Local Time 10:24 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Webmite driving me crackers...
Posted: 09:49am 07 Dec 2024
I've abandoned Webmite for the moment. I decided that it was easier to redesign the Aquarium Controller to have a display as it doesn't need much control. It gives me an excuse to put SMD MOSFETs in instead of the ULN chip too, and to introduce backlighting using a WS2812B strip. :)  All done on a RP2040-Zero this time.
Malibu
Posted: 06:01am 08 Dec 2024
Don't give up yet Mick... Try this and it might help out
OPTION EXPLICIT
'basic web server
dim string Off$, Onn$
dim Integer CurrentTemp
'get the time
WEB ntp
Pause 1000
Print "Server started at "Time$
Print
Dim buff%(4096/8)
Off$ = "checked"
Onn$ = ""
WEB TCP INTERRUPT WebInterrupt
'<do your processing here>'
CurrentTemp=26
' sub to handle all web server requests
Sub WebInterrupt
 Local a%, p%, t%, s$
 For a%=1 To MM.Info(max connections)
 WEB tcp read a%, buff%()
 if llen(buff%()) > 0 then
   'LongString print buff%()
   If (linstr(buff%(), "GET / HTTP") > 0) or (linstr(buff%(), "GET /index") > 0) then
     WEB transmit page a%,"/index.html"
   elseif linstr(buff%(), "favicon.ico") > 0 then
     web transmit code a%, 205
   elseif linstr(buff%(), "RB=ON") > 0 then
     ? "Turning RB to ON"
     Off$ = ""
     Onn$ = "checked"
   elseif linstr(buff%(), "RB=OFF") > 0 then
     ? "Turning RB to Off"
     Onn$ = ""
     Off$ = "checked"
   else
     ? "Other request found, sending 205 code"
   endif
 endif
Next a%
<html>
<head>
<title>WebMite</title>
</head>
<body>
<h1>Aquarium Control</h1>
<h2>{date$}  {time$}</h2>
<p>The tank temperature is {ttemp}C
<br>
The current lighting preset is number {colr}
</p>
<br>
<br>
<br>
<form id="radiotest" name="radiotest" method="post" action="">
Coloured Lighting
<input type="radio" id="RB" name="RB" value="OFF" onclick="submit(this.value)"{off$}>Off
<input type="radio" id="RB" name="RB" value="ON" onclick="submit(this.value)"{onn$}>On
</form>
</body>
</html>
Works on Opera and Firefox for me - I don't use Chrome, but see how it goes for you
For the Favicon request, I've just added the 205 code, but you can use a real favicon if needed
Posted: 07:08pm 09 Dec 2024
Thanks John. I'll give it a try, but just at the moment I'm a little busy.  :)
Malibu
Posted: 03:59am 10 Dec 2024
  Quote  I'll give it a try, but just at the moment I'm a little busy
No worries, it's there when/if you need it... and yeah, it's the busy season, so totally understood!
I've been playing with the UDP comms instead of TCP. It seems to be more stable - maybe that's another option for your controls?
