 2014
If the goal is to specifically support Micromite, then I would leave it as is. Keep it simple and cost effective.
There is no way to please everyone. I wouldn't try.
If at some point you want to offer a more universal device that also supports Micromite, then offer as a separate item.
My 2 Cents
vasi
Posted: 09:00am 02 Jun 2014
Fine by me then.
Posted: 10:39am 02 Jun 2014
I have got a specific reason for the DTR being used as a reset signal for the uMite.
When you want to monitor some signals with a PC, a uMite is a pretty handy 'tool' to be able to read analogue and digital signals.
The PC can be a 'connection to internet' or a logger or a 'master controller' etc.
For that you need to make sure that the uMite is always responding and working.
If the PC side detects that there is no more communication with the uMite then simply using the DTR to reset the uMite will in 99.9% of the cases get it running again.
I have done this with arduinos before, and i know i need that functionality.
Now to be clear, it does not have to be on the same connector, on the boards i am designing it definitely is, but that DTR can just as easy be on another pin.
Edited by TZAdvantage 2014-06-03
vasi
Posted: 04:13pm 02 Jun 2014
It is for emitter (USB adapter):
- GND
- CTS
- 5Vcc
- TX
- RX
- RTS
And for receiver (mcu board):
- GND
- CTS
- 5Vcc
- RX
- TX
- RTS
For RTS we have DTR and I guess for CTS we can have the 3.3Vcc but careful, some Arduino boards and adapters connect CTS to ground. And the standard is somewhat preserved.
- Board USBAdapter
- GND GND
- 3,3v 3,3v
- 5v 5v
- RX TX
- TX RX
- DTR DTR
P.S. I can make a list with all the boards, adapters and cables using this standard.Edited by vasi 2014-06-04
Zonker
Posted: 06:51pm 02 Jun 2014
Wow... My little 8bit head is spinning in circles...
I think the object of the upcoming LCD prototype board is to make it compatible with what is already being offered to customers at Phil's website. Lou also seems to think the 5pin WW module for console IO is very suitable also... DONE...
The board will have a "power" connector with: +RAW, +5out, +3out and GND...
There will be a "solder-bump" jumper to source +5 from the WW module (if wanted)
The board has SMD +5 and +3 volt reg's onboard to supply external power
More info and a schematic will follow soon... (will open a new thread)
     Page 2 of 3
