Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colossal Cave Adventure Preview/Test Version
Posted: 09:50am 17 Oct 2025
Triggered by Tay's adventure, I found a book online with type-in text adventures.
But this book is in electronic format, and you can simply copy the text, and paste it in MMedit....
The book was written for the Atari 800. And Atari basic resembles MMBasic very much.
After making a few changes (Atari basic allows different variable types to have the same name such as M$ and M%) and adaptation for the speed (they create delays using FOR-NEXT loops) it runs.
Despite the old commands such as GOSUB, GOTO and multibranch GOTO. MMBasic still kept the old commands .. Even IF ... THEN 1000 without GOTO.
Atari_Chateau_Adventure.zip
Have fun..
Tested (not fully) on picomite and MMB4DOS.
Martin H.
Posted: 11:43am 17 Oct 2025
Nice
405 aa$=ucase$(aa$)
to avoid the ">>> CAPITAL LETTERS, PLEASE" message
'no comment
Posted: 12:14pm 17 Oct 2025
Hi Martin,
I knew, and left it since it represents the time this was written. And it is kind of special, since many 70's and early 80's systems did not even have lower case characters as the Atari had. Fixed 2 bugs.
Atari_Chateau_Adventure_BF.zip
Edited 2025-10-17 23:15 by Volhout
zeitfest
Posted: 11:54am 20 Oct 2025
The version I remember playing, had a slightly different intro,
ending with a line about a bird singing in the distance (?).
That would be f77 versions though.. complete with COMMONs..
not sure I want to go there
Martin H.
Posted: 04:21pm 21 Oct 2025
Hi Volhout
  Volhout said  Atkinson was smart. It is much easier to implement in a microprocessor. When I remember correct it's algorithm compensate only forward and downward.
Exactly, you could paint over the source image, as the current point is no longer taken into account. It is only ever inherited by pixels before and below the current pixel.
..,x,+1,+2
-1,0,+1
..,0,
I do this for each color channel, i.e., 3 measurements per pixel. I determine the original value and compare it with the most similar value I can set (for red and blue, it's either all or nothing). The difference from the original value is then divided by 8 and distributed to the neighboring points in the 3 lines of the “ring buffer.” When measuring the points, this value is added to the actual value with the correct sign.
It's a bit like Game of Life. Simple arithmetic operations for each pixel result in the entire processing.
cheers
  Martin
Edited 2025-10-22 02:22 by Martin H.
'no comment
