Forum Index : Microcontroller and PC projects : matherps Hdmi board from jlpcb
Thanks Plasma for arranging.. Volhout PicomiteVGA PETSCII ROBOTS |
Hi, one board left for me (germany) ? |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 757 |
Dankeschön! You send us your PayPal via PM? I'll stick with the 3 pieces. Matthias |
Please pm me your PayPal Adresse 'no comment |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 368 |
Thanks Plasma If you PM me your PayPal email address , I’ll send you 10€ (1 board plus postage) ASAP. Best Thomas |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
I waiting for the Package from Jlcpcb . Plasma |
I thought we could pay in advance, before ordering. Wouldn't that be safer for you? Regards Michael Edited 2024-09-03 17:07 by twofingers |
Nope. Wrong DVI system. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If anybody’s package arrived pm me and I send you my PayPal. I testing the pcb before to prevent mistakes. first the goods then the money No message from JLPCB yet Gtx Edited 2024-09-03 18:27 by Plasmamac Plasma |
Your decision! Regards Edit By the way, I wouldn't have a problem if you reduced my "ration" (2 boards) by one piece in favor of Atmega, in case there isn't enough for everyone. Edited 2024-09-03 21:08 by twofingers |
| Exile Newbie Joined: 27/05/2023 Location: United KingdomPosts: 28 |
With some trivial changes the Olimex successfully runs the dvi_out_hstx_encoder from the pico SDK. The changes needed were to swap the clock and D0 lines and to swap the inversions (line 196 to 219) // Pinout on Olimex: // // GP12 CK- GP13 CK+ // GP14 DO- GP15 D0+ // GP16 D2- GP17 D2+ // GP18 D1- GP19 D1+ // Assign clock pair to two neighbouring pins: hstx_ctrl_hw->bit[0] = HSTX_CTRL_BIT0_CLK_BITS | HSTX_CTRL_BIT0_INV_BITS; hstx_ctrl_hw->bit[1] = HSTX_CTRL_BIT0_CLK_BITS; for (uint lane = 0; lane < 3; ++lane) { // For each TMDS lane, assign it to the correct GPIO pair based on the // desired pinout: static const int lane_to_output_bit[3] = {2, 6, 4}; int bit = lane_to_output_bit[lane]; // Output even bits during first half of each HSTX cycle, and odd bits // during second half. The shifter advances by two bits each cycle. uint32_t lane_data_sel_bits = (lane * 10 ) << HSTX_CTRL_BIT0_SEL_P_LSB | (lane * 10 + 1) << HSTX_CTRL_BIT0_SEL_N_LSB; // The two halves of each pair get identical data, but one pin is inverted. hstx_ctrl_hw->bit[bit ] = lane_data_sel_bits | HSTX_CTRL_BIT0_INV_BITS; hstx_ctrl_hw->bit[bit + 1] = lane_data_sel_bits; } Given that, perhaps the Olimex can be used? |
MMBasic V6.00.00b5 (just about to post) will now run on the Olimex Just use OPTION RESET OLIMEX to setup the DVI port, the sdcard and the audio They have selected stupid pins for the audio (not the same PWM channel) so bridge GP28 to GP26 to get stereo in MMBasic |
For 12dollar, that is a nice solution. it even has a charger. Volhout Edited 2024-09-04 02:05 by Volhout PicomiteVGA PETSCII ROBOTS |
Peter Thank you. This is a great solution with Option Reset Olimex And a board with DVI(HDMI), Audio, SD, Lipo charger, Reset etc. Probably connectors with long pins were used on the Pico 2? Jan. |
For those that may have not used the Olimex board before, there is a gotcha that by default the board does not put 5v out on HDMI pin 18. Some TVs detect an HDMI device by looking for this 5V and so without it they do not register that the board is plugged in. I've seen this issue with Samsung and Sony TVs. Most PC monitors do detect the board correctly. If the board is not detected, it is possible to force 5V through pin 18 by soldering closed SJ1 on the back of the board. The issue that this can then lead to the board being back powered from the TV. This is usually not enough run the MCU correctly, so the board can become unresponsive. The workaround for that is to ensure that the board is powered up and running prior to connecting the HDMI lead. |
Bridge the jumper with a 100 ohm resistor, and power the board from its own supply. PicomiteVGA PETSCII ROBOTS |
Put a diode across the jumper so that the board can source almost 5V but not get reverse powered. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Volhout Calculation from Olimex (Bugaria) to the Netherlands. 12.00 Euro + VAT 5.23 Euro + Shipping 12.91 Euro Jan. |
For 12dollar, that is a nice solution. it even has a charger. Harm, I sent a PM to TinyTronics Eindhoven because they are a dealer and got this message. We are going to buy the RP2040-PICO-P from Olimex. As soon as I have more information about the delivery time and price, I will let you know immediately. They also have many modules from WaveShare for the Raspberry Pi Pico. Jan. |
Hi Jan, I ordered Peters design, and will start playing with that. At the moment I have 5 projects at hand for the 2040, although I am charmed by the potential speed gain. Many of my earlier projects could use a bit more umpf and ram. I.e. the thermal camera, that was 70% battle for performance. But you know how this goes: al is de hardware nog zo snel, de software achterhaalt hem wel....(dutch saying). Volhout Edited 2024-09-07 05:19 by Volhout PicomiteVGA PETSCII ROBOTS |
