Local Time 01:15 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Gamer
     Page 2 of 4
SimpleSafeName
Posted: 01:20am 21 Mar 2024
  Geoffg said  The April issue of Silicon Chip magazine is hitting the streets about now and it features the Pico Gamer.  This is a game playing console similar to the Nintendo Game Boy Advance but using the PicoMite.
Looks great!!
Andrew_G
Posted: 02:32am 21 Mar 2024
Geoff, Well done!
SimpleSafeName, following our 'conversation' a month or two back I bought an AnkerMake  5 and I am very happy with it. I use OpenScad and can do simple things.
I can 'IMPORT' Geoff's STL file (thanks Geoff) but all I get is the complete item - without the ability to edit or remove features - am I missing something?
(I use the AnkerMake slicer and it slices it OK but complains about the raised lettering. I have a smooth build plate so I can get smooth bottom layer).
Cheers,
Andrew
SimpleSafeName
Posted: 04:36am 21 Mar 2024
  Andrew_G said  Geoff, Well done!
Cheers,
Andrew
Excellent! I'm happy to hear that! :)
You can't (as far as I know) edit an "external" .STL file per se. But what you can do is to import it and add and/or subtract from that .STL file. So you end up editing it in a backdoor sort of fashion.
Here's an example of importing a .STL and then adding the OpenSCAD elements to it (or in this case subtracting "stuff" from the original model).
I've included the files for you to play with. Enjoy. :)
OpenSCAD Merge Example.zip
$fn=64;
//difference() {
translate([0,0,0])
import("HextrudORT_Dragon_TENSION_ARM_body_V1.5.STL");
difference(){
translate([4.425,-15.09,2.9])
cylinder(r1=2.25, r2=2.25, h=14);
translate([4.425,-15.09,2.4])
cylinder(r1=1.75, r2=1.75, h=15);
difference(){
cylinder(r1=4.25, r2=4.25, h=14);
cylinder(r1=3.75, r2=3.75, h=15);
difference(){
translate([6.9,-5.6,2.9])
translate([6.9,-5.6,2.4])
difference(){
Martin H.
Posted: 07:48am 21 Mar 2024
So that I have a smooth contact surface when printing I wanted to change the lettering of the TOP Cover from raised to engraved.
Top Case:
  Quote  STL num of vertices 365496 num of triangles 731593
Base
  Quote  STL num of vertices 393630 num of triangles 787272
For a simple housing, that's a lot.
Sadly I could not Handle such complex files.
'no comment
Chopperp
Posted: 09:02am 21 Mar 2024
  SimpleSafeName said  I was going to suggest OpenSCAD. You can easily import Geoffg's STL files (thanks for providing them Geoff!) and then remove the printing.
OK, I tried  importing the STL file (after reading up & watching a Vid on how to do it), but nothing comes up in the main window. The console seems happy. I tried other files, but get the same blank display.
I did a "Check Validity" which said "No" so there must be something wrong with the import.
A file I render locally validates OK.
Brian
ChopperP
SimpleSafeName
Posted: 09:10am 21 Mar 2024
Oh what fun! OpenSCAD is correctly complaining about an "ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron." error.
This has happened to me in the past when I was trying to print the Destiny Thorn gun that someone had added their name to in the model. So until the error is fixed OpenSCAD won't render the file (and without a proper rendering, there will be no STL file exported).
So, off to MeshMixer. Which shows where the error is:
And MeshMixer's first shot at fixing the error:
Arguably it did fix the problem. LOL! Nonetheless, it appears that we have some work to do. :)
The best thing would be for Geoff to remove the text, but I'll muck about with it and see if I can fix it. My edits might leave a file that looks correct, but no longer prints accurately (but I don't expect that to happen).
So take this post as a work in progress,
Posted: 09:34am 21 Mar 2024
There seems to be some confusion going on here.  Probably a case of the blind leading the blind (at least I know that I'm rather blind in this discipline).
Firstly, I intended for the case to be made by a commercial company (ie, jlc3dp.com), not a home printer.  I have never used a home printer but my guess is that it would not work out very well - the STL files are complex, home printers have a rough surface finish, etc.  BTW, one of the reasons for such a complex STL file is that I was after a very smooth bevel on the corners of the case so that it would sit comfortably in the user's hands.
Also, I have only used Blender.  Other packages seem to work in a completely different fashion.  My recommendation to use Blender was solely based on the fact that I was able to get it to work after a steep learning curve.
Finally, the raised letters works well - easy to read but not annoying.  However, for anyone who needs it, I have created a version without the lettering (top enclosure only).  It can be downloaded from here: https://geoffg.net/Downloads/picogamer/TopNoLetters.zip.  I was reluctant to make it available as I have not had a test piece made, so please be aware that there may be a defect in it (although I doubt it).
Edited 2024-03-21 19:43 by Geoffg
SimpleSafeName
Posted: 10:17am 21 Mar 2024
Yeah! Thank you!
For the record, there is nothing wrong with your file - if - it is printed as you intended using a resin printer.
But if you want to print it at home using a filament 3D printer the bumps from the letters will lift the rest of the print off of the build plate and that part of the print will begin in mid-air (which won't work).
That's all that was "wrong" with it. But by editing your design to omit the lettering you fixed the problem for filament 3D printers. And it can now be printed at home.
I did "fix" it in MeshMixer, but I've forgotten what I did to fix the previous file for my friend. The resulting file is about 3 times the size (but looks pretty good), but it now exceeds the memory limits of OpenSCAD (my rig has 64 Gig, I'm going to go out on a limb and say that *I* didn't run out of memory).
But your file is the way to go.
Here's what I ended up with in MM:
Posted: 11:38am 21 Mar 2024
Thanks John, maybe in future I should indent the lettering.
If you, or anyone, does print this on a home filament printer I would be interested in hearing about the experience (surface finish, accuracy of the features, strength, etc).
Martin H.
Posted: 01:18pm 21 Mar 2024
Thanks a lot
For People that like to print it with filament Printer, I changed the "No Text Version" to engraved text.
PICO GAMER TOP-engraved text.zip
Martin
Edited 2024-03-21 23:48 by Martin H.
'no comment
Posted: 02:12pm 21 Mar 2024
That's great Martin.  Would it be OK if I added it to the construction pack?
Martin H.
Posted: 03:56pm 21 Mar 2024
  Geoffg said  That's great Martin.  Would it be OK if I added it to the construction pack?
Of course you can do that
'no comment
karlelch
Posted: 05:10pm 21 Mar 2024
  Amnesie said  Haha! For me, 3D printing is just ugly. Yeah there are methods to "clean" all those filament stuff but honestly, for me it is just a piece of plastic toy feeling to it. I much prefer proper CNC milling of steel, aluminium etc. Laser becomes cheaper and cheaper, too.
I really understand that it also has some benefits, it boosts creativity und a lot of people tinker with it and learn something on the way - epecially to design and work with all those CAD software.
But in the end it is an ugly piece of plastic. Often I see projects even gooped up with hot glue, too.
Awful, just awful.
Steel, aluminium - pah! In the good old times, we hand-carved our cases from wood and wrapped them with leather! Sorry - could not resist.
SimpleSafeName
Posted: 06:07pm 21 Mar 2024
  Geoffg said  Thanks John, maybe in future I should indent the lettering.
You're welcome! And for filament style 3D printers it would certainly be helpful. :)
You could flip the part over so the lettering was on the top, but that would require adding support inside the void to get it to print (and support rarely comes away cleanly from the part it is intended to support).
I did some more experimenting, and I found that I could "bury" the issue by setting the Z axis transform downwards by .5mm in the slicer. So if all you want to do is to print it out, then this would work in a pinch (and for any other prints that had the same problems).
But thank you again for fixing this. :)
I'm going to print it out on my printer just to see how it comes out. But if I make a Pico Gamer, I'll have the case printed by JLC3DP as you suggested. It does look stunning. :)
But what I will do for a print on my printer, is to put a "pause" in the G-Code file once the print has got to the .5mm level. This would allow me to change the filament color to something different to make the indented lettering stand out.
And I will probably print it in ABS and then use ABS "Vapor Smoothing" to give it a resin level of smoothness.
And a bit of OpenSCAD "Inside baseball" concerning the error:
This is twice now that text has "broken" the STL file for me. What happens is that the manifold is no longer watertight. It still prints, usually with no problems, but OpenSCAD can't handle the "leak".
Here's what one of the guys had to say about what was going on
"There are many, many ways to get this class of error.
Roughly, they can be broken down into three sub-classes:
 * Polyhedra that are malformed - that have missing faces, faces
   oriented the wrong way, or self-intersections.
 * Polyhedra that have points that are too close together, that
   OpenSCAD snaps together when it forces everything onto its grid.
 * Models that are not 2-manifold, that have volumes that touch only
   along a single line."
It's my understanding that the underlying STL engine, "GCAL", can allow a precision that will induce errors (how helpful...) and there's not much that the OpenSCAD team can do about it.
https://github.com/openscad/openscad/issues/4039
Edited 2024-03-22 04:08 by SimpleSafeName
SimpleSafeName
Posted: 06:10pm 21 Mar 2024
  Martin H. said  Thanks a lot
Martin
Nice! Thanks!!
SimpleSafeName
Posted: 06:12pm 21 Mar 2024
  karlelch said  Steel, aluminium - pah! In the good old times, we hand-carved our cases from wood and wrapped them with leather! Sorry - could not resist.
Whaaa? You don't chisel them into the walls of your cave?!?
Andrew_G
Posted: 10:02pm 21 Mar 2024
Wow,
A lot of dialogue on this overnight - I haven't caught up yet.
Thanks to everyone for chipping in and to Geoff for being so understanding.
We hadn't meant to hijack your 'release' of Pico Gamer.
3D printing is still a little of a black art - for example for about Au$50 I have a smooth 'build plate' (magnetic and with the normal rough surface on the reverse). This gives a mirror-like finish to the bottom. Even with a 0.4mm nozzle I get pretty good finish elsewhere. A resin printer would be better again.
Thanks again,
Andrew
damos
Posted: 11:21pm 21 Mar 2024
  Geoffg said
Now that I have put the time into learning the Blender app I'm going to be using more custom boxes... it is so easy.
That is my experience as well, although not sure about the easy part. It is very easy to use Blender the way you describe, but every time you go do something new, there is a whole extra learning curve, then you get a whole heap of extra capability and it keeps repeating. In my case I decided to take the design and render it. Light sources, cameras etc. Heaps of work, but wow!. Then I decided to animate it. It works really well, but once again, steep learning curves.
I have done the full wood working, metal working, styrene modelling and then laser cutting, but at this stage 3D printing wins every time. All of the methods require as much time finishing as design and creating if you want a good result. For non-presentation work a quick clean up with a knife, file or sandpaper is all that is required for 3D printed parts.
For example with LCD panels, my minimum standard is no visible screws if possible. To do this in a jiffy box it requires an accurate cutout with drilling, cutting and lots of filing. Then I glue styrene blocks to the back and drill holes to mount the panel to the back using 6mm self tapping screws. It gives a really good finish but takes a lot of time. I now have a design for Micromite backpacks and I just print it out. For most applications the box is good enough straight from the 3D printer - I would say similar in quality to a jiffy box. If I want a really good finish I can use a higher quality setting on the printer. Generally a quick sand and a coat of spray paint and you get a really good finish. If you use angled sides you can get a stepping effect that can be covered with filler (I just use gyprock filler as it really soft and easy to work). I think the best approach could be high-build spray putty.
PeteCotton
Posted: 04:11pm 22 Mar 2024
  Geoffg said  Creating a 3D design does not require any special skills.  You start with a solid cube and then cut holes, extrude parts, bevel corners, etc until you get what you want.
This reminds me of the apocryphal Michelangelo quote:
  Michelangelo (the sculptor - not the turtle) said  "It's easy to carve an elephant. Get a big block of granite and remove all of the bits that don't look like an elephant."
Congratulations on another very cool project.
IanT
Posted: 09:33am 23 Mar 2024
Interesting thread - both in terms of Geoff's new device and 3D printing/CAD.
A friend recommended Open SCAD when I got my 3D filament printer a few years back. It was very easy to get into and will suit anyone with a programatic frame of mind. By using variables you can build models that are easily modified for size and fit. So it worked well in my workshop to produce hose adaptors and various small cases and containers where frankly, I don't care about surface finish.
However, it didn't replace my engineering/drafting CAD which for many years had been 2D TurboCAD. So I finally bit the bullet and decided to learn a 3D CAD system. I settled on Siemens Solid Edge (Community Edition) which is a free download running on Windows (I have it on Win 10 & 11 Home Editions) locally (e.g. no Cloud required). I've been using it for about 3 years now and I'm very happy I invested the time learning it. Not everyone will have my technical requirements of course (dimensioned drawings, multiple export/import file types, fully parametric etc).
I too recently had to import and modify a .STL file and SE has the ability to both repair the mesh and to (some extent) modify .STL files but it is (as mentioned by SSN) mostly to add or subtract material. The STL file doesn't have enough data to truely reconstruct the part but you can 'flatten' surfaces for instance, which then become more usable (e.g to mate/align another part to it). My file was of a locomotive wheel and I was able to clean up the hub and then remove the flange and replace it with a new one (designed in SE). So easier perhaps than starting from scratch but a .STEP file would be much better for this kind of re-cycling, as it contains more base data.
As Solid Edge can be used for 2D drafting, it has replaced SCAD and TurboCAD as my sole CAD system, which makes life a little simpler. If you are looking for a full-fat 2D/3D CAD system then I'd suggest you look at Solid Edge CE.  It's not as well known (publicised) as Fusion or FreeCAD but it's a very powerful CAD tool should you need one.
OK - Sorry to Interupt, Back to lurking...
IanT
     Page 2 of 4
