Local Time 07:55 12 Nov 2026 Privacy Policy
Forum Index : Windmills : need help
DTV004
Posted: 12:10am 27 Sep 2009
hi GWaTPE, ok i will rewire one more time to see if produce more volts. the magnets are strong i dont feel no coggin. do you thing will produce more power? at this time is 25v max...
Posted: 02:10am 27 Sep 2009
Hi DVT004,
I am no teacher, but the voltage you are measuring has no current component. The number of turns and the rpm, and the magnet strength and some other factors like air gaps etc determine the voltage. This will not essentially change, however, with a reduced wire length, with physically smaller, more tightly wound coils, the resistance will be lower. This means that more current can be delivered for the same amount of heating in the windings. This will result in a more efficient alternator, with more power getting to the loading.
I will leave it at that.
Gordon.
