Local Time 11:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS3231 code mmbasic
     Page 2 of 3
MOBI
Posted: 12:18am 08 Mar 2014
Hi Grogster,
It is probably better to always read to an array rather than a single byte variable, in which case, dim an array with the maximum number of elements that you are likely to need. e.g. in the case of the RTC, DIM RTC_data(12) then when you specify the number of bytes to read each register will fit in the array.
DIM rtc_data(12)
i2c write RTC_address,0,1,0
i2c read RTC_address,0,3,rtc_data(0)
This will read the seconds, minutes and hours into RTC_data(0), (1) and (2)
The data will be in BCD format.
In your example, you are trying to assign a byte value to a string instead of a numeric variable.
(sorry I didn't get back straight away but visitors dropped in for a cuppa.)
David M.
Posted: 12:34am 08 Mar 2014
  MOBI said  DIM rtc_data(12)
OK, but how does the read NOT just end up putting ALL the bytes, one after another, into rtc_data(0)? Is this being handled internally by MMBasic?
Not sure I understand the BCD data being returned by the RTC - I seem to recall having similar problems understanding things when I was trying to get it working on the PICAXE(and on their forums too).
EDIT: @ MOBI - I warned you about me and I2C!!!!
ANOTHER EDIT:
  MOBI said  i2c read RTC_address,0,3,rtc_data(0)
This does not seem to want to work on the uM chip - it is rejected - see above image I posted.
Edited by Grogster 2014-03-09
MOBI
Posted: 01:17am 08 Mar 2014
  Quote  OK, but how does the read NOT just end up putting ALL the bytes, one after another, into rtc_data(0)? Is this being handled internally by MMBasic?
Yes, it looks like that, but MMBasic puts the received bytes in successive array positions.
  Quote  Not sure I understand the BCD data being returned by the RTC
I don't know if you understand BCD ? If you do, then sorry about the sucked eggs. If not, in BCD, a byte is divided into a left nybble and right nybble each of 4 bits and each with a numeric value 0 to 9. When you print it, it will come up with the binary version of the variable. If you look at the example in the back of Geoff's uMite manual, it might (or might not ) make things there a bit clearer.
BCD 23 would look like 100011 but displays as decimal 35. BCD makes displaying numeric data easier.
Don't know why your read command isn't working - it is here ok. Unless you are still trying to read to a string variable?
David M.
atmega8
Posted: 03:37am 08 Mar 2014
Hi,
this Basic code works for me with the ds3231 and mmbasic Beta 10 and the 28 pin pic.
Connect Clock and Data from the RTC to Pins 18/17 of the pic with short wires.
pin 18 I2C DATA
pin 17 I2C CLOCK
Tis Routine doesnt make any conversions.
It only reads and prints the BCD values.
You have to convert the BCD values to human readable "Numbers"....
The datasheet is your friend ;-)
Dietmar
Dim RTCbuff(6) ' Received data is stored here
I2C OPEN 100,100 ' Start up the I2C module
I2C WRITE &b1101000, 0, 1, 0 ' Request the time
If MM.I2C <> 0 Then Error "RTC not responding"
I2C READ &b1101000, 0, 7, RTCbuff(0) ' Get 7 bytes from RTC
I2C CLOSE ' Close the I2C function
For i=0 To 6
Print rtcbuff(i)
Next i
atmega8
Posted: 08:54am 08 Mar 2014
@ Grogster
here an advanced example how to extract and calculate the seconds from the ds3231.
Try the rest yourself ;-)
Dietmar
Dim RTCbuff(19) ' Received data is stored here
For i=0 To 19
Print rtcbuff(i)
Next i
seconds = rtcbuff(0) And &b00001111
zehnerseconds = rtcbuff(0) And &b01110000
zehnerseconds = (zehnerseconds \ 16) + zehnerseconds Mod 16
zehnerseconds = zehnerseconds * 10
Print zehnerseconds + seconds
atmega8
Posted: 09:00am 08 Mar 2014
And here the minutes...;-)
minutes= rtcbuff(1) And &b00001111
zehnerminutes = rtcbuff(1) And &b01110000
zehnerminutes = (zehnerminutes \ 16) * 10 + zehnerminutes Mod 16
Print zehnerminutes + minutes
atmega8
Posted: 09:04am 08 Mar 2014
zehner is german for "ten" or "tens"
Hours :
hours = rtcbuff(2) And &b00001111
zehnerhours = rtcbuff(2) And &b00110000
zehnerhours = (zehnerhours \ 16) + zehnerhours Mod 16
Print zehnerhours + hours
BobD
Posted: 10:54am 08 Mar 2014
Try this program to read your DS3231. It may have some syntax errors. I can't test it all. Unless you have set the clock and date data then the output may be crap although the temperature should read correct.
' Read first 19 registers of RTC DS3231
' Bob D 2014 03 09
'how much data do we want
BuffLen = 19
' RTC address
RTCaddr = &h68
Dim RTCdata(Bufflen) Length 2
I2C open 100,100
I2C write RTCaddr, 0,1,0
If MM.I2C <> 0 then
print "I2C error"
end
Endif
I2C read RTCaddr, 0, Bufflen, RTCdata(0)
I2C close
' Convert time and date data
' the data in the registers is BCD (aka Packed Decimal) format
' with a decimal number from 0 to 9 in each half byte (nibble)
' each byte has a 10s decimal and a units decimal
' except day of the week which is units only
' Not all bits are used in each half byte - only what is needed for that data
' Example: Day of month range is 1 - 31 so we need 2 bits for the 10s (decimal 0 to 3)
' and 4 bits for the units (decimal 0 - 9) so we can then express
' all decimal numbers from 1 - 31 in one byte
' each half byte needs to be processed 4 bits at a time and then added together
' this done by right shifting the left nibble 4 bits right (\16) and multiply by 10
' to get the 10s value and then add the right nibble
Seconds = (RTCdata(0) and &h70)\16*10 + (RTCdata(0) and &h0f)
Minutes = (RTCdata(1) and &h70)\16*10 + (RTCdata(1) and &h0f)
Hours = (RTCdata(2) and &h70)\16*10 + (RTCdata(2) and &h0f)
DoW = (RTCdata(3) and &h07)
DoM = (RTCdata(4) and &h30)\16*10 + (RTCdata(4) and &h0f)
Month = (RTCdata(5) and &h10)\16*10 + (RTCdata(5) and &h0f)
Year = (RTCdata(6) and &hf0)\16*10 + (RTCdata(6) and &h0f)
print Hours; Minutes; Seconds
print DoM; Month; Year
' from here is optional but is dependent on previous code
' Convert Day of the week to day name
' Sunday=1 - Saturday=7
DayNames$ = "123456789Sunday 6Monday 6Tuesday 7Wednesday9Thursday 8Friday 6Saturday 8"
Day$ = Mid$(DayNames$, DoW*10, 10)
L = Val(Right$(Day$, 1))
Day$ = Left$(Day$,L)
Print "The day of the week is "; Day$
' Convert temperature and Aging Offset data
' This data is in Twos Complement format
' in register 17 and bits 7 & 6 of register 18
If RTCdata(17) < &h80 Then
Temperature = RTCdata(17) + (RTCdata(18) / 256)
Else
Temperature = -(((RTCdata(17) Xor &hFF) + 1) + (RTCdata(18) / 256))
EndIf
t$=Format$(Temperature,"%+6.2f")
Print "Temperature is "; T$; "degrees Celsius"
If RTCdata(16) < &h80 then
Offset = RTCdata(16)
Else
Offset = -(RTCdata(16) Xor &hFF)
Endif
Print "The Aging Offset data is "; Offset
End
atmega8
Posted: 04:33am 09 Mar 2014
Hi BobD,
your code is definitely much more elegant than what i wrote!;-)
Do you also have such an elegant sample code for writing to the rtc??
Thank you
Dietmar
  BobD said   Try this program to read your DS3231. It may have some syntax errors. I can't test it all. Unless you have set the clock and date data then the output may be crap although the temperature should read correct.
' Bob D 2014 03 09
BuffLen = 19
' RTC address
RTCaddr = &h68
I2C open 100,100
If MM.I2C <> 0 then
print "I2C error"
end
Endif
I2C close
Else
EndIf
Else
Endif
End
BobD
Posted: 08:09am 09 Mar 2014
Dietmar, thanks for that. I hope it works OK for you. I was unable to test it as presented because I don't have a working machine, MM or uM. The hardest part was commenting it for publication given that the format of the time and date data (in the RTC) is not an easy concept for some of us.
I do have the code to load the DS3231 but it will require some preparation. I am also doing some house renovations at the moment (I am under instructions from the boss).
If anyone is impatient to load the RTC it can be done by computing the register values manually, putting them into an array and dumping the content of the array to the RTC.
Example: put time (UTC now) and date into an array
RTCdata(0) = &h00 ' seconds
RTCdata(1) = &h09 ' minutes
RTCdata(2) = &h18 ' hours
RTCdata(3) = &h01 ' Day of Week - Sunday
RTCdata(4) = &h09 ' Day of Month
RTCdata(5) = &h03 ' Month
RTCdata(6) = &h14 ' Year
then give it some I2C code and you should be off and running.
Posted: 01:11pm 09 Mar 2014
Have been away Sunday, and lots of activity here!
I will read all these posts and try some of the demo codes and post back in due course. Thanks guys! Lots of info for me to play with.
atmega8
Posted: 01:35am 10 Mar 2014
Hi Bob,
it will be some more effort to put the right values to the RTC.
We have to do BCD conversion, you know that the RTC uses it for the internal Format.
I stuck in Problems for writing to the RTC..
I2C write seems to have some Problems with writing to the RTC.
So strange things happen, that i can't explain what ist going on here.
I hope there is not a bug in the micromite..
In most cases i'am the bug;-)
Dietmar
  BobD said   Dietmar, thanks for that. I hope it works OK for you. I was unable to test it as presented because I don't have a working machine, MM or uM. The hardest part was commenting it for publication given that the format of the time and date data (in the RTC) is not an easy concept for some of us.
atmega8
Posted: 01:37am 10 Mar 2014
This part of code is working very well.
I Ddidn't test the optional part, tried to do some writes to set the RTC first, with th above described probs..
' Bob D 2014 03 09
BuffLen = 19
' RTC address
RTCaddr = &h68
I2C open 100,100
If MM.I2C <> 0 then
print "I2C error"
end
Endif
I2C close
atmega8
Posted: 08:41am 10 Mar 2014
Here an Example of how to write to the DS3231.
Not complete, but it shows the principles.
It will not take to much time to complete it.
If someone wants do this for all, so please use it..
Tested un 28 PIN OIC with latest umite version
Dim RBUFF(10)
Sekunden = 55
Minuten = 59
Stunden = 23
'if use i2c write do not beginn with 0 in array but with one..
' I would call it a litte bug in mmbasic ?? what do you think geoff?
' It is strange to beginn with 1 in the Array, but to start with 0 in i2c write..
' i think i saw somewhere in the docu an option to configure where the Array
' index starts??; then it is a Feature not a bug ;-)
RBUFF(1) = (sekunden \ 10*16 + sekunden Mod 10)
RBUFF(2) = (Minuten \ 10*16 + minuten Mod 10)
RBUFF(3) = (Stunden \ 10*16 + Stunden Mod 10)
RBUFF(4) = &b00010001
RBUFF(5) = &b00010001
RBUFF(6) = &b00010011
RBUFF(7) = &b00010001
RBUFF(8) = &b00010001
I2C OPEN 100,100
I2C write &H68, 0, 8,RBUFF(0)
I2C close Edited by atmega8 2014-03-11
jman
Posted: 08:51am 10 Mar 2014
Try this to set the time
It will get the current Time and date from the uMite and write it
to the RTC
SetTime:
' Get time from time$ and date$
tempdec = val(left$(time$, 2))
BCDtoHex TempDec
hours = hex
tempdec = val(mid$(time$, 4, 2))
BCDtoHex TempDec
minutes = hex
tempdec = val(right$(time$, 2))
BCDtoHex TempDec
seconds = hex
tempdec = val(left$(date$, 2))
BCDtoHex TempDec
day = hex
tempdec = val(mid$(date$, 4, 2))
BCDtoHex TempDec
month = hex
tempdec = (val(right$(date$, 4)) - 2000)
BCDtoHex TempDec
year = hex
rtcctrl = &h10
rtcwday= &h1
' Write Time to RTC
i2caddr = &h68 ' RTC I2C address
i2c Open 100,100 ' Enable I2C
' i2csend i2caddr, 1, 1 , 1
I2C Write i2caddr, 0, 9, &h0, seconds, minutes, hours, rtcwday, day, month, year, rtcctrl
I2C Close
? "0=ok 1=nack 2=timeout"; mm.i2c
? "RTC has been set to ";time$;" ";date$
end
' Convert to Hex
Sub BCDtoHex TempDec
hex = fix(tempdec / 10) * 16
hex = hex OR ((tempdec / 10) - (fix(tempdec / 10))) * 10
return
Jman
MOBI
Posted: 12:23pm 10 Mar 2014
I originally wrote this for the MM using only i2c devices. I've modded it for uMite but still with I2c keys and i2c LCD. The structure at least might be of some use.
It works on my uM. I don't know how many TBS members have i2c LCD and 12 Key keypad but I can supply the source, hex and schema for those interested.
Pressing the "*" key activates the register set mode. Other wise it is a timing loop.
Option autorun on
Option break 3
Dim RTCbuff(12) ' Received data is stored here
Dim keys(2)
Dim bcd_byte
Dim bcd
blank$ = " "
mylcd = &b0111000 'LCD address
myrtc = &b1101000 'real time clock address
mykeypad = &b0110100 'key pad address
I2C write mylcd,0,3,0,0,2
I2C write mylcd,0,3,0,1,4: Pause 100 'LCD reset. (my LCD pic module)
I2C write mylcd,0,3,0,44,2 'two line display
'I2C write mylcd,0,3,0,15,2
'Main Routine starts here
'scan past keys - check for keypress
If readkey() = 42 Then set_rtc 'if Keypad "*" key then modify register.
I2C write mylcd,0,3,0,12,2 'LCD On, Cursor Off
I2C WRITE myrtc, 0, 1, 0 ' Request the time
If MM.I2C <> 0 Then Error "PCF8563 not responding"
I2C READ myrtc, 0, 7, RTCbuff(0) ' Get the time as 7 bytes
bcdtemp = RTCBuff(0) And &H7F ' Get just the bits that we want
sec$ = Str$((bcdtemp \ 16) * 10 + bcdtemp Mod 16)
bcdtemp = RTCBuff(1) And &H7F
min$ = Str$((bcdtemp \ 16) * 10 + bcdtemp Mod 16)
bcdtemp = RTCBuff(2) And &H3f
hours$ = Str$((bcdtemp \ 16) * 10 + bcdtemp Mod 16)
bcdtemp = RTCBuff(4) And &H3f
day$ = Str$((bcdtemp \ 16) * 10 + bcdtemp Mod 16)
bcdtemp = RTCBuff(5) And &h1F
month$ = Str$((bcdtemp \ 16) * 10 + bcdtemp Mod 16)
bcdtemp = rtcbuff(6)
year$ = Str$((bcdtemp \ 16) * 10 + (bcdtemp Mod 16) + 2000)
If Len(sec$)<2 Then sec$ = "0" + sec$ 'insert leading 0s for appearances
If Len(min$)<2 Then min$ = "0" + min$
t$ = hours$+":"+min$+":"+sec$+" "
D$ = day$+"/"+month$+"/"+year$+" "
disp_str(128,t$) 'display time - or use uMite LCD commands
disp_str(192,d$) 'and date on LCD
'end of main routine
Function getkey() 'wait for a key
I2C write mykeypad,0,1,0 'request a key
I2C read mykeypad,0,1,keys(0) 'read keypad
Loop Until keys(0) <> 0 'non zero value means a valid key
getkey = keys(0)
I2C write mykeypad,0,2,0,0 'Tell the keypad that it can send new data
End Function
Function readkey() 'read a key value no waiting for key press
I2C write mykeypad,0,1,0 'request key
Pause 10
I2C read mykeypad,0,1,keys(0) 'read keypad regardless
readkey = keys(0)
End Function
Sub set_rtc 'read RTC register and new time value
I2C write mylcd,0,3,0,14,2 'cursor on
I2C write mykeypad,0,2,0,0 'clear any leftover key press
I2C write mylcd,0,3,0,1,2 'clear LCD
disp_str(192,blank$):disp_str(192,"Register ") 'blank lines 1 and 2
register = get_dec() 'get register number in decimal format
disp_str(128,blank$): disp_str(128,"# to accept ")
If getkey() <> 35 Then Exit Sub '35 is # key
disp_str(192,blank$):disp_str(192,"Value ")
bcd=get_bcd() 'get Register value in BCD format
I2C write myrtc,0,2,register,bcd 'write the new time value to the appropriate register
Sub disp_str(ptr,a$) 'display a string to numinated screen position
Local x, char$
I2C write mylcd,0,3,0,ptr,2
For x = 1 To Len(a$)
char$=(Mid$(a$,x,1))
I2C write mylcd,0,3,0,Asc(char$),1)
Next x
Function get_dec() 'get a 2 key decimal value include leading zero
key=getkey()
Loop Until key >= 48
I2C write mylcd,0,3,0,key,1 'display key
left = (key-48)*10
key=getkey()
right=key-48
get_dec=left+right 'combine digits
End Function
Function get_bcd() 'get 2 key BCD value include leading zero
key = getkey()
Loop Until key >= 48 'i.e, a number
left = (key-48)*16
key = getkey()
Loop Until key >= 48 'a number
right = key-48
get_bcd=left Or right 'combine digits
End Function
David M.
BobD
Posted: 05:55pm 10 Mar 2014
  atmega8 said   Here an Example of how to write to the DS3231.
Dim RBUFF(10)
Sekunden = 55
Minuten = 59
Stunden = 23
I2C OPEN 100,100
I2C close
The I2C write command to a DS3231 needs to have a pointer to DS3231 register 0 followed by the data. This makes it impossible to use an array to write the data unless the register pointer is in the first used array index followed by the data in subsequent contiguous indexes.
This is either a bug, a feature or a limitation (select one) of the MMBasic I2C implementation.
Example: this works
dim array(7) length 2
I2Cen
I2Csend &H68, 0, 7, array(0)
I2Cdis
Example: This does not work
I2Cen
I2Csend &H68, 0, 8, 0, array(0)
I2Cdis
It gets an error
Error: Insufficient Arguments
It seems it is not possible to mix non arrayed variables or constants with arrayed variables in an I2Csend command.
I have used the MMBasic I2C commands because I tested on MMBasic v4.4. It seems that Dietmar has run into similar problems with MicroMite basic.
Edited by BobD 2014-03-12
Posted: 06:33pm 10 Mar 2014
Example: this works
I2Cen
I2Cdis
I2Cen
I2Cdis
It gets an error
I am surprised that this line didn't give an error:
LENGTH is only valid for string arrays.
According to the MicroMite manual, You can send data as either individual bytes OR a one dimensional array (but not mixed)
You can start the data in the array from any position in the array.
This is valid:
dim mydata(10)
I2Csend &H68, 0, 7, mydata(2)
which would send 7 bytes starting at mydata(2)
MOBI
Posted: 06:41pm 10 Mar 2014
In the second example, the array is set to 7 but 8 bytes are being sent. Wouldn't this throw an error?
David M.
BobD
Posted: 06:54pm 10 Mar 2014
  MOBI said   In the second example, the array is set to 7 but 8 bytes are being sent. Wouldn't this throw an error?
Two reasons it didn't happen is the mixed variables bombs it first but if mixed variables were allowed then it is legit because all after the length is data including the 0 preceding the array. It is the address of register 0 of the RTC.
     Page 2 of 3
