Local Time 03:10 12 Nov 2026 Privacy Policy
Forum Index : Windmills : PicLog finally updated, Ver 1.2
Posted: 10:17am 26 Feb 2013
I'll look into the 28X2 to see if it should work. Just a bit tied up at the moment, give me a couple of days.
The PIC16F873A wont work, its not programmed with the PicAxe boot loader.
scnarine
Posted: 09:11am 27 Feb 2013
Hello Glen,
I was able to program a PICAXE-28X1 (PIC16F886) successfully with your version 1 code. In order to use the PICAXE-28X2 (PIC18F25K22) I use the PICAXE wizard in the programming editor to X2 conversion. I do have a problem with the nap command (syntax errors). If I change the nap command to doze I was able to program X2 chip, but I am unsure about the duration of the doze, since for example nap 7 seems to be shorter than doze 7 and I am not sure if doze will be the correct command. Version 2 code you must make sure the LCD is a 20x2 and not a 16x2 as the schematic shows. I missed that point although it was mention on the web page :).
Thanks again Glen.
Sudesh
scnarine
Posted: 05:24pm 20 Mar 2013
I now have a 20x2 LCD but cant get the version 2 code to work on the chip. Version 1 works fine. I am unable to find the PICAXE-28X chip anywhere. Is there a possibility that some one can dump their picaxe chip with the version 2 code and I can try writing that hex code to my PIC16F873A chip and see if that will work? or someone with a revolution programmer convert the version 2 code using the wizard in the program editor. Please help me.
Thank you.
Sudesh
