Local Time 03:18 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Breakout game using TILEMAP
Posted: 04:07pm 13 Mar 2026
No, it was only specifically the RP2040 PIco version because of the size of the A: drive
tenij000
Posted: 08:07am 14 Mar 2026
can do also whit my calc program turn into english give graphics
' PICO-SPREADSHEET V1.7 (FULL VERSION)
' Functies: Auto-Grid, Formulegeheugen, Save/Load, Anti-Crash
CLS
DIM cells(26, 20)
DIM formulas$(26, 20)
fileName$ = "spreadsheet.csv"
' Startscherm met raster
GOSUB ShowGrid
DO
 ' De input verschijnt altijd onder het raster
 INPUT "Opdracht: ", cmd$
 cmd$ = UCASE$(cmd$)
 IF cmd$ = "EXIT" THEN END
 SELECT CASE cmd$
   CASE "CLEAR"
     FOR r = 1 TO 20: FOR c = 1 TO 26
       cells(c, r) = 0: formulas$(c, r) = ""
     NEXT c: NEXT r
     GOSUB ShowGrid
     PRINT ">> Alles gewist."
   CASE "SHOW"
     GOSUB ToonLijst
   CASE "SAVE"
     GOSUB OpslaanBestand
     GOSUB ShowGrid
     PRINT ">> Opgesl*gen in "; fileName$
   CASE "LOAD"
     GOSUB LadenBestand
     RecalculateAll
     GOSUB ShowGrid
     PRINT ">> Bestand geladen."
   CASE "HELP"
     GOSUB ToonHelp
   CASE ELSE
     ' Standaard: Verwerk de formule en ververs het grid
     GOSUB VerwerkFormule
     GOSUB ShowGrid
 END SELECT
LOOP
' --- RASTER WEERGAVE (MET SLIMME KLEUR-DETECTIE) ---
ShowGrid:
 LOCAL col, row, cVal, cStr$, pad, f$, isFormule, i, charCode
 CLS
 ' Print de kolomletters (A t/m E) in geel
 COLOR RGB(YELLOW), RGB(BLACK)
 PRINT "      ";
 FOR col = 1 TO 5
   PRINT "|    " + CHR$(64 + col) + "      ";
 NEXT col
 PRINT "|"
 COLOR RGB(WHITE), RGB(BLACK)
 PRINT "------" + STRING$(60, "-")
 ' Loop door de rijen (1 t/m 10)
 FOR row = 1 TO 10
   IF row < 10 THEN PRINT " ";
   PRINT STR$(row) + "   ";
   FOR col = 1 TO 5
     cVal = cells(col, row)
     cStr$ = CleanString$(STR$(cVal))
     f$ = formulas$(col, row)
     isFormule = 0
     ' --- CHECK: Is dit een berekening of verwijzing? ---
     ' 1. Check op wiskundige tekens
     IF INSTR(f$, "+") > 0 OR INSTR(f$,"-") > 0 OR INSTR(f$,"*") > 0 OR INSTR(f$,"/") > 0 THEN
       isFormule = 1
     ENDIF
     ' 2. Check op letters (celverwijzingen zoals A1, B2)
     FOR i = 1 TO LEN(f$)
       charCode = ASC(MID$(f$, i, 1))
       IF charCode >= 65 AND charCode <= 90 THEN isFormule = 1
     NEXT i
     ' Teken de cel-afscheiding in wit
     PRINT "| ";
     ' Bepaal de kleur van de waarde
     IF isFormule = 1 THEN
       COLOR RGB(CYAN), RGB(BLACK)   ' Formules/Sommen in Cyaan
     ELSE
       COLOR RGB(WHITE), RGB(BLACK)  ' Gewone getallen in Wit
     ENDIF
     PRINT cStr$;
     ' Vul de rest van de kolombreedte op met spaties (in wit)
     pad = 10 - LEN(cStr$)
     IF pad > 0 THEN PRINT STRING$(pad, " ");
   NEXT col
   PRINT "|"
 NEXT row
 PRINT "Typ HELP voor info. Opdracht (bijv. A1=B1+5):"
RETURN
' --- SUBROUTINES ---
ToonLijst:
 PRINT "--- ACTIEVE FORMULES ---"
 LOCAL fnd, rL, cL
 fnd = 0
 FOR rL = 1 TO 20: FOR cL = 1 TO 26
   IF formulas$(cL, rL) <> "" THEN
     PRINT CHR$(64 + cL); rL; " = "; formulas$(cL, rL)
     fnd = 1
   ENDIF
 NEXT cL: NEXT rL
 IF fnd = 0 THEN PRINT "(Geen formules gevonden)"
RETURN
ToonHelp:
 PRINT "--- HELP OVERZICHT ---"
 PRINT "A1=10       : Getal invoeren"
 PRINT "B1=A1*2.5   : Formule invoeren"
 PRINT "SHOW        : Lijst met alle formules"
 PRINT "SAVE / LOAD : Bestand op de Pico opslaan/laden"
 PRINT "CLEAR       : Alles wissen"
 PRINT "EXIT        : Programma stoppen"
 PRINT "Druk op Enter om terug te gaan..."
 INPUT dummy$
 GOSUB ShowGrid
RETURN
VerwerkFormule:
 LOCAL pPos, tR$, fR$, t$, f$, cX, rY
 pPos = INSTR(cmd$, "=")
 IF pPos > 0 THEN
   tR$ = LEFT$(cmd$, pPos - 1): fR$ = MID$(cmd$, pPos + 1)
   t$ = CleanString$(tR$): f$ = CleanString$(fR$)
   ' Controleer op zelf-verwijzing
   IF INSTR(f$, t$) > 0 THEN
     PRINT "!! Fout: Circulaire referentie!"
     PAUSE 2000
   ELSE
     ' Adres bepalen
     cX = ASC(LEFT$(t$, 1)) - 64
     rY = VAL(MID$(t$, 2))
     IF cX > 0 AND cX < 27 AND rY > 0 AND rY < 21 THEN
       formulas$(cX, rY) = f$
       RecalculateAll
     ELSE
       PRINT "!! Fout: Ongeldig cel-adres!"
       PAUSE 1500
     ENDIF
   ENDIF
 ENDIF
RETURN
OpslaanBestand:
 OPEN fileName$ FOR OUTPUT AS #1
 LOCAL rS, cS
 FOR rS = 1 TO 20: FOR cS = 1 TO 26
   IF formulas$(cS, rS) <> "" THEN
     PRINT #1, CHR$(64 + cS); rS; ","; formulas$(cS, rS)
   ENDIF
 NEXT cS: NEXT rS
 CLOSE #1
RETURN
LadenBestand:
 LOCAL rD, cD, kommaPos, rgl$, cl$, fr$
 ' Wissen voor het laden
 FOR rD = 1 TO 20: FOR cD = 1 TO 26: formulas$(cD, rD) = "": NEXT cD: NEXT rD
 OPEN fileName$ FOR INPUT AS #1
 DO WHILE NOT EOF(#1)
   LINE INPUT #1, rgl$
   kommaPos = INSTR(rgl$, ",")
   IF kommaPos > 0 THEN
     cl$ = LEFT$(rgl$, kommaPos - 1): fr$ = MID$(rgl$, kommaPos + 1)
     cX = ASC(LEFT$(cl$, 1)) - 64: rY = VAL(MID$(cl$, 2))
     formulas$(cX, rY) = fr$
   ENDIF
 LOOP
 CLOSE #1
RETURN
' --- REKEN ENGINE (SUB & FUNCTIONS) ---
SUB RecalculateAll
 LOCAL c, r, fStr$, fV$
 ' Twee passes om kettingreacties (C=B, B=A) op te vangen
 FOR pass = 1 TO 2
     fStr$ = formulas$(c, r)
     IF fStr$ <> "" THEN
       fV$ = ParseFormula$(fStr$)
       cells(c, r) = EVAL(fV$)
     ENDIF
   NEXT c: NEXT r
 NEXT pass
END SUB
FUNCTION CleanString$(in$)
 LOCAL i, ch$, rs$
 rs$ = ""
 FOR i = 1 TO LEN(in$): ch$ = MID$(in$, i, 1)
   IF ch$ <> " " THEN rs$ = rs$ + ch$
 NEXT i
 CleanString$ = rs$
END FUNCTION
FUNCTION ParseFormula$(f$)
 LOCAL c, r, cn$, oStr$, vStr$
 oStr$ = f$
 ' Terugwaarts zoeken voorkomt dat A10 wordt gezien als A1 + "0"
 FOR c = 26 TO 1 STEP -1: FOR r = 20 TO 1 STEP -1
   cn$ = CHR$(64 + c) + CleanString$(STR$(r))
   IF INSTR(oStr$, cn$) > 0 THEN
     vStr$ = STR$(cells(c, r))
     oStr$ = ReplaceCell$(oStr$, cn$, vStr$)
   ENDIF
 NEXT r: NEXT c
 ParseFormula$ = oStr$
END FUNCTION
FUNCTION ReplaceCell$(br$, ou$, ni$)
 LOCAL p, res$
 res$ = br$: p = INSTR(res$, ou$)
 DO WHILE p > 0
   res$ = LEFT$(res$, p - 1) + ni$ + MID$(res$, p + LEN(ou$))
 LOOP
 ReplaceCell$ = res$
END FUNCTION
