Local Time 01:24 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Through a UART
seco61
Posted: 10:07pm 12 Jul 2011
Hi Don.
You are correct in your interpretation of how communication to the PCF8563 is handled.
The issue is that pins 4 and 5 are already in use by the SPI 2 module.... and that is not I2C.
That is why I (and Ken) have used the I2C 1 module as the pins (MCU 43 and 44) are available on the I/O connector and over-riding the pin 12/13 functonality is relatively easy.
regards
Gerard
Gerard (vk3cg/vk3grs)
donmck
Posted: 10:32pm 12 Jul 2011
  seco61 said   Hi Don.
regards
Gerard
Thanks Gerard, then it is beyond my scope to make a suggestion, so I have informed Richard of this thread and contents. Best he is aware of the problem.
Cheers Don...
https://www.dontronics.com
Tecc
Posted: 11:52pm 12 Jul 2011
Yes those pins were set aside to talk to the Real-time clock.
Not using internal I2C module of the PIC, but bit-bashed I2C implementation using the pins as digital IO.
Data and clock can be implemented using digital IO bit bashing.
I2C as we know is not synchronous, and stuff can be clocked in and out at almost any speed.
Yes, the clock chip has a set of I2C 'Registers' that can be Set and Read using the 2 wire I2C
i.e the code is similar to found here
http://en.wikipedia.org/wiki/I%C2%B2C
This has not yet been implemented...
Richard
seco61
Posted: 01:00am 13 Jul 2011
Hi Richard.
I do not believe that pins 4 and 5 are available for digital I/O as the SPI 2 peripheral is active (it is used by MMBasic for video generation) and therefore pins 4, 5, 6 & 8 have been "taken over" by the SPI peripheral module.
regards
Gerard
jebz
Posted: 10:49am 13 Jul 2011
  seco61 said
I see that Richard is indeed using pins 4 and 5 for his I2C interface (I2C 4) to the PCF8563.
To use those pins for I2C, the video "subsystem" would have to be stopped as they are also part of the SPI 2 module.
The video may be interrupted if you read the clock before the video system starts. This while not providing the most accurate use of the clock would be convenient as the internal clock function used by MM basic would be running very close to time most of the time.
jebz
Posted: 10:59am 13 Jul 2011
  ksdesigns said   Im about done with my i2c to serial adapter .. it uses a pic12f1822 about 1.40$ from digikey and you can probably get free samples from microchip
its a 8pin chip so 2 for i2c 2 for serial and 2 for onewire
if i get around to it will also write some basic code to program it from the maximite
ken
Have you completed your pic12f1822 i2c to serial converter? Would you share your code say on Don's file drop box.
aargee
Posted: 10:38pm 14 Jul 2011
For those interested in Serial Bluetooth comms...
Looky there
Have a a close look at the title, and try and think how you would mount it..
- Rob
donmck
Posted: 10:51pm 14 Jul 2011
  aargee said   For those interested in Serial Bluetooth comms...
Looky there
- Rob
Arduino Shield?
Is there a current UART and Bluetooth, to Arduino Shield available already?.
This may be the simple answer to mounting it.
Cheers Don...
seco61
Posted: 11:34pm 14 Jul 2011
You will also require the ability to interact with the RTC device to set the date, time etc. This will require the video to be stopped, the pins reconfigured for I2C or GPIO and bit-bashed, and then re-initialised.
While this can be done, it will require changes to the video code.
regards
Gerard
aargee
Posted: 01:14am 15 Jul 2011
Looky there
- Rob
Arduino Shield?
Cheers Don...
Actually, Don, I was suggesting something more gutter-ish. After all it is an Anal Interface board.
- Rob
elproducts
Posted: 09:50pm 15 Jul 2011
Looky there
- Rob
Arduino Shield?
Cheers Don...
YES, several. Here are examples.
RS232 Shield
BlueTooth Shield
There is a list of links to shields at the link below.
Shield List
www.elproducts.com
donmck
Posted: 10:12pm 15 Jul 2011
Shield List
Thanks Chuck, WOW, love the way they do the pin out table for each individual shield, see:
http://shieldlist.org/luke-weston/pebblehttp://shieldlist.org/luke-weston/pebble
Obviously the way to travel, and I will follow suit, and also have a big peruse through all of them there shields.
Cheers Don...
