Local Time 06:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CAN-bus with picomite/webmite and MCP2515, proof of concept
Posted: 11:16am 10 Sep 2025
Hi Arne,
There may still be a little speed gain in:
- changing SPI clock speed from 100k to 1000k.
- changing SPI from 8 bit to 24 bit transfers, and creating "commands".
from
'set receive buffer 0 control register RXB0CRTL to filters for standard identf.
Pin(2)=0:j=SPI(&H02):j=SPI(&H60):j=SPI(&B00100000):Pin(2)=1
to
'defines
const SET_CMD%=&h02<<16
const RXB0CTRL%=&h60<<8
const SET_RXB0%=SET_CMD% + RXB0CTRL%
const RXB0_VAL%=&b00100000
'in the code
Pin(2)=0:j=SPI(SET_RXB0% + RXB0VAL%):Pin(2)=1
You could even look into using SPI WRITE for these non-reading commands, such as opening SPI in byte mode.
DIM a%(2)
a%(0)=&h02:a%(1)=&h60:a%(2)=&b00100000
Pin(2)=0 : SPI WRITE 3,a%() : Pin(2)=1
Edited 2025-09-10 21:19 by Volhout
Posted: 11:40am 10 Sep 2025
I believe the count inputs on the Pico do use a hardware interrupt. All the other accessible interrupts are software and are polled after each command. It may be possible to use a counter.
