Local Time 05:34 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : new rpi 400 os called Trixie
al18
Posted: 09:21pm 17 Oct 2025
Mick,
Sounds like the NUC is a few years old, considering it’s using a 120 GB HD. I would suspect one or more chips are running hot. You could:
1. Boot off a Linux live thumb drive and run sysbench, which can independently stress test the CPU, memory and hard drive https://github.com/akopytov/sysbench
Or
2. Remove the heat sink and/or thermal tape, clean the old stuff off and reapply thermal grease and/or thermal tape
stanleyella
Posted: 09:38pm 17 Oct 2025
back on rpi400, I tried Twister os 3.01 new version. flashed to 120 gb usb ssd but iffy install like wifi key need ~ tild but it not anywhere.
can't find 64bit twister os.
trixie 64bit is good, I'm watching startrek ds9 dvd box set on 64gb pen drive and it's perfect.
so not a waste
note matching kb,mouse usb ssd, and pendrive
Edited 2025-10-18 07:49 by stanleyella
stanleyella
Posted: 10:33pm 17 Oct 2025
I'll leave this. it's a pico forum but folks post linux mint and rpi400 is linux...aaargh!
vlc makes it easy
Posted: 06:36am 18 Oct 2025
It's not a Pico forum, it's a "Microcontroller and PC Projects" forum (see title). Any project using either of those fits in, obviously. It's actually a really broad field. :)
As there isn't a Backshed forum for discussing the hardware of the controllers themselves (PCs or microcontrollers) rather than projects using them then they also come here. :)
TrevorC
Posted: 09:03am 18 Oct 2025
Hi Stan,
The ~ tilde key is next to the Enter key.
Hope this helps.
Trevor
Posted: 10:59am 18 Oct 2025
Symbols can be a pain, Stan.
Are your RPi and keyboard both set to the same language? For English it should be "Generic 101-key PC English (UK)" - use raspi-config. It's usually set to this by default.
Is there a tilde on the keyboard? It should be right next to the Enter key, with the hash symbol.
stanleyella
Posted: 05:23pm 18 Oct 2025
it's the rpi 400 keyboard and in trixie the ~ is shifted # next to enter same as win usb keyboard.
installing twister os 3.01 first blue tooth mouse is enabled but doesn't work so usb mouse and no key acts as ~ which is used in wifi password so no wifi. plugging in usb keyboard doesn't work. I gave up on the latest twister install, it falls over eventually in setup but installs.
64 bit trixie is working fine enough for me to recommend it on rpi400 although I was a twister os fan...
ok tried to install twister os again with usb mouse and it was the same screen too big for 17" display,
the menu button is hidden but got it up and wow! all options so lowered screen res and found ~ is | so wifi working. got bluetooth mouse working.
so many options,
stanleyella
Posted: 06:53pm 18 Oct 2025
this is a test post and screen shot of win10 theme and made stuff smaller.
from rpi400 twister os. er, it was the same as doing it on windows. it was win 10 theme but not work like win 10???
stanleyella
Posted: 07:15pm 18 Oct 2025
should have said it was all done on rpi400 twister os. the screen shot, the forum post image from the screen shot stored in pictures. from rpi wifi.
dunno what, twister again or 64bit trixie   stan
hitsware2
Posted: 09:37pm 18 Oct 2025
  stanleyella said  should have said it was all done on rpi400 twister os. the screen shot, the forum post image from the screen shot stored in pictures. from rpi wifi.
Put them both on thumb drives and switch back & forth with the wind : )
my site
stanleyella
Posted: 12:02am 19 Oct 2025
@hitsware2' got trixie 64  and twister os both on 120 usb3 ssd so swapping easy.
imho trixie is better, well my choice. make your own.
I loaded cura to see speed and wine and 6 other wine things and gparted loads of stuff to test. for a rainy day, looking like twister with lots of apps. themes don't seem a big deal as one nice one.
it's just a smooth pc thinggy
stan
Posted: 07:17am 19 Oct 2025
I don't know what Twister OS is based on, but unless there's been a new version recently I'd guess at Debian 12 (Bookworm). Debian 13 (Trixie) has a lot of updates and changes so I'd expect it to run better.
