Local Time 02:46 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : cutting circlip groove in hardened steel
yahoo2
Posted: 03:02pm 27 Nov 2011
Hi bob
No, they wont be cheap and probably will snap the blades off like carrots.
The best tool I ever had was a large piece of tungsten shaped like a half moon or a woodruff key. I brazed it to a large hex boring bar, used it for removing bulk material inside and out. just sweat it off with the oxy to sharpen it then stick it back on with a piece of sandwich braze sheet. Like rastus says for general machining you cant beat the higher grade of HSS and a quality shaping wheel. Some homemade angle templates for the grinding wheel are handy, a tool with good clean angles will do a lot of work before it needs resharpening.
yahoo
Rastus
Posted: 10:46am 28 Nov 2011
Hi Bob,
The toolpost grinder sounds ideal for the job and yes,you read my mind with the cross slide.I'm getting to the stage I don't say what I mean,and don't mean what I say Fortunately I have a younger brother who is a fitter & turner,the only snag is he lives 240 miles away.It seems Yahoo can easily justify the cost of tooling.Youch!$1000 for the shaft assembly.I don't have a lathe ect.because of the outlay and consumables.You've probably become more resourcefull out of neccessity and experience.Cheers Rastus
Posted: 02:31am 02 Dec 2011
I have a lathe and now have a tool post grinder for it as well.
Any sort of sharp edged tool is not going to work on a hardened shaft, grinding is the only way.
You can get very narrow cutting wheels (made for angle grinders), some of those are only 1mm thick.
A small diameter abrasive cutting wheel worn down to minimum diameter mounted in a tool post grinder would cut a very clean groove with a pit of patience so the shaft is not overheated.
This is a 5" cutting wheel 3/32" thick (2.38mm) I just happen to have here, but they are available much thinner.
curiosity
Posted: 10:08am 08 Jan 2012
you can turn bearings with carbide lathe tips I've done it many times. you do need a decent brand tip (sandvik or similar)and spin very SLOW
VK4AYQ
Posted: 12:12am 09 Jan 2012
Hi Curiosity
You must have a very rigid lathe as well not the normal hobby lathe.
Foolin Around
curiosity
Posted: 11:42am 10 Jan 2012
  VK4AYQ said   Hi Curiosity
Chinese brand 3 phase. I have the luxury of using an industrial lathe at work but it's not very rigid really. I turn mostly stainless steel on it but on occasion we need to modify bearings slightly to get us out of trouble quickly.
VK4AYQ
Posted: 01:46pm 10 Jan 2012
Hi Curiosity
Must be a good machinist then, a dying breed these days as most are machine watchers and are called machinists.
When I had my workshop going commercially I to did a lot of stainless work in the farm and wine growing industry and also rebuilding paper mill machinery, it is a pleasure to work with the right tooling but I must admit I was never to keen on machining bearing cases, I would set them up and grind them mainly.
Still have most of the machinery but retired now so it gets hobby use only.
All the best
Foolin Around
curiosity
Posted: 09:53am 11 Jan 2012
thanks for the kind words Bob. I wouldn't say i'm a good machinist but i do prefer a challenge. With the introduction of CNC, which I've done very little of, I guess machine watchers are the best you can expect these days
Oscar4u
Posted: 08:28am 12 Jan 2012
Am enjoying your grinding thread.
I made a bracket that clamps in my toolpost which holds a 115mm grinder. Not as good as a proper toolpost grinder, but I am dutch and have a reputation to uphold! Cheers
Oscar
Oscar4u - for all your rotary cowshed repairs
Posted: 08:47am 12 Jan 2012
I have had my lathe for about forty years, but would still class myself as a beginner.
I just don't use it often enough to be a serious lathe addict.
But by golly it really comes in handy sometimes.
It seems to me, a very big part of lathe work is coming up with really cunning and devious ways to do rather unusual things with very limited resources.Edited by Warpspeed 2012-01-13
VK4AYQ
Posted: 10:01am 12 Jan 2012
It is all good fun and really satisfying when you make something that works.
Foolin Around
