Local Time 03:06 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Good Tips
norcold
Posted: 10:27pm 13 Sep 2012
Wind Turbine braking- On 3phase side use a 10 amp (or lower if you can get) 3phase circuit breaker, if will trip and put your turbine back under load(battery charging) before the current harms your windings.
Vic
Posted: 12:22am 14 Sep 2012
Norcold,
That sounds like a dangerous method to me, as you dump should be your controlling factor not your battery.
The thing saving your mill from a runaway should be your dump load and under no circumstances should you be unloading the mill to the battery because the dump current went up.
Sorry to say i think its a "Bad tip"
This would be better placed in the "Windmill" section and open for debate, rather than as a general tip.
norcold
Posted: 08:04am 14 Sep 2012
To clarify talking about 500 watt turbines, drop in the ocean into 1000a/hr batteries in my case and I suspect in most 4m members case. With two of them at full output would hardly run the fridges. Works for me, has done for years. Sorry Downwind I`ll have to agree to disagree with you here. K.I.S.S
Edited by norcold 2012-09-15
Vic
Posted: 02:01am 15 Sep 2012
Norcold,
Lets just say its a method that suits your application and no what i would consider sound advice for a general windmill application on a broader scale.
I dont wish to discuss it further in this thread as a general tip because there is dedicated areas on this forum for such topics.
Pete.
