Local Time 07:18 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite MMBasic GPIO Library v1.0 available
Posted: 12:54am 10 May 2025
  Quote  I wish they would make a dip40 or dip68 (like the 68000) package... (with ALL the gpio's brought out and ditch the on-board noisy regulator. only USB-C , reset and boot button and flash/psram on the qspi). i may have to roll one.... the current boards are wider than a standard DIP40
Not quite what you want but...
They have the same footprint as a standard Pico RP2040 but these have all the GPIO pins, a linear reg, USB-C and 16MB flash. Select the Purple 16M one.
There are many other sellers with this module so it is worth shopping around.
One with a better view of the pins Scroll down to the description.
Edited 2025-05-10 11:05 by phil99
vincenthimpe
Posted: 04:24am 10 May 2025
More something like this : Fits a standard DIP40 socket without overhanging.
PhenixRising
Posted: 03:39pm 23 Jun 2025
Does this mean that we can drive an LED without a current-limit resistor?
  Quote  - control the drive strength of a pin
Posted: 04:13pm 23 Jun 2025
No. It means that you have a safety device to help limit maximum dissipation of the chip. If you drive a pin into current limit the dissipated power has to go somewhere - heat. You shouldn't ever rely on it for anything else.
Also, the "noisy reg" can be a necessity. It's better to design the rest of your system so that it can be used. It dissipates far less heat than a linear. It will let you run a Pico from a 3V7 lithium cell with no issues (the cell protection will cut in before the Pico stops working). That's not possible even using a LDO reg.
3V3 wanted. Dropout voltage 200mV at best. Vfwd of a Schottky diode to isolate from VBUS is about 300mV at best so you need 3.3+0.2+0.3 = 3V8 absolute minimum from the battery.
Edited 2025-06-24 02:22 by Mixtel90
