Local Time 22:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ecological simulation on picomite and cmm2
hhtg1968
Posted: 09:14am 11 Jun 2023
in the corner down left is a counter for the "years" since start.
the exact observer will see that the wolfes only survive in a big area. on a small island they will not survive so long.
the params and probabilities are estimated by me. may be there are better params. everybody can try.
to turbo46: i think the program is fast running at mmb4w. on the cmm2 one year is about 7 sec...
Turbo46
Posted: 10:29am 11 Jun 2023
Thanks hhtg1968.
The program is very fast on MMB4W about 5 to 7 'years' per second on my laptop.
I expected that when I typed 'H' at startup that it would take me to the help screen but no.
It does go to the help screen while the program is running but when I return to the game from that it starts writing the updates to the screen over the help screen text. That maybe something to do with the saving you were talking about earlier and it may be something to do with MMB4W. Maybe the screen buffer may help with that but others will know better.
I'm better at being a critic than programming and I will never understand your program. But I can fiddle around the edges of it.
I will try it on the CMM2 tomorrow I'm sure it will be better.
Also I see nothing about the wolves in the help screen now?
hhtg1968
Posted: 10:44am 11 Jun 2023
to turbo46:
in the programm i have a sub routine for caching the screen and fetch the screen back.
"sub cachescr
if v$="Colour Maximite 2" then blit read 1,0,0,dx,dy
if v$="PicoMiteVGA" then framebuffer copy N,F
end sub
sub popscr
if v$="Colour Maximite 2" then blit write 1,0,0
if v$="PicoMiteVGA" then framebuffer write N
end sub"
that means if v$ has another content the program caches not and so on. i do not know the
mm.device$
exactly for mmb4w. it could be "DOS". look at the foto...
but exists versions for dos and another for windows? in the manual from the dos version i cannot find any graphic commands...
hhtg1968
Posted: 10:51am 11 Jun 2023
to turbo46:
it is random wether there are wolfes or not at the beginning...
insert wolfes by pressing "w"
the keys are:
A - atomic bomb!
n - count the lifeforms
r - run           q - quit
c - circle water  C - filled
k - circle clean  K - filled
g - circle grass  G - filled
p - circle poison P - filled
w - insert wolfs  s - insert sheeps
W - rain/water    x - poisened rain!
L - load landscape  S - save
   file: lifepx4.png
o - show and change parameters
h or ? - this help page
Turbo46
Posted: 11:41am 11 Jun 2023
MM.DEVICE$ from the MMB4W manual.
  Quote  "DOS" when running on Windows in a DOS box.
“MMBasic for Windows” when running in Windows 10 or later
"Generic PIC32" for the generic version of MMBasic on a PIC32.
But I would not worry about it until or if you have MMB4W running.
Sorry about my 'wolf' comment, it is there I was wrong.
Also your use of:
do
loop until inkey$=""
Normally you would be waiting for a key to be pressed:
Print
Print"press a key to start or wait 10s"
print
do
loop until inkey$<>""
But I am guessing that it did not work first time for you and I believe that is because there is already some keycode in the buffer. That is why I suggested that you use:
do : loop until inkey$="" ' get rid of any earlier keypress
before waiting for a keypress like:
timer = 0
do
if timer => 10000 then exit do ' wait for 10 seconds
That confused me the first time in CMM2 it may be a bug but I don't know. I stole that idea from someone else but it always works.
hhtg1968
Posted: 05:28pm 11 Jun 2023
turbo46 wrote:
"But I am guessing that it did not work first time for you and I believe that is because there is already some keycode in the buffer."
yes, you are right.
hhtg1968
Posted: 08:08pm 13 Jun 2023
about one hour ago i started my (first) picomiteVGA!
now i must recognize that my simulation does not run 100%. i will change it...
here is an ascii version...
LIFE.BAS.zip
hhtg1968
Posted: 10:22am 18 Jun 2023
here is a version for picomite without vga - vt100 with colours...
lifevt100.bas.zip
hhtg1968
Posted: 01:46pm 18 Jun 2023
newer vt100 version:
lifevt100.bas.zip
