Local Time 00:57 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.03.02 betas
     Page 2 of 7
Posted: 05:43pm 28 Aug 2026
Brown out detection is enabled but it monitors DVDD so has no idea if the 3.3V rail is sagging until the dvdd voltage drops at which point the chip goes in to reset.
Posted: 01:36pm 29 Aug 2026
V6.03.01b1 is now available at https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.02b1
It adds whole-array assignment, functions that return arrays, and MM.ERRLINE, on top of the single-element array dimensions introduced in b0. As with b0, please report anything odd — especially in existing programs that have nothing to do with the new features.
The new functionality is available on all versions
Edited 2026-08-29 23:47 by matherp
javavi
Posted: 05:47pm 29 Aug 2026
  matherp said  Not sure what you are asking for. COLOUR MAP works in mode 1
I would like the MAP(N) function to also work in MODE 1
So that the following example can work the same in all modes (1,2,3)
For N=0 To 15
 Color Map(N)
 Print "COLOR",N
Next
Currently using this function in MODE 1 produces an Error: Invalid for Mode
And I don't understand why this function shouldn't work and pass its values ​​for MODE 1
Edited 2026-08-30 03:50 by javavi
Posted: 07:29pm 29 Aug 2026
It doesn't - never has. I'll look at it but no promises
toml_12953
Posted: 10:21pm 29 Aug 2026
Thank you for the latest change - allowing a function to return an array.
Although not stated anywhere, a function's dimensions can be made dependent on the calling array. This is important. It eliminates the requirement for a different function for every size array used.
Example:
FUNCTION INVR(N()) AS FLOAT(BOUND(N),1),BOUND(N(),2))
 MATH M_INVERSE N(),INVR()
END FUNCTION
OPTION BASE 1
DIM A(3,3)=(4,5,6,2,8,5,7,2,1)
DIM C(BOUND(A(),1),BOUND(A(),2))
C()=INVR(A())
MATH M_PRINT C()
This will work with no change to the function even if the dimensions of a() change.
Again, thank you!
Edited 2026-08-30 08:22 by toml_12953
Footnote added 2026-08-31 21:29 by toml_12953
Of course line 1 of the snippet should be
FUNCTION INVR(N()) AS FLOAT(BOUND(N(),1),BOUND(N(),2))
disco4now
Posted: 01:44am 30 Aug 2026
I have not looked at the source but the CRC12 calculation is giving a different result to earlier versions.All other MATH stuff seems OK
test_math_crc8,crc12,crc16,crc32:                              FAIL (1/6)
   6: Assert equals failed, expected &h0000FEFB but actually &h00000EFB
Sub test_math_crc()
local a$="123456789"
assert_hex_equals(&h29b1, math (crc16 a$,len(a$),,&hffff))                             'CRC16-CCITT
assert_hex_equals(&h4b37, math (crc16 a$,len(a$),&h8005,&hffff,0,1,1),8)               'CRC16-MODBUS
assert_hex_equals(&h31c3, math (crc16 a$,len(a$)),8)                                   'CRC16-XMODEM
assert_hex_equals(&ha1, math (crc8 a$,len(a$),&h31,,,1,1))                             'CRC8-MAXIM
assert_hex_equals(&hcbf43926, math (crc32 a$,len(a$),,&hffffffff,&hffffffff,1,1),8)    'CRC32
if mm.DEVICE$="ARMmite F407" then exit SUB
 assert_hex_equals(&hfefb, math (crc12 a$,len(a$)),8)                                'CRC12
Edited 2026-08-30 11:49 by disco4now
Footnote added 2026-08-30 13:47 by disco4now
I see the source has this comment.
crc &= 0x0FFF; // the CRC register is only 12 bits wide
Does this mean latest is probably the correct version for CRC12 ?
F4 H7FotSF4xGT
Posted: 06:19am 30 Aug 2026
  Quote  Does this mean latest is probably the correct version for CRC12 ?
Yes, the original was wrong 16-bit answer for a 12bit CRC
Posted: 07:19am 31 Aug 2026
@toml_12953: good catch, I've added this information to the manual which has been updated on the release.
Edited 2026-08-31 17:19 by matherp
fred777
Posted: 12:13pm 31 Aug 2026
Fantastic MM.ERRLINE works great!
Many thanks and cheers!
Posted: 08:11am 02 Sep 2026
Hi Peter,
I feel free to suggest a feature for 60302 since we are in beta anyway.
After adding another DO : LOOP to an already existing game, to flush the inkey$ buffer, improving game playability through console, I feel free to suggest:
a$=inkey$    'classic use of inkey$, returning the character at read pointer
a$=inkey$,f  'new, flush buffer (read pointer=write pointer), then return character at read pointer (the last valid character)
I know it is easy to flush the buffer from MMBasic, done it many times, but by having this feature, it makes keyboard handling much easier. And without specific code for keyboard types (PS2 / USB / console).
Edited 2026-09-02 18:13 by Volhout
Posted: 08:21am 02 Sep 2026
The idea is good but the syntax makes no sense. inkey$ is an example of the function that takes no parameters so there is no way to parse your suggestion. You could consider inkey$(f) but that would break every program using inkey$ as they would then need changing to inkey$()
The correct solution would be a new function inkeyf$ but then we run into the function count limit so that is a non-starter.
Posted: 08:47am 02 Sep 2026
No problem,
The MMBasic code to flush the buffer is simple enough.
And only needed for console control, since USB and PS2 can use KEYDOWN, that flushes the buffer also (keeping the last 6).
terekgabor
Posted: 09:53am 02 Sep 2026
How you can flush the buffer from MMBasic?
G@bor
Posted: 10:01am 02 Sep 2026
You can use this to get the last key pressed when calling.
It is not tied to a keyboard type, or console, just empties the generic input buffer and returns the last valid key..
function lastkey$()
 local k$=""
 do
   lastkey$=k$
   k$=inkey$
 loop until k$=""
end function
Edited 2026-09-02 20:03 by Volhout
terekgabor
Posted: 11:03am 02 Sep 2026
Thanks!
toml_12953
Posted: 11:09am 02 Sep 2026
Would it be possible to add optional parameters to function and sub calls?
On a riskier but related note, would it be possible for a function to see the size of an array on the left side of an equal sign - like this? EXTERNAL would take its array size from the left side of the equation so IDN with no parameters would adjust automatically to whatever size the left side array was.
OPTION BASE 1
FUNCTION IDN(N()AS external,optional) AS FLOAT(BOUND(N(),1),BOUND(N(),2))
 LOCAL ROW,COL
 LOCAL TEMP(BOUND(N(),1),BOUND(N(),2)
 FOR COL=BOUND(N(),0) TO BOUND(N(),1)
   FOR ROW=BOUND(N(),0) TO BOUND(N(),2)
     IF COL=ROW THEN
       TEMP(COL,ROW)=1
     ELSE
       TEMP(COL,ROW)=0
     END IF
   NEXT ROW
 NEXT COL
 IDN() = TEMP()
END FUNCTION
DIM A(3,3)
A()=IDN()
MATH M_PRINT A()
1.0000     0.0000     0.0000
0.0000     1.0000     0.0000
0.0000     0.0000     1.0000
Edited 2026-09-02 21:12 by toml_12953
Posted: 02:22pm 03 Sep 2026
V6.03.02b2 is now available on https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.02b2
This includes an update to TinyUSB v0.21 which allows faster access to USB flash drives.
ville56
Posted: 04:34pm 03 Sep 2026
Peter,
b2 seems to be about 7% slower than b1. Tested with PicoMite MMBasic RP2350B and the KnivD benchmark with "Option tracecache on 128".
Gerald
73 de OE1HGA, Gerald
JanVolk
Posted: 08:35pm 03 Sep 2026
Things go wrong with the PicoMiteVGA MMBasic USB RP2040 Edition V6.03.02b2 as soon as I plug in the USB dongle for the keyboard and mouse.
If I unplug the dongle, the VGA display returns to normal, and control is limited to the serial console.
Even erasing the 16MB flash using universal_flash_nuke.uf2 doesn't help. You have to wait about a minute for the process to complete; this is normal for 16MB flash—and also for the RP2350A0A4 with 16MB flash—due to the low baud rate.
Jan.
> option list
PicoMiteVGA MMBasic USB RP2040 Edition V6.03.00RC21
OPTION SYSTEM I2C GP16,GP17
OPTION FLASH SIZE 16777216
OPTION COLOR CODE ON
OPTION MOUSE SENSITIVITY 1.0000
OPTION KEYBOARD US
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION SDCARD GP21, GP18, GP19, GP20
OPTION VGA PINS GP11,GP22
OPTION AUDIO I2S GP13,GP15', ON PWM CHANNEL 6
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE
OPTION F1 help
OPTION F5 list commands
OPTION F6 list functions
OPTION F7 list pins
OPTION F8 option list
OPTION F9 fm
OPTION PLATFORM PicoMiteVGAUSB RP2040-PiZero
> option list
OPTION KEYBOARD US
OPTION PICO OFF
OPTION F1 help
OPTION F6 list commands
OPTION F7 list functions
OPTION F9 fm
Copyright 2011-2026 Geoff Graham
Copyright 2016-2026 Peter Mather
> US USB Keyboard Connected on channel 1
*** FAULT PC=1008AE54 LR=10084989 SP=20041DF8 CFSR=00000000 HFSR=00000000
*** FAULT PC=1008AE54 LR=10084989 SP=20041E10 CFSR=00000000 HFSR=00000000
*** FAULT PC=1008AE54 LR=10084989 SP=20041E28 CFSR=00000000 HFSR=00000000
toml_12953
Posted: 10:29pm 03 Sep 2026
  matherp said  V6.03.02b2 is now available on https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.02b2
I'm trying to compile the source for the PicoCalc and getting this:
/home/tlake/picocalc/PicoMite/PicoMite.c:78:10: fatal error: class/cdc/cdc_device.h: No such file or directory
  78 | #include "class/cdc/cdc_device.h"
Any ideas?
     Page 2 of 7
