Local Time 09:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 'flags' in interrupt routine
PhenixRising
Posted: 07:57am 06 Mar 2025
  Volhout said
a%=pin(gp0)
if a% then
if pin(gp0) then
Posted: 08:50am 06 Mar 2025
Even better...
Posted: 10:51am 06 Mar 2025
  JohnS said  Unless you're desperate for every byte of memory just (KISS) use one variable per flag. Easy to read, easy to write, easy to maintain, easy to reuse.
It'll be much faster than some of the stuff just posted, too, especially in the interrupt routine.
arghh!!! it burns! IT BURNS!!!
Quite right, single variables will be faster, but the SET/RESET subs only take around 300uS on a 48MHz Micromite (further optimisations are available at the expense of legibility) and I really hate wasting 8 bytes to represent a bit and all the extra variables... if MMBasic had a Bit (or even Byte) datatype these routines would likely not exist. my firmly entrenched miserness (years of assembler). It's also nice to be able to see the all the flags using BIN$(flags,64). I guess personal preferences are playing here - I like to see stuff like
Every 47,DuskDawnTimer
FlagSet DuskDawnTimer
Every 60,PipeTempTimer
If FlagTest(PipeTempTimer) Then
 FlagRes PipeTempTimer
 PipeTemp=Fix(Tempr(TempSense))
 If FlagTest(HeaterForce) ...
in my progs... which are derivations of the Z80 BIT,SET & RES mnemonics... but I felt going full 8-bit on them is a step too-far - maybe a questionable decision
  ville56 said  use INV instead of NOT.
e.g. Flag=Flag and inv (1<<b)
should work this way ....
the version of MMBasic I use (MicroMites) doesn't have INV(), the FotS article does show a version at the bottom that uses INV.
Edited 2025-03-06 21:03 by CaptainBoing
Posted: 05:28pm 06 Mar 2025
  PhenixRising said
  Volhout said
a%=pin(gp0)
if a% then
if pin(gp0) then
Unless you're going to be doing something else with pin(gp0) inside the IF statement--like save the state value of the pin. It may have changed by the time you say "pin0State%=pin(pgo)"; better to be able to say "pin0State%=a%" and then deal with any new change the next time you check pin(gp0).
This probably implies that your IF statement is going to be "if pin0State%<>a%".
Edited 2025-03-07 03:31 by lizby
58kk90
Posted: 06:38am 08 Mar 2025
I am really grateful for the guidance given, and thought I had decided on using one integer per flag, but I do like the @CaptainBoing idea as it is similar to what I have always done in the 8048 / 8051 / arduino / Pic days where a single bit of a byte represented a particular flag so I decided to give that a try.
Seting and clearing the bit work fine, but I cannot get the 'Test a flag' function to work.
Most likely it's due to my limited knowledge, but I cannot see what the issue is
Dim Flags as integer
Flags = 1                       ' set a bit for testing
do
  if FlagTest(0) = 0 then print "bit is 0"
loop
End
Function FlagTest(b As Integer)
    FlagTest=Abs(Sgn(Flags And (&o1<<b)))
End Function
When I try and run this I get
[12] If FlagTest(0) = 0 Then Print "bit is 0"
"Error  : Variable type not specified"
I am using PicoMite MMBasic Version 6.00.00b4
Any suggestions please.
Tony
Posted: 07:20am 08 Mar 2025
My guess is that you have
option default none
set
If so, you have to give the function a type.
58kk90
Posted: 08:08am 08 Mar 2025
Jim, you are correct I do have Option default none set.
How do I give the function a type? I have defined b as integer
Tony
58kk90
Posted: 08:11am 08 Mar 2025
Cancel the last, I have figured that i've done :-
Function FlagTest(b As Integer) as integer
Now it works :-)
Tony
Edited 2025-03-08 18:12 by 58kk90
