Local Time 04:43 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How about this for a Christmas surprise?
     Page 2 of 4
karlelch
Posted: 03:59pm 22 Dec 2025
  matherp said  I know the issue. You can't have errors in the pre-processor as each time it calls it it hits the same error and loops. I'm afraid that the fix will be the same as other pre-processor errors which is to delete the program
With your new version, the issue seems to be gone (see above). I was only surprised that nothing helped, not even nuking, except writing an other firmware version. Maybe I don't have the latest nuke? I am using a RP2350B w/ 6MB PSRAM.
karlelch
Posted: 04:01pm 22 Dec 2025
  thwill said
  NPHighview said  * Function (pointers) as struct elements - very useful for callback operations .
You don't actually need that explicitly, or you've already got it depending on your point of view. The pre-existing CALL command and CALL() function already allow you to call a SUB/FUNCTION given its name as a string.Tom
Soon, MMBasic will be fully OO ...
Edited 2025-12-23 02:01 by karlelch
karlelch
Posted: 04:27pm 22 Dec 2025
This looks like a small issue:
> list
Option Base 0
Option Explicit
Type TMotor
 vel As Float
 velStep As Float
 newVel As Float
End Type
Type TRobot
 motor(1) As TMotor
 nSteps As Integer
End Type
Dim self As TRobot
Struct Clear self
self.nSteps = 0
Struct print self
self.nSteps = self.nSteps +1
Struct print self
Inc self.nSteps, 1
Produces a syntax error:
TROBOT:
 .MOTOR = TMOTOR:
   .VEL = 0
   .VELSTEP = 0
   .NEWVEL = 0
 .NSTEPS = 0
TROBOT:
 .MOTOR = TMOTOR:
   .VEL = 0
   .VELSTEP = 0
   .NEWVEL = 0
 .NSTEPS = 1
[23] Inc self.nSteps, 1
Error : Invalid syntax
Posted: 04:35pm 22 Dec 2025
Slowly but  unaviodable all languages merge.
Posted: 05:32pm 22 Dec 2025
Attached is a complete set of the RP2350 firmware with structures implemented. This also fixes the "INC" bug and a number of similar issues. Also it makes changes to avoid pre-processor errors looping without clearing the program.
PicoMiteRP2350V6.01.00EXP.zip
NB: structures will not be implemented for the RP2040 - too much code.
Edited 2025-12-23 03:32 by matherp
toml_12953
Wow! Thanks, Santa! (Peter)
ville56
Posted: 05:59pm 22 Dec 2025
Peter,
there seems to be a strange memory leak.
Just after rebooting the pico the heap seems to get smaller and smaller without any program have been running. PSRAM or not does not make any difference, the heap shrinks.
Example:
PicoMiteHDMI MMBasic RP2350B Edition V6.01.00EXP
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
Total of 6 Mbytes PSRAM available
> print mm.info(heap)
6446336
> print mm.info(heap)
6434048
> print mm.info(heap)
6421760
> print mm.info(heap)
6409472
> print mm.info(heap)
6397184
> print mm.info(heap)
6384896
> print mm.info(heap)
6372608
> print mm.info(heap)
6351360
> print mm.info(heap)
6339072
> print mm.info(heap)
6326784
Edit:
when using no PSRAM I relatively fast get into the following state, looping with
Error : Not enough Heap memory
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
[15] Type Point
only reset clears that
Edit2: the test program has to be loaded, but no need to run it once. Same behaviour after power cycling.
Gerald
Edited 2025-12-23 04:08 by ville56
73 de OE1HGA, Gerald
Posted: 06:09pm 22 Dec 2025
UPDATE
I understand the issue, the leak only happens if you execute multiple commands at the command prompt. If you run the program and then type mm.info(heap) afterwards you will always get the same value as RUN clear memory whereas commands at the prompt don't. I'll put some code in not to re-allocate memory if at the command prompt
Check for something in the library etc. nuke the flash. Doesn't do if for me. List all options too so I can see if I can replicate
Edited 2025-12-23 04:23 by matherp
Posted: 06:37pm 22 Dec 2025
Ignore
Edited 2025-12-23 04:39 by matherp
ville56
Posted: 06:53pm 22 Dec 2025
what I've done:
- nuked flash, loaded V6.01.00EXP, mm.info(heap) is stable
- loaded your test program, ran it once, mm.Info(heap) decreases
- resetting pico, prog loaded but not run, mm.Info(heap) decreases
-typed NEW, mm.info(heap) is stable but a few seconds later entered a boot-loop. After abt 5 reboot in the loop the > prompt came up and heap is stable again.
- copying test program to A: drive via MMCC, LOAD test-program, heap shrinks.
> option list
PicoMite MMBasic RP2350B V6.01.00EXP
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION PICO OFF
OPTION CPUSPEED (KHz) 200000
heap with prog just loaded:
> print mm.info(heap)
302336
> print mm.info(heap)
290048
> print mm.info(heap)
277760
> print mm.info(heap)
265472
> print mm.info(heap)
253184
Edit:
Just loading this short program already shows the heap issue.
Option Explicit
Option Default None
Type Point
x As INTEGER
y As INTEGER
End Type
edit2:
after NEW writing in the editor
type point
end type
saving with F1
is sufficient to start shrinking the heap
Edited 2025-12-23 05:29 by ville56
Posted: 07:39pm 22 Dec 2025
types/structs use heap for their data structures so you will see heap usage even if you define a type but don't use it. This is better than a static allocation because, for a user who doesn't use TYPE, no memory is lost.
The bug was that it re-allocated that memory every time a command was run at the command prompt (not in a program). This should be fixed in the attached.
Edited 2025-12-23 05:40 by matherp
ville56
Posted: 07:45pm 22 Dec 2025
Thank you Peter, heap is now stable.
hhtg1968
Posted: 09:12pm 22 Dec 2025
very cool. i must hurry up to get my picomite computer from jlcp...
Posted: 10:13pm 22 Dec 2025
It hasn't broken any of the programs I have tested with so that is good.
Most of my deployed 'mites will not benefit but structures are something I have wished for many times.
There are a few challenges with highlighting in MMEdit but indenting and code folding works nicely with minor modification.
Good work Santa!
Posted: 10:44pm 22 Dec 2025
  TassyJim said  Good work Santa!
Santa Claude & Zwarte Piet ?
Amnesie
Posted: 11:49pm 22 Dec 2025
Hello Peter,
There is a bug with play mp3 again (in latest version and offical release). When executed it does a reboot + strange behavior.
HDMI /ps2 Version tested from:
EDIT: There is ALSO a problem in the latest offical release, please see the attached video, since the problem with play mp3 isn't constant!
DROPBOX link:
play mp3 problem video
I can confirm that everything works with version:
V6.01.00RC25
PicobMiteV6.01.00RC25.zip
Greetings
Daniel
Edited 2025-12-23 10:23 by Amnesie
TimD
Posted: 12:39am 23 Dec 2025
Oh my days, this is excellent - thank you!  Any chance it can eventually be ported to the CMM2?
Kind regards and Merry Christmas,
Tim.
Posted: 01:55am 23 Dec 2025
hi Peter,
   all very PASCAL like
have just scanned through the thread, it looks like you haven't yet implemented anything like the pascal WITH statement:
Type Person
  age As INTEGER
  height As FLOAT
  name As STRING
End Type
Dim person1 As Person
WITH person1 DO
  age = 42
  height = 1.85
  name = "John"
END WITH
(the use of DO in the context of mmbasic is probably superfluous)
the use of WITH saves on a great deal of duplicated typing and hence consumed flash program space.
rob   :-)
toml_12953
Posted: 04:15am 23 Dec 2025
  robert.rozee said  hi Peter,
Type Person
  age As INTEGER
  height As FLOAT
  name As STRING
End Type
WITH person1 DO
  age = 42
  height = 1.85
  name = "John"
END WITH
rob   :-)
It looks like Peter was going for Microsoft BASIC compatibility. If so, then in that case, you'd type
Type Person
 age As INTEGER
 height As FLOAT
 name As STRING
End Type
 person1.age = 42
 person1.height = 1.85
 person1.name = "John"
Posted: 08:00am 23 Dec 2025
  Amnesie said  Hello Peter,
DROPBOX link:
V6.01.00RC25
Greetings
Daniel
Peter, Daniel,
The problem does not exist in V6.01.00 official release for RP2350 (non HDMI).
So it is either related to HDMI (maybe the resolution chosen conflicts with memory requirements for MP3 play) or the new experimental implementation for structures.
     Page 2 of 4
