Local Time 07:03 12 Nov 2026 Privacy Policy
Forum Index : Windmills : COFAZING AC AT MAST
Posted: 02:42pm 31 May 2010
Bob,
The aluminium was used to protect the coils when filing the stator to decog it, not to repair it.
Whats the saying .....??... little bit of prevention is worth a whole lot of cure...or to that effect??
Pete.
GADGETS
Posted: 02:51pm 31 May 2010
Hi bob I just grazed it. so a little bit of laq should be ok. Not greatly worried about it as it is pretty crappy. lots of cracks in the plastic. if u cut a piece of aluminium a bit wider than the depth of the coils, you can then fold it in a shape, leaving the open end a bit wider than the coils ( so u can squeeze it in gently by pressing it slightly) it will cover the coils nicely. Hope that clears it.
VK4AYQ
Posted: 02:52pm 31 May 2010
Hi Pete
Thanks for that to late at night to think of the obvious.
All the best
Foolin Around
VK4AYQ
Posted: 02:56pm 31 May 2010
Hi Gadget
Thank you to now I understand, also don't forget to give the whole thing a few coats of two pack estapol to seal it all up before you put it up.
All the best
Foolin Around
