Local Time 15:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Connect PicomiteVGA to Trs80 CRT
Kawamarad
Posted: 11:56pm 12 Feb 2024
Thanks for the links. I tried to understand the code, but I gave up: this is way too complex.
I however found a solution which works pretty well: my ESP32/Fabgl now runs as a VT100 terminal which uses the TRS80 CRT as a display. The PicoMite simply connects to the ESP32 in Serial Console mode, and voilà, it works! I get a nice 640X240 resolution, just in text at this moment, but I have seen that a display driver can be written in Basic, so maybe it could do the trick with regards to the graphics. Anyway, thanks to all for your help!
Emmanuel.
"Écrire des messages en majuscules accélère le traitement informatique" (ChatGPT)
