Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic n selected sub load global array, odd issue data not stored?
zeitfest
Posted: 12:28pm 22 Nov 2025
I missed the point, I didn't read it in enough depth   .
[  my standard C bug is a conditional test that creeps in when I am tired eg
if (gitchp = 3) dostuff ;
when I should use  '==" instead     . ]   too similar !!
toml_12953
Posted: 04:08pm 22 Nov 2025
  mozzie said  Supertech,
The following works on MMbasic for DOS, not sure if its the best solution:
If N = 3 then IF true = 1234 then Condn(n) = 1 else Condn(n) = 0
Pretty sure someone here will have a better way if you need to test the value of True depending on the value of N every loop. Select case or choose perhaps?
Hope this helps
Lyle.
I'd probably use:
If N = 3 And true = 1234 then Condn(n) = 1 else Condn(n) = 0
Posted: 05:20pm 22 Nov 2025
  toml_12953 said  I'd probably use:
That's what was used and doesn't work (*), for the reasons stated already.
(*) doesn't do what's wanted - MMBasic does work correctly, however
Edited 2025-11-23 03:21 by JohnS
EDNEDN
Posted: 05:38pm 22 Nov 2025
I was surprised nobody considered changing things in this direction:
If N = 3 then if true = 1234 then Condn(n) = 1 else Condn(n) = 0
Ooooops!!!!    Mozzie did suggest this same construct.    My apologies!
Edited 2025-11-23 03:40 by EDNEDN
