Forum Index : Microcontroller and PC projects : How old is your daily driver PC
By all means run Win 11 on machines that don't meet the spec, but don't keep anything on them that you may need in the future and keep backups of your data elsewhere (not on that machine at all). Otherwise, if the system decides to play silly bu66ers with the partition tables or drive allocation because of a "Windows Update" that your machine isn't suitable for, you'll be sorry. :) It's always a good idea to keep backups anyway. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Bill.b![]() Senior Member Joined: 25/06/2011 Location: AustraliaPosts: 249 |
I am still using my old conpacq E500 (2000 model) running win 2000 for programming picaxes. 2 laptops - (2018) Asus tuf gaming Razen 5 processor with win 11 home (2024 acer I5 running win 11 home 2 desktop PC both small 100 mm * 100mm one with Razen 7 and win 11 pro the other is an I5 running win 11 pro One standard PC I5 running win7 32bit, needed for a database that will not run on a 64bit machine. Bill Edited 2024-11-17 21:28 by Bill.b In the interests of the environment, this post has been constructed entirely from recycled electrons. |
DH61BE motherboard dating from 2011, so around 13 years old. but i didn't buy it new. upgraded to an i7-3770s processor, 16gb RAM, SSD, using the onboard graphics (1080p) and running linux mint XFCE. various other operating systems i work with are run in VMs using VirtualBox. i can have a handful of VMs running at once with used RAM and CPU resources still below 25%. for things that do not involve gaming or video editing, these older processors are venerable workhorses - fast, relatively cheap (i paid around nz$40 for the 3770), on a motherboard with good connectivity. cheers, rob :-) |
is this to activate? change to W11 install directory? |
| Marcel27 Senior Member Joined: 13/08/2024 Location: NetherlandsPosts: 105 |
2019 - INTEL NUC8I7, 16MB, 500 GB SDD. Windows 10. |
