Local Time 20:55 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Time offset between two pins
     Page 2 of 3
Posted: 09:06pm 11 Sep 2023
My toroidal transformer is a dual 9V secondary rated at 25VA. I have loaded it to ~5mA.
If I wanted true galvanic isolation, I could remove the secondaries, install a faraday shield and replace the secondary. Not a huge job but not required here.
My mains is very noisy with a powerline network adapter the main culprit.
I was going to use a lowpass filter but found that a simple voltage follower using a LM324 was visually sufficient to remove the high frequencies. I haven't used a FFT to analyze the waveform yet.
Unfiltered:
simple digital filter:
The peaks show some residual HF getting through.
Sampling frequency was 8k.
I used a sample size of 3 for the filter:
SUB math_runAv array1!(), samples%, arrayout!(), count%
 LOCAL INTEGER n, range, k, b
 LOCAL FLOAT av
 range = samples%\2
 b = MM.INFO(OPTION BASE)
 FOR n = MM.INFO(OPTION BASE) TO count%
   av = 0
   FOR k = -range TO samples%-range-1
     IF (n+k) < b THEN
       av = av + array1!(b)
     ELSEIF (n+k) > count% THEN
       av = av + array1!(count%)
     ELSE
       av = av + array1!(n+k)
     ENDIF
   NEXT k
   arrayout!(n)= av/samples%
 NEXT n
END SUB
Posted: 12:07am 12 Sep 2023
This is a demo of getting power from captured volts and amps.
yellow = volts
cyan = amps
green = power.
It was tested on an armiteF4 but should run on a picomite with any resolution display.
 OPTION EXPLICIT
 OPTION DEFAULT INTEGER
 OPTION BASE 1
 DIM capturesize = MM.HRES * 4
 DIM cpp = 2 ' cycles per page
 DIM FLOAT radppixel = 2*PI*cpp/MM.HRES
 DIM FLOAT voltarray(capturesize)
 DIM FLOAT ampsarray(capturesize)
 DIM FLOAT voltview(MM.HRES)
 DIM FLOAT ampsview(MM.HRES)
 DIM FLOAT powerview(MM.HRES)
 DIM hor(MM.HRES)
 DIM n, trigger, ampphase
 DIM FLOAT vs = 0.75, ps = -0.01
 DIM k$
 FOR n = 1 TO MM.HRES : hor(n) = n : NEXT n
 FOR n = 1 TO capturesize
   voltarray(n) = SIN(n*radppixel)*150
   ampsarray(n) = SIN(n*radppixel)*50
 NEXT n
 trigger = MM.HRES/2
 redraw
 DO
   k$ = INKEY$
   IF k$<>"" THEN
     SELECT CASE k$
       CASE "<",","
         ampphase = ampphase + 1
         IF ampphase > MM.HRES/2 THEN ampphase = 0
       CASE ">","."
         ampphase = ampphase - 1
         IF ampphase <=0 THEN ampphase = MM.HRES/2
     END SELECT
     redraw
   ENDIF
 LOOP
Sub redraw
 Local pow, pf!
 Memory Copy Float Peek( Varaddr voltarray())+trigger*8,Peek( Varaddr voltview()),Mm.hres
 Memory Copy Float Peek( Varaddr ampsarray())+trigger*8+ampphase*8,Peek( Varaddr ampsview()),Mm.hres
 math_multiply voltview(),ampsview(),powerview(),Mm.hres
 pow = Math(Mean powerview())
 pf! = pow/(math( sd voltview())*math(sd ampsview()))
 Math Scale voltview(), vs, voltview()
 Math Scale ampsview(), vs, ampsview()
 Math Scale powerview(), ps, powerview()
 Math Add voltview(), Mm.vres/2, voltview()
 Math Add ampsview(), Mm.vres/2, ampsview()
 Math Add powerview(), Mm.vres/2, powerview()
 Cls
 Line 0,Mm.vres/2,Mm.hres,Mm.vres/2,1,Rgb(Blue)
 Pixel hor(), voltview(), Rgb(Yellow)
 Pixel hor(), ampsview(), Rgb(Cyan)
 Pixel hor(), powerview(), Rgb(Green)
 Text Mm.hres/2,30,Str$(pow)+"W "+str$(pf!,2,2)+" pf",cm,1,2
SUB math_multiply array1!(), array2!(), arrayout!(), count%
 LOCAL n%
 FOR n% = MM.INFO(OPTION BASE) TO count%
   arrayout!(n%)= array1!(n%) * array2!(n%)
 NEXT n%
END SUB
The two memory copy lines have wrapped.
use < and > to shift the phase of the current.
Edited 2023-09-12 14:23 by TassyJim
Frank N. Furter
Posted: 07:55am 12 Sep 2023
@Volhout:
Thanks for the really interesting link!
...do you really mean a 33K/33K voltage divider??? There I would have a power dissipation of 800mW...
@TassyJim:
On the secondary side you already have a galvanic isolation...
  Quote  My toroidal transformer is a dual 9V secondary rated at 25VA.
It is too big for my application...
Frank
Posted: 08:15am 12 Sep 2023
  Volhout said  Simulation shows that something like this should work to measure mains voltage. I will try to prototype (build actual circuit) tomorrow.
It actually works....
Using a small common mode choke to measure 230Vac. The 2x 47kohm resistors are not on this board, but connected in the power plug.
Edited 2023-09-12 18:16 by Volhout
Frank N. Furter
Posted: 08:20am 12 Sep 2023
Do you operate the OP with positive and negative supply voltage? Is there a possibility to get along with only one (positive) voltage?
Frank
Pluto
Posted: 08:32am 12 Sep 2023
According to Volhout's schematic above, only +5V supply. LM358 can output almost to 0V with single 5V supply.
Posted: 08:38am 12 Sep 2023
@Jim,
I did not investigate your complete power meter program in depth.
With such a nice voltage waveform, the filtering you add does not give much extra.
Try to RMS both waveforms, and you will see the results are identical. And when not ... blaim is on the filter (really, this is no joke).
I am not sure if you need 8kHz. Have been working on several energy meters here and these run on 4kHz, using a ADC with SINC3 filter and modulation frequency trap.
These are class 0.2 meters.
I will be following this carefully. Both you and Frank.
P.S. one tip. If you capture data in an array, and want to do accurate RMS, you will see errors as result of incomplete waveforms (i.e. 3-3/4 waveforms in the array, not 3 or 4). RMS calculation should be performed on full amount of waveforms to prevent DC errors. There are 2 ways to do this
1/ adjust the sampling frequency to get full waveforms in the array
  this gives perfect FFT and RMS
2/ capture an array and:
  - window it for FFT (i.e. Hann)
  - find zero first and last crossings in the array, and calculate RMS over the
    cycles between these zero crossings.
Posted: 08:49am 12 Sep 2023
Frank, the waveform you showed on the previous page seems to show significant capacitive coupling between the two windings. The output of Jim's transformer shows the 'flat top' distortion you should see, not the peaks in yours.
If you must use that transformer it's possible to reduce the effect of the coupling.
1) Swap active and neutral and check the waveform again. Getting the active end of the primary away from the secondary should help.
2) Put a large capacitor from the voltage reference end of the secondary to ground and a smaller one from the other end to ground. These may swamp the primary / secondary capacitance. If this causes a phase shift subtract it in software. Trial and error will determine the values of the caps.
3) Swap the secondary connections. It might give a small improvement if it gets the measurement end of the secondary further away from the primary.
Frank N. Furter
Posted: 09:39am 12 Sep 2023
@Pluto:
You are right! I didn't look at the picture thoroughly enough - those who can read are clearly at an advantage...
@phil99:
1) Swapping N and L has no effect on the curve.
2) This is my reference voltage generation:
There I used a 47µF for stabilization. Do you think I should make it bigger?
You mean I should connect the second capacitor here?
Frank
Posted: 10:03am 12 Sep 2023
@Frank,
For an opamp to be stable, it is preferred to have a phase margin of 45 degrees or more.
Your opamp (TLV272) phase margin versus capacitove load shows that the maximum capacitive load is 300pF (the 0 ohm series resistor curve).
47uF is FAR too much. Your TLV272 opamp will not operate reliable.
Additionally, if you plan to use the pico ADC is is best to use a LM4040 3V as reference at the VREF pin, and use a 1:1 voltage divider from that reference to create 1.5V. In that case they cannot drift appart. One reference for both.
Posted: 10:04am 12 Sep 2023
  Quote  I am not sure if you need 8kHz. Have been working on several energy meters here and these run on 4kHz, using a ADC with SINC3 filter and modulation frequency trap.
My real program does sample at 4kHz. That gives me room to capture 2.5 seconds for before and after disturbances.
The arrays are sized to suit 50Hz and long enough to give good RMS readings.
Even thou it is over 30 years since I worked in power distribution, I still have an interest in what's happening.
I am waiting for an event to record to see if it is as good as the old systems we had at the substations.
Posted: 10:42am 12 Sep 2023
  Quote  There I used a 47µF for stabilization. Do you think I should make it bigger?
47µF should be enough.
  Quote  You mean I should connect the second capacitor here?
Yes, experiment with values. Too high and it may reduce the voltage accuracy yet it must be much larger than the capacitance between the windings to be effective.
Edit
Volhout,s method looks like a good compact way to measure the mains.
It has the potential for good phase accuracy as the primary circuit is almost totally resistive.
If all the resistance is in the active leg the effect of capacitive coupling will be close to zero.
As the layout of the windings is visible the the signal end of the secondary can be kept away from the primary.
Edited 2023-09-12 22:07 by phil99
Frank N. Furter
Posted: 12:05pm 12 Sep 2023
@Volhout:
  Quote  Your opamp (TLV272) phase margin versus capacitove load shows that the maximum capacitive load is 300pF (the 0 ohm series resistor curve).
? ...that's just a voltage follower with amplification, isn't it?
@phil99:
I have now inserted a 10µF at this point:
The voltage measurement looks quite acceptable now:
The red line is the measured voltage reference - it is stable up to the 2nd decimal place - only the third decimal place changes. So I measure 1.51XXX every time.
Frank
Frank N. Furter
Posted: 12:25pm 12 Sep 2023
I have drawn an ideal sine curve (grey) here:
Do you think that is accurate enough???
Frank
Posted: 01:14pm 12 Sep 2023
Hi Frank,
You have not given any pass-fail criteria. Is it good enough ...? I cannot judge.
You have put the zero crossing of both waveforms on top of eachother.
- The second zero crossing is roughly 3/4 sampe period wrong (at 40 samples per sinewave is 6.7 degrees).
- At this exact moment the amplitude difference between the 2 waveforms is almost 5% of the peak-peak amplitude. This will show up as harmonic distortion in the spectrum.
If you run an FFT on the samples it gives you a number for the harmonic content.
But the most important question is:
Is the waveform the same as the actual mains waveform. The actual mains waveform may show the same distortion, or it may not....
Your transformer does not have to create a perfect sine wave, but it needs to be a good copy of the input signal.
This is the input (blue) and the output (red) of my common mode choke circuit. The input is the 230V mains voltage. I used a scope with isolated input channels to prevent lethal voltages on the scope.
P.S. the output is leading in phase, not lagging as I would normally expect...
Edited 2023-09-12 23:30 by Volhout
Posted: 01:52am 13 Sep 2023
That such a large capacitor was needed after the voltage divider without entirely eliminating the distortion indicates I was wrong. It can't be winding capacitance so I tested a variety of transformers and the largest was less than 1nF between windings, so a 100nF should have fixed it.
That leaves core saturation as the most likely cause, which suggests that transformer isn't suitable for 240V 50Hz.
This idea can be tested by putting a resistor in series with the primary. Choose a value that reduces the primary voltage to 150V to 200V and see what the output looks like.
To see if this is common to small transformers I made the following test circuit using a tiny 1.3VA transformer.
The result is much better and is what yours should look like.
Edited 2023-09-13 11:54 by phil99
Posted: 07:16am 13 Sep 2023
IIRC the "proper" VTs that we used to use had quite bulky cores for their burden rating. That may explain it, making it difficult to saturate the core. Given that, avoid toroids as they saturate if you breathe on them. After that it's probably a compromise. The best way is probably to wind secondary first (keep it close to the core for best characteristics), then lots of insulation, then the primary (where it cools better). Split bobbin transformers may not couple the primary and secondary closely enough for good monitoring. All this waffle might explain why VTs cost a lot more than ordinary mains transformers. :)
Having said all that, I'd be tempted to try a 30VA or 40VA toroid loaded to 10mA or so. I think you probably need the core size and close coupling (even though the layers are the wrong way round).
Frank N. Furter
Posted: 07:24am 13 Sep 2023
@Volhout:
  Quote  You have not given any pass-fail criteria. Is it good enough ...? I cannot judge.
You are right! At the end of the day, I would like to be able to measure the power to approximately 100W to 200W (500W would possibly also be sufficient). The most important thing is whether power is being generated or consumed at the moment.
  Quote  Is the waveform the same as the actual mains waveform. The actual mains waveform may show the same distortion, or it may not....
How can I measure that? I have an oscilloscope and an isolating transformer...
Your curves look really very good - I think I have to try your setup too!!!
Do I see correctly that you used 150V AC in your simulation? What is the power dissipation of your circuit?
I should still have a few Würth common mode choke here...
@phil99:
I used this transformer here.
This is a small 0,33VA transformer...
I could put a second transformer in series for a test - should that do anything?
Otherwise I have to look for suitable resistors here...
Frank
Posted: 07:43am 13 Sep 2023
If you use resistors put a series string of them together so that you don't exceed their voltage rating. If you take the input impedance of the 'scope (usually 1M) into consideration then you can make up a potential divider so that the output voltage can't exceed the 'scope's input rating. The current through the resistors will be low so they won't get hot. I used to thread HV strings through fish tank airline tubing when measuring a few thousand volts. :)
Posted: 08:06am 13 Sep 2023
  Quote  I could put a second transformer in series for a test -
Yes that would be ideal. With such a tiny transformer (0.33VA) the primary resistance will be very high, the 1.3VA one measures 1.9k and the smaller they are the higher it gets.
So you don't have to alter the rest of the circuit also put the secondary windings in series, making sure they have the same phasing or there will be no output..
     Page 2 of 3
