Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10108
Posted: 10:17pm 11 Mar 2024
That was enough of a reply to convince me that if I use the HW watchdog in the 2040 chip, and NOT the software one, this SHOULD get me around the issue.
I still have no idea WHY the PM is crashing this badly, and it is only ONE unit out of fifty or so, all with the same code. YES - have tried swapping out for a different PM module, but the same thing happens.
It's extremely odd.....
However, if I just use the 2040's hardware watchdog as a work-around, that will settle things down till I can work out what the hell is going on. Edited 2024-03-12 08:19 by GrogsterSmoke makes things work. When the smoke gets out, it stops!
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807
Posted: 11:07pm 11 Mar 2024
dunno about crash but dim k k=inkeys error mmedit still connects and says uploading(flashing code) and sits there. power off/on sorts it vga usb 00b5
