Local Time 15:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GameBoy Emulator for PicoMiteVGA HW
     Page 2 of 3
Posted: 03:01pm 15 Feb 2024
If you want to get closer to the C64 palette, I would advise to change the hardware.
Original Palette
R, G1 and B with 390 ohm resistors to VGA R,G,B
G0 with 820 ohm to R, 820 to G, 820 to B on VGA (G0 drives all pins at same time)
Looks closer to C64, and has 2 different grey tones, but misses out on pure R, G and B.
And (for Peter) is not so easy to convert from RGB 8:8:8 to RGB 1:2:1. You need a lookup table, and new color names.
Volhout (always looking for "grey / gray" tones to better mimick real life/Windows95)
Edited 2024-02-16 01:07 by Volhout
javavi
Posted: 06:28pm 15 Feb 2024
  Martin H. said
could be done , only missing Color is Bright White
Spectrum Colors
I would like to know under which PicoMite scheme to make such a ZX-Spectrum 128k port, which one is the most common?
And how interesting will this be to the local public, since these emulator projects exist for other boards based on Raspberry Pico?
Edited 2024-02-16 04:31 by javavi
Martin H.
Posted: 06:45pm 15 Feb 2024
  javavi said
Spectrum Colors
The colour values come closest to the spectrum colours in the "normal" RGB 121 for PicomiteVGA or LCD.
Since I started my career on a ZX81 and very quickly switched to the Spectrum, I would certainly use such an emulator
My first RaspberryPi (1B) has found its final destination in a ZX Spectrum(like) case and runs with the BareMetal ZX emulator.
For PicoMiteVGA I use Mixtel90s GameBoard V2.0, but I still have enough Picos to use them with a different firmware.
Edited 2024-02-16 04:47 by Martin H.
'no comment
javavi
Posted: 11:33pm 15 Feb 2024
ZX_Spectrum 128k on PicoGAME VGA !!!
To begin with, I ported the fruit-bat/pico-zxspectrum project to the PicoGAME VGA scheme.
https://github.com/fruit-bat/pico-zxspectrum
Can you check it for yourself?
For now I made the sound single-channel on GP6
I changed the palette as you described, and yes, there is no gray!
If this topic is interesting, then there are at least two more ZX-Spectrum projects for Piro RP2040 whose authors I know.
What I don’t know is whether it makes sense to tinker with the limit of these projects for the VGA121 scheme since they use VGA222?
ZX-Spectrum_PicoGAME_VGA.ZIP
javavi
Posted: 11:38pm 15 Feb 2024
You need to place the folder from the archive in the root of the flash drive, enter the menu using F1 key.
Other information on the project's GitHub
By the way, the USB keyboard and some of the gamepads should still work.
Edited 2024-02-16 17:04 by javavi
javavi
Posted: 07:32am 16 Feb 2024
Yes, as it turns out, the gray color of the ZX-Spectrum palette is the only thing missing from this VGA121 color scheme from PicoMiteVGA
Best regards, Java
Martin H.
Posted: 08:39am 16 Feb 2024
I get the same Picture but there is no reaction on Gamepad or PS2 Keyboard input, so I have no way to get something to run
Edited 2024-02-16 18:53 by Martin H.
'no comment
Posted: 08:51am 16 Feb 2024
Javavi implemented USB keyboard, not PS2
Martin H.
Posted: 08:58am 16 Feb 2024
  Volhout said  Javavi implemented USB keyboard, not PS2
I have read that...
Sadly a Pico Game Board normally doesn't have a connection for a USB keyboard.
'no comment
javavi
Posted: 09:14am 16 Feb 2024
  Martin H. said  I get the same Picture but there is no reaction on Gamepad or PS2 Keyboard input, so I have no way to get something to run
This is strange, at my stand, the PS/2 keyboard works.
It is connected like a PicoMite circuit to GP8 - CLOCK, GP9 - DATA.
Perhaps you have a universal USB/PS2 keyboard that requires initialization.
And yes, you can also connect a USB keyboard and a regular USB PC gamepad.
javavi
Posted: 09:25am 16 Feb 2024
My Development board on Raspberry Pico
Edited 2024-02-16 20:10 by javavi
Posted: 10:07am 16 Feb 2024
I'll get back to the new PicoGAME, I think. The current state is that it will support USB, with the possibility of connecting the USB-A socket to the USB pads beneath the Pico.
I might still do more messing about (I never know where to stop on these designs!). The intention was to include the guts of a VGA-hdmi converter but, although I ordered one, that particular order from AE got lost somewhere. :(
javavi
Posted: 10:33am 16 Feb 2024
  Mixtel90 said  I'll get back to the new PicoGAME, I think.
I am using a development platform called MURMULATOR already version 1.4.
It uses a VGA222 video output combined with HDMI and can connect an LSD screen and a composite video output adapter, and all this is connected to the same pins (but not at the same time :))
It turns out to be a very universal connection of video outputs.
Also in the latest version, I2S sound chip and an 8MB PSRAM RAM chip are optionally added.
Currently working on it:
- Four different ZX-Spectrum emulator projects
- NEC emulator
- GB and GBC emulator
- PC XT emulator
and other projects including PicoMightVGA were ported.)
Posted: 11:11am 16 Feb 2024
Nice, this murmulator...
There is a version that fits in a RPi 3B housing with build in USB hub for 4 ports and HDMI. That may support USB controllers also ???? (my russian is bad).
Edited 2024-02-16 21:13 by Volhout
javavi
Posted: 01:08pm 16 Feb 2024
  Volhout said  Nice, this murmulator...
In theory, yes, but there are still few projects using USB and they are under constant development.
Supported projects can be found on the website (via Google Translate :)
murmulator
cosmic frog
Posted: 05:54pm 18 Feb 2024
I built a new PicoGameVGA from scratch and tried again with the gameboy emulator and this is what I got.
The keyboard seems to be trying to do something but pressing the "Z" or the "X" key puts the Pico into BOOTSEL mode and gives a black screen/monitor goes into standby.
I have the GB Folder on the SD card but nothing seems to work.
Thanks.
Dave.
Also the Horizontal and Vertical are the wrong way around on the VGA socket.
Edited 2024-02-19 03:59 by cosmic frog
javavi
Posted: 06:39pm 18 Feb 2024
Hi Dave,
This is the picture that will appear when the GameBoy emulator cannot read files from the SD card.
There may be several reasons: there is no contact, incorrect connection, and not all SD cards may work here. You need to try other SD cards formatted in FAT32.
Yes, I corrected the VGA connection diagram.
Thank you!
Martin H.
Posted: 07:20pm 18 Feb 2024
I get the same picture as Dave with the GameboyEmu on PicoGameVGA.
Please note that there are different options for SD socket and MicroSD module as the pins are switched in a different order.
I have inserted a standard SD card and it works fine with PicomiteVGA.
option list
PicoMiteVGA MMBasic Version 5.08.00
OPTION KEYBOARD GR, 0, 0, 0, 0
OPTION CPUSPEED (KHz) 252000
OPTION SDCARD GP10, GP12, GP11, GP13
OPTION AUDIO GP6,GP7', ON PWM CHANNEL 3
OPTION MODBUFF ENABLE  180
cheers
Martin
Edited 2024-02-19 05:34 by Martin H.
'no comment
cosmic frog
Posted: 09:01pm 18 Feb 2024
Sounds like I should be able fix it if its just an SD card thing.
I'll have another look and let you know if I get it working.
Thanks Javavi and Martin for your help.
Dave.
Martin H.
Posted: 09:13pm 18 Feb 2024
  cosmic frog said  Sounds like I should be able fix it if its just an SD card thing.
Dave.
Hi Dave
I hope it is less effort for Javavi to adapt the source code to the given conditions than to have to re-solder the configuration (which works for PicoMITEVGA).
Also I get no real response from the PS2 Keyboard on the ZX Spectrum- or the Gameboy Emu
'no comment
     Page 2 of 3
