Local Time 05:22 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) DuinoMite-eMega is complete
Olimex
Posted: 01:31pm 28 Jan 2012
loading the modules in PIC flash at execution time? you know the 1000 times flash erase/write
Posted: 04:47pm 29 Jan 2012
Well, that's worst case but version B (or indeed version A) of the MMBasic code could just check the flash to see if the code was identical and if so not actually reflash. Just set a pointer or two.
This just isn't rocket science :)
Better ruin an occasional board than not have the feature. No-one has to use the feature if they don't wish.
I'm semi-tempted but put off by the closed-source issues so will leave it to someone else.
JohnEdited by JohnS 2012-01-31
ernie
Posted: 11:53am 01 Apr 2012
  Olimex said   dynamic linking would require OS
probably you have seen Sergey's posts here on TBS he is running the RetroBSD project and told me that he made the assembled and linker running on DuinoMite, but he is out of memory to fit the C compiler, his idea is to make stand alone UNIX computer with DuinoMite with keyboard and VGA same way as it's done in BASIC now.
With the new MOD-VGA with 32MB of RAM he will have plenty of RAM for his project and he may move forward, so if Sergey can complete this DuinoMite will have UNIX and will be able to compile/link C without need of PC
I installed RetroBSD on a Duinomite mega today, quite impressive. The onboard C compiler is working, even had assembler, a small BASIC, and forth interpreters. Still a code hackers platform, not ready for prime time, but great fun. Some of the ported unix commands:
# cd /bin
# ls
[ col head nice rz test
adb comm hostid nm sb time
adc-demo cp hostname nohup scm touch
aout cpp id od sed tr
apropos date iostat pagesize setty true
ar dc join passwd sh tsort
as dd kill portio size tty
awk df la pr sl uname
basename diff last printf sleep uniq
basic du ld ps sort vi
bc echo ln pwd split vmstat
cal ed login ranlib strip w
cat egrep lol rb stty wall
cb expr ls re su wc
cc false mail renice sum whatis
chflags fgrep make renumber sx whereis
chfn file man retroforth sync who
chgrp find med rev sysctl whoami
chmod forth mesg rm sz write
chpass fstat mkdir rmail tail xargs
chsh grep more rmdir tar
cmp groups mv rx tee
Edited by ernie 2012-04-02
Olimex
Posted: 02:28pm 01 Apr 2012
wow Sergey done nice progress, I didn't check for a while this project but will have look at it now
do you know if Sergey implemented some kind of drivers to access GPIOs under RetroBSD?
ernie
Posted: 08:28pm 01 Apr 2012
  Olimex said   wow Sergey done nice progress, I didn't check for a while this project but will have look at it now
Yes, you can see in that list a program called portio, it calls the api.
The GPIO documentation is here http://retrobsd.org/wiki/documentation-2/kernel-drivers/gpio /
You can also access the ADC http://retrobsd.org/wiki/adc/ Edited by ernie 2012-04-03
Olimex
Posted: 02:58pm 21 Apr 2012
Just to notify you first: DuinoMite-eMega is now in stock!
and I just merged on GitHub the Stanimir's eMega firmware changes to the main DuinoMite firmware.
with conditional compiling you can build different HEX's for Mini/Mega and eMega
for more convenience I made FIRMWARE folder with the pre-built HEXs
Posted: 09:14pm 22 Apr 2012
I think you mean
https://github.com/OLIMEX/DuinoMite/tree/master/SOFTWARE/FIR MWARE
edit: why does this board add spaces and re-add them even if you edit them out? crazy
(you need to strip it/them back out)
JohnEdited by JohnS 2012-04-24
donmck
Posted: 10:03pm 22 Apr 2012
  JohnS said   I think you mean
If you use the to format the link, you should be right John.
It adds the space to the text shown, but correctly formats the URL, so that the user can click on it and have it link.
Cheers Don...
https://www.dontronics.com
Posted: 10:09pm 22 Apr 2012
Thanks Don. John the spaces are added to make the site more secure. It stops someone inserting worms/trojans/etc into their post. By inserting random spaces into long strings, it breaks any malicious code. It can be a problem when adding links, but I would rather be more secure.
Posted: 03:23pm 23 Apr 2012
Thanks, guys. I don't think I've used a site that doesn't auto-format links before!
