Local Time 17:42 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Analog Meters On Piclog
oztules
Posted: 10:51am 06 Jun 2010
It's all good development. I like to see this....... (but I still won't use windows )
I agree completely Pete
...........oztules
Posted: 11:13am 06 Jun 2010
Good to see this update apears to fix that old bug. If its still working after a couple of days I'll update the PicLog article with this bug fix and a few other changes.
I've been on the lookout for a cross platform free alternative to VB6. While VB6 is easy to use and has a lot of grunt, its not free, and its no longer available unless you can source a 2nd hand copy. Visual Studio 2005 and 2008 have free versions, but its bloatware to the extreme and not as user friendly as VB6. A cross platform version of visual basic would be great, and I would love to rewrite the PicLog to work on other OS's. The PicLogs text file storage of data is simple and would port to other systems, but com port handling could be a challenge as Windows and Linux treat the com port very differently.
I'll keep looking for an VB6 alternative ( this is where Vasi will hopefully chime in with the answer )
windman1000
Posted: 07:15pm 06 Jun 2010
Ok I Took Glenns Last Subs he posted and put them in the meter piclog and all works good here, so try this and let us know.( Recap) this needs to go in piclog folder and you need the orignal files/folders in that Piclog folder.
And the rpm and the windspeed Meters are posted all the time.
2010-06-07_051430_Meter3.zipEdited by windman1000 2010-06-08
Posted: 01:59am 07 Jun 2010
Windman,
It worked!!!!!!
I did have a few dramas though, as the logger i tested it on was on 240 volt i calibrated it to 240 and it crashed with error 380 till i dropped the voltage value back. (it was off scale)
A few things i noticed is ... it dont show values on the meters unless you are recording...a draw back.
I notice you only have full figures shown for amps and wind etc, and i for one like to see to at least 1 decmial point. I dont care about volts, rpm and watts.
It still has the old problem of ..if you get the com port wrong it locks you out and you need to go into the prog file to change it.
It would be nice to have a high and low scale button on the amp and wind gauges as when there is low readings the needle is close to zero and hard to read.
Otherwise all worked and well done.
Pete.
Ps:- you might want to ask Glenn to edit the earlier Zip files so there is not to many versions posted, and nothing worst than versions that dont work.
Edited by Downwind 2010-06-08
vasi
Posted: 07:18am 07 Jun 2010
Hi guys,
Commercial alternatives
1. If there are possibilities, then I strongly recommend the PowerBasic (Windows and Dos) for his performances and the impressive list of customers (and, as a personal reason, because is the successor of Turbo Pascal from Borland). Read about it on his site.
Price: Good
- Site
- Customers
2. Second, I recommend PureBasic as cross platform solution (Win, Linux, Mac, Amiga), with a huge list of 1100+ internal commands and also great compiler results (very fast and compact code single executable - no bloatware, no additional dll's or runtime's).
- Site
- Screenshots
Price: Very good
Code example (Serial port on both systems, Win and Linux):
[code]
; PureBasic - SerialPort example file
; (c) Fantaisie Software
CompilerIf #PB_Compiler_OS = #PB_OS_Windows
Port$ = "COM1"
CompilerElse
Port$ = "/dev/ttyS0"
CompilerEndIf
If OpenSerialPort(0, Port$, 300, #PB_SerialPort_NoParity, 8, 1, #PB_SerialPort_NoHandshake, 1024, 1024)
MessageRequester("Information", "SerialPort opened with success")
Else
MessageRequester("Error", "Can't open the serial port: "+Port$)
EndIf
[/code]
Yes, this is the only difference regarding to Serial Comm. ports (the string which designate the serial comm port) between Linux and Windows and this is true also for other cross platforms languages (C++, Freepascal, etc.)
3. Another cross platform solution (Win, Mac, Linux) is RealBasic but with not so small resulted executable.
Price: Too expensive
- Site
There is also Liberty Basic but is only for Windows and I don't recommend it because compiled result is poor.
Freeware alternatives
A good cross platform solution (Win and Linux) is FreeBasic 32 bit compiler
- Site
- Gallery
To be continued...Edited by vasi 2010-06-08
Elvish name: Mablung Miriel
Beyound Arduino Lang
vasi
Posted: 08:04am 07 Jun 2010
Considerations about Serial ports on cross platform:
On Linux
/dev/ttyS0 - when is about a physical serial comm. port
/dev/ttyACM0 - when is about USB-CDC Serial
/dev/ttyUSB0 - when is about other USB devices (modems e.g.).
You can see what comm port have been allocated to your device using dmesg console command (when you insert an USB device after the computer initialization or when you reset the board often if you are in development process).
An example. If you reset your device (logger) without closing your terminal console application, then on the next initialization, linux will allocate another virtual device: if it was /dev/ttyACM0, it will be /dev/ttyACM1. You must know this when you restart your PC application. If you reset your board after your PC application closed the serial comm., then at reinitialization, your board will have same device allocated: /dev/ttyACM0
Also, on Windows an USB device have bigger values than the physical serial ports COM1 - COM4 ...
So it is better to have a text input field rater than a combo box (with the required tooltip as help or a neighbor text label as indication for the format of the string [COM1, /dev/ttyS0, /dev/ttyACM0, etc.])... or better an editable combo box.
Vasi
windman1000
Posted: 09:43pm 07 Jun 2010
I Was Looking over Glenns Version 3 Piclogger And Noticed That My MeterLogger Had Old And New Sub Codes So I Redid Everything To Glenns Version 3 And Even Thow I Wasnt Getting Errors This New Meter Version Seems To load Faster.
Glenn Please Delete All Old Meter Downloads I Have Here.
2010-06-08_074247_Meter4.zip
Posted: 01:09am 08 Jun 2010
Yeah I've fixed a couple of the most annoying bugs, the corrupt serial data bug and incorrect com port bug, both which caused the PicLog to crash. I'll add Windmans version of the PicLog and source code later today.
Thanks for the Basic links Vasi, I have a few of the free ones now and will have a play when I get a few free hours.
Posted: 02:04am 08 Jun 2010
Windman,
The meters4 zip did load and run for me.
I also found it can be minimumised on the meters then stretched out to show all meters, and dragged to the bottom of the screen as a tool bar.
Much better than a large Green screen, but still takes up a lot of space.
I have only tested these and have not used them for any length of time in logging to know if they crash with time. As the earlier piclog was prone to do.
Pete.
Posted: 04:00pm 08 Jun 2010
Hi windman,
have finally had another chance to try and run the revised piclog programs.
I managed to start with the revised piclog from Gizmo.
I then copied the meter version to the same directory, that the working piclog was in. Once the calibrations had been set up, the meter version would run.... for a bit, before crashing with a runtime error 5. I also had the error 380 come up as well.
I think there may still be problems with data types within the program.
I hope you sort it so the meters that are displayed, reflect the options chosen in the setup as well.
Gordon.
Posted: 10:13pm 08 Jun 2010
Hey Gordon, are you using a original PicLog or a modified version that would be sending a different serial stream than normal? I ran Windmans version without any problems on a standard PicLog.
Also, the error codes dont help much, what we need to know is where within the program the error occured. If you have a copy of VB6, you can open Windmans source code and run the program from within VB6, instead of the compiled version. When the program crashes, VB6 will tell you exactly where and why, making it easy to fix the problem.
Posted: 10:30pm 08 Jun 2010
Hi Glenn,
I have just run your code this morning, and you have introduced a timing bug. Even though the logging interval may have been changed, the logging interval stays at the previous timing. You need to go back into the prog setup again and exit for the change to be effective.
The changes you made to the comm routine is similar to my own, and I have not seen an error yet. I did have the comms hang with the update window frozen with all zero's for data. I had to press the calibrate button again. I don't close and reopen the comm port during the calibration, but leave the comms open and share the variables. The only time I close the comms, is during the port discovery routine, and upon program exit.
I don't have any source code for windmans program so I can't run it in the VB editor to check anything.
Gordon.
vasi
Posted: 11:42am 09 Jun 2010
  Gizmo said  Thanks for the Basic links Vasi, I have a few of the free ones now and will have a play when I get a few free hours.
Welcome and please keep us updated about your evaluation/conclusions (maybe in another topic if you consider it is the case).
Vasi
windman1000
Posted: 09:15pm 09 Jun 2010
I have 2 new version 1 version is a better coding of the the set i posted here and the other version has 50 scale wind meters for the guys that do wind m/s.
I also figured out why the 380 error shows up, if your calibration setting are below or above The meter scales then you get the 380 error, ( example amp meter is scales for 100 so if you open the meter piclog and you are off scale say 101 amps or-1 amp you get the 380 error)
you can fix this by opening Glenns piclogger look at what readings you are getting and calibrate it there, or get the source code and change the scales.
any way here are the newer versions
2010-06-10_071525_wind_scale_50.zip
2010-06-10_071550_Wind_scale_100.zip
niall1
Posted: 10:18pm 09 Jun 2010
hi Windman
i tried out your latest download version on 48v and it seems fine ..i need to let the
batts run down a little to watch the voltage readings but the pic seems to
be tracking the voltage well...
i,m running the pic cct off 12v from one battery , the sample 48v is tapped separately
the 39k resistor is changed to about 70k...this gives a reading of about 4v to the pic
pin at full battery voltage ....this is kind off suck it and see ...maybe i could change the clamp zener to 5v1 if a little extra headroom was needed...was wondering about that by what was discussed in previous posts ......
at the moment i,m just using the anemometer and battery v functions
very nice to see analogue meters as an option , there pretty easy on the eye
nice work to all concerned ....
niall
VK4AYQ
Posted: 12:00am 10 Jun 2010
Hi All
You guys are doing a great job sorting this out, I like analogue gauges for scan checking and digital for logging accuracy so this is a great way to go. keep up the good work
All the best
Foolin Around
