Forum Index : Microcontroller and PC projects : WS2812B LED with picoMite questions
AlbertR
Posted: 07:32am 01 Jun 2025
Daniel
I made a new version
because of the time for the loop I made some unrolling and precalculations like the first version. Additional there is a third string for a rest period
LedMatrixR.zip
have fun with it
Greetings
Albert
Amnesie
Posted: 11:01am 01 Jun 2025
Albert,
this is so impressive to see your new video! Currently my ordered modules are on their way to Germany ... so I have to be patient
You connected 5 modules? Do you know what the current draw is? I suppose I have to order an additional power supply for that. But that's not a problem.
Thanks for your updated version, as soon as I tried them out I will report. But it is just amazing to see what MMBASIC is capable of! A lot of fun ahead!
Greetings
Daniel
Edited 2025-06-01 21:01 by Amnesie
AlbertR
Posted: 09:19am 05 Jun 2025
i made an other version loading a bmp directly without display
max. 4 tiles of 8x8 are visible
' get led-data from bmp-file
' 11  4 byte offBits
' 19  4 byte biWidth
' 23  4 byte biHeight
Option DEFAULT NONE
Option EXPLICIT
Dim Integer tmp(8) 'Dim Leds follows later when size is known
Dim Integer lAdr,tAdr
Dim Integer offBits,biWidth,biHeight
Dim Integer x,y,fill,mCnt,lCnt
' sys-init
SetPin GP0, DOUT       'outputpin for the first  ws2812-matrix
'Drive "B:"
Open "MPTeaCup.bmp" For random As #1
 '- read parts of bmp-header
 Seek #1,11                'skip type("BM"),size,reserved
  offBits  = ReadDWord()
 Seek #1,19                'skip headersize
  biWidth  = ReadDWord()
  biHeight = ReadDWord()
 '- read bmp-data
 Dim Integer Leds(biWidth*biHeight) 'Array for bmp-data
 Seek #1,offBits+1         'skip planes, bitcount, compress, ...
 For y = 0 To biHeight-1
   For x = 0 To biWidth-1
     Leds((x*biHeight)+y)= ReadPixel() '3 bytes BGR-values divided by 8
   Next x
   fill = 3-Loc(#1)And 3   'mask last 2 bit to fill up to 4-byte boundary/line
   If fill>0 Then = Asc(Input$(fill,#1)) 'skip dummy-data
 Next y
Close #1
lAdr = Peek(VarAddr Leds()) 'adr of led-data
tAdr = Peek(VarAddr tmp())  'adr of temp-data
mCnt = biWidth*8            'in pixel
If mCnt>256 Then lCnt=256 Else lCnt=mCnt    'max Ws2812 bitbang
'- main loop -----------------------------------------------------
 Device WS2812 B, GP0, lCnt, Leds()        'sys-function
 Memory Copy Integer lAdr,tAdr,8           'copy 1 column(8pix) to temp buffer
 Memory Copy Integer lAdr+(64),lAdr,mCnt-8 'move all from second to last column
 Memory Copy Integer tAdr,lAdr+(mCnt-8)*8,8'copy temp buffer in last column
 Pause 60
'- functions ------------------------------------------------------
Function ReadPixel() As Integer
Local integer Bl,Gr,Re
 Bl=Asc(Input$(1,#1))>>3
 Gr=Asc(Input$(1,#1))>>3
 Re=Asc(Input$(1,#1))>>3
 ReadPixel = (Re<<16)+(Gr<<8)+Bl
End Function
Function ReadDWord() As Integer
Local integer lsb,msb,msb1,msb2
 lsb =Asc(Input$(1,#1))
 msb =Asc(Input$(1,#1))
 msb1=Asc(Input$(1,#1))
 msb2=Asc(Input$(1,#1))
 ReadDWord = (msb2<<24)+(msb1<<16)+(msb<<8)+lsb
End Function
Greetings
Albert
Footnote added 2025-06-05 20:55 by AlbertR
by checking i discover a mistake
must be changed to
If fill>0 Then x = Asc(Input$(fill,#1)) 'skip dummy-data
the bmp-file must be 24bit with a Height of 8 pixel
Amnesie
Posted: 10:35am 05 Jun 2025
Hello Albert,
sadly I am still waiting for my 8x8 matrix from china. At the time I only have a 4x4 matrix. But a 8x8 does make more sense.
It is possible to show an bmp? I didn't expect that to work! Wow! There is a lot I have to play with, as soon as my new modules arrive
Greetings
Daniel
AlbertR
Posted: 11:37am 05 Jun 2025
Hello Daniel,
i made a quick hack and a sample bmp for you for 4x4 display
don't know if it works correct.
Greetings
Albert
AlbertR
Posted: 11:38am 05 Jun 2025
sorry forgot upload
ALedMatrixTests.zip
AlbertR
Posted: 06:44pm 06 Jun 2025
Hello,
I made a new one, now with some layers to implement 3 bmps with different scrolling.
@Bill, I captured the theme of your project, now with scrolling background and falling snowflakes.
LedMatrix.zip
Greetings
Albert
AlbertR
Posted: 08:07pm 12 Jul 2025
Hello,
I expand the matrix to 16x16x3 = 768leds with meandering-connection
It now uses a proportinal font and a gradient color for this is possible.
It based on the first version with scrolling text but get a background-animation.
LedMatrixUpRain.zip
@Daniel
If you have time beside your Gui-Editor
Greetings
Albert
LedMatrix48x16_2.zip
Amnesie
Posted: 09:17am 13 Jul 2025
Hello Albert,
thank you a lot for all your examples and sharing your code with us! I instantly downloaded it, but haven had the time yet to test it, since there is a lot going on with my normal job and then the GUI Editor, I am working on (implementing new features after the CHAIN problem was solved).
But I already have a plan for a project, in which I need your code as a "guidance" (I have no clue at all how to do such cool things like in your program).
I am planning to built some kind of clock with those matrix leds but also with an integrated geiger counter (as always), this is a big hobby of mine (radioactivity measurement devices). I used MMBASIC (vga versions) for those but I feel I need one with an LED matrix, too.
Good that you uploaded a video, too. really impressive!
If I just had more time   But one thing after another...!
Greetings
Daniel
Edited 2025-07-13 19:21 by Amnesie
AlbertR
Posted: 06:32pm 08 Oct 2025
Hi,
since I was already working on it, here is a MorphClock for the WS2812 display.
In the video, there are four 16x16 panels with 3D-printed diffusers.
I think, I hadn't presented the PIO version yet. It now uses DMA, so the controller can do something else during output. All panels are now in a row, i.e., on one pin.
WS2812Clock.zip
Best regards,
Albert
