Local Time 07:43 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Backlight Command
palcal
Posted: 10:00pm 03 Apr 2025
Thanks Phil, I have a Ver1.2 display with Q1 so the fix should be easy.
Maybe a separate version of the firmware for audio or have the Backlight like the PWM command where you can stipulate frequencey and %.
Edited 2025-04-04 10:10 by palcal
Posted: 02:44pm 04 Apr 2025
I'll change the backlight command to allow you to optionally specify the frequency. The default will still be 50KHz on powerup
BACKLIGHT 50 [,freqinHz]
palcal
Posted: 08:35pm 04 Apr 2025
Thanks Peter
palcal
Posted: 03:16am 25 May 2025
Peter changed the Backlight command andit works ok in WebMite V6.00.02RC10 but
in thelatest version of the PicoMite firmware V6.00.02RC24 it no longer works.
palcal
Posted: 04:51am 25 May 2025
Hold the phone, I think there may be aproblem with my board, PWM no work either.
Posted: 05:16am 25 May 2025
Yes, you must have an issue there.
Tested V6.00.02RC24 and "backlight 50,1000" produces 1kHz at 50% on the backlight pin.
palcal
Posted: 02:18am 27 May 2025
Thanks Phil, yes a mosfet problem, all sorted.
