Local Time 03:10 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : controlling 6 LCD displays with 1 PicoMite
mozzie
Posted: 01:57pm 22 Feb 2026
G'day Gerald,
A novel approach and a brilliant looking setup.
You might like to try cutting up the grey anti-static bag into strips as a filter for the WS2812 LEDs, several layers may be required. Works very well on overly bright power LEDs on all sorts of things here
Lyle.
ville56
Posted: 04:58pm 22 Feb 2026
Thanks for the tip Lyle. Will give it a try. Should have some of the bags somewhere.
73 de OE1HGA, Gerald
ville56
Posted: 03:34pm 23 Feb 2026
attached is the circuit diagram for the display unit as I've built it.
the signal names partial buried under the watermark are:
GND    Ground
Vcc    5V
SCL    serial clock
SDA    serial data
RS     reset
D/C    data/command
CS     chip select
BLK    backlight control
I left RS bus wire floating without any issues so far, it must not (sic !) be connected to the pico if the standard MMBasic "gui reset lcdpanel" init is used for each LCD position. I'am currently reading thru the ST7789 datasheet to find out how to init the displays with poke display commands. Should be a lot faster and seems to be feasable.
For the colons the LED and the WS2812B are interchangeable in my design.
On the software side I still have to do a lot of improvements, so I will post the code in a few days at the earliest. I have a lot of grandpa duties as well    and a doughter-in-law in the wheelchair ....
v.lenzer
Posted: 03:54pm 14 Mar 2026
Hi Gerald!
I'm fascinated by the small displays and wanted to try building a Wi-Fi kitchen clock before replicating your Nixie project. Unfortunately, I haven't been able to get the display to work yet. IF YOU HAVE THE TIME, would it be possible for you to post the options and connection pins for the pico-W with RP2040?
Best wishes! Joachim
ville56
Posted: 06:28pm 14 Mar 2026
Joachim,
here you go:
my options:
WebMite MMBasic RP2350A Edition V6.02.01RC5
OPTION SYSTEM SPI GP2,GP3,GP4
OPTION SYSTEM I2C GP8,GP9
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION HEARTBEAT OFF
OPTION CPUSPEED (KHz) 252000
OPTION DISPLAY 40, 145
OPTION LCDPANEL ST7789_320, PORTRAIT,GP14,GP13,GP15,GP16
OPTION TELNET CONSOLE ON
OPTION SDCARD GP17
the pin usage is documented here:
Clock-Pinout.pdf
you can check the function of the displays easily just by connecting one display to the SPI pins. A simple BOX, LINE or TEXT command should proof the function. But be aware of the offset for the x-axis with 35. If you want I can also post my current code here. It should be easily adaptable to whatever pin usage you choose. But, like all of my code, it is rather overdone    for just serving as a clock as I also did some coding experiments for extended parametrization and debugging capabilities.
BTW: I had the code running not only on the WebMite but also on other types of RP2350 processors. The WebMite is my final solution because I use NTP to synch the date/time. But it can also run with a RTC module or even on the processor xtal alone if you want and don't care about the drift. DCF decoding is still not implemented.
v.lenzer
Posted: 12:06am 15 Mar 2026
Hello Gerald!
Thank you very much for answering so quickly and in detail! I hope, I will have success.
As I see, You are connecting GP10  to 15 with the LCD , but in the options for the LCDpanel You are using GP14 to 16. Is this ok?
Edited 2026-03-15 10:18 by v.lenzer
v.lenzer
Posted: 12:31am 15 Mar 2026
Hello Gerald!
It's working!!
I just changed to OPTION SYSTEM SPI GP10,GP11,GP12
Thank You once again!
ville56
Posted: 06:49am 15 Mar 2026
sorry Joachim, my bad, misleading information.
The initial idea was to have a seperate SPI bus for the lcd panels but it turned out this is not possibe with ST7789. My fear was the length of the bus wiring, more than 30 cm, and the load with 6 panels would not work reliably, if at all, and so some HW tricks could be necessary. But it does, even with an SD card connected at the end of the bus. And this lcd SPI pins where still allocated in the docu. I use GP2,3,4 for system spi and GP13,14,15,16 for the rest of the lcd panel signals. GP10,11,12 are not allocated so far.
v.lenzer
Posted: 10:43am 19 Mar 2026
Hi Gerald!
That's absolutely fine. I'm just glad I made any progress at all. I've left my settings as they are. It's a completely different project than the "Nixie" anyway.
ville56
Posted: 09:24pm 19 Mar 2026
Joachim,
maybe it is of interest for you: there are, at least, 2 different methods to init the individual ST7789 LCD panels.
1) is the easy way, but slow
   'secure reset sequence
   gui reset lcdpanel                'perform reset on this display position
   cls                              'remove garbage
2) is the faster way, I figured out by reading through the datasheet
   'fast reset sequence, for details see ST7789 datasheet
   poke display &h01           'swreset (soft reset)
   poke display &h11           'slpout (exit sleep mode)
   pause 120                   'this pause is needed
   poke display &h13           'noron,  set normal display mode on
   poke display &h36, &hC0     'MADCTL, to flip hor and vert sides
   poke display &h3a, &H55     'colmod, 16 bit/px
   Pause 10                    'next needed pause
   poke display &h21           'invon,  invert colors
   if lcd_gamma <> 1 then poke display &h26, lcd_gamma   'set display gamma value
   poke display &h29           'dispon, turn display on
   cls
- the pause statements could be replaced by polling the panel status, but I was too lazy for that
- the lcd_gamma value can be 1,2,4 or 8 and changes the gamme of the display (what a surprise   ). Can be useful to enhance the readability of the display, depends on the quality of the picture data.
- With the MADCTL command you can setup any orientation you like. But it should be the same as in the options lcdpanel, otherwise positioning may not work as expected. Mine are OPTION LCDPANEL ST7789_320, PORTRAIT, pins ... for the example above.
- INVON may be needed, depending on the display type (TFT or IPS)
all in all the sequence with the pokes is about 2 to 3 times as fast as the init with gui reset lcdpanel. If you have to init 6 displays in sequence, this is quite a lot faster. The code and the options are for the 170x320 displays that can be bought from several sources for a few bucks.
If you can manage to assert all CS signals in parallel at the same time to the displays I think only one init sequence should be sufficient as there are no input data from the display to the pico. So they just listen to their master. For the individual control individual CS signals are then again necessary. Some additional hardware in excess to the 1:8 demux IC would be needed. E.g. 7 gates ( 6 EXOR for the CS and one of the 4 free outputs from the demux with an inverting EXOR).
v.lenzer
Posted: 12:20pm 20 Mar 2026
Hi Gerald!
You've really delved into this in depth. It's certainly not necessary for my Wi-Fi kitchen clock. But it is for multiplexing the displays. At the moment, I'm only using
OPTION SYSTEM SPI GP10, GP11, GP12
OPTION LCDPANEL ST7789_320, LANDSCAPE, GP14, GP13, GP15, GP16
and in the program, only
CLS and TEXT...
I'm thrilled with these displays. They're just the right size for a clock or measuring instrument display and, unlike the small OLEDs, they can also be used with color.
I'm really looking forward to the NIXIE project. I certainly have enough displays :)
